Like Tree23Likes
Old 05-07-2012, 06:19 AM   #5791
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
The Losi springs are closer spaced than the Durango ones, so you dont have to make huge jumps in spring weight. Kyosho are my favorite springs.....but they are HUGE money! Avid has some good ideas with their new spring line. The only fall back is the jump between rates.
Ray Kindstrom is offline   Reply With Quote
Old 05-07-2012, 06:34 AM   #5792
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
Ray - with the shorty pack or full-length?
I've been thinking of giving the shorty a real try and spending some time with it.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 05-07-2012, 06:48 AM   #5793
Hey JR. The setup was with a shorty lipo. I tried to get a full size lipo to work as well and was able to get it close with 1.1 front pistons and kit springs. It just wasn't as consistent as the shorty pack.
Added some info to the original post (JC body/wing and Panther tires)
Old 05-07-2012, 07:56 AM   #5794
Jeremy Blair's Avatar
Trader Rating: 23 (100%+)
jpcopeland1 if you wanna try losi springs here is something to try.
I just started runing the 210 last week but work at my track 3 days a week so I got some good tuning time. There is no comparison this car loves the shorty packs. My 22 didnt change much with the shorty but the 210 to me became more responsive and reacted faster with the shorty. As far as losi springs I have found a shock setup that is working great on my car. To me the 6 hole pistons didnt feel like they had enough pack so I took the blank pistons and drilled some 4 hole 56 pistons with 22.5 oil and whit springs on rear and orange up front and my car was REAL good. A local die hard AE driver drove my car saturday and sold his b4.1 on sunday. Glad I decided to try the car after the shock change I am lovin it.
Clints creations Painting : clintscreations.com
Raceway Hobby
Cowtown RCC Club member
Jeremy Blair is offline   Reply With Quote
Old 05-07-2012, 08:17 AM   #5795
Trader Rating: 137 (100%+)
That was the exact matchup of losi springs I was thinking of trying. orange fronts, white rears. For my pistons I stuck with the stock Durango pistons and epoxied 2 holes shut. I have spare sets so glueing holes shut isnt a big deal, and they've help up. Using regular CA wouldnt stand up to the rigors of off-road, the seals would pop out. As far as oil goes, I stuck with 30 all around, helped my car land a little smoother without excessive chassis slap, and it soaks up the rhythm section a bit better then lighter oil. However changing out springs may make me have to go to a lighter oil.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-07-2012, 09:32 AM   #5796
spiro's Avatar
Anyone have problems getting the slipper tight enough? Feels like I don't have any spring action left, and still the slipper seems too loose.
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 05-07-2012, 09:43 AM   #5797
MikeFriery's Avatar
Trader Rating: 19 (100%+)
May want to try pink or yellow Rears, remember the Durango has a very heavy rear end
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 05-07-2012, 09:47 AM   #5798
Jmuck69's Avatar
I have noticed differences in length with the aluminum spacer for the layshaft. One with the kit was perfect and rencently put a new one on. It was a tad too long. I had to sand it down carefully to free everything up. I would suspect that the spacer is too short. Try using a shim or two on the topshaft and that will compress the slipper plate near the motorplate.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-07-2012, 09:53 AM   #5799
I ran into this the other day. My slipper pads had glazed over to the point of no return (compltely my fault I had changed from mod to stock and didnt check my slipper, pads were wasted), swapped with AE's which are a direct fit with the RW spurs I use and problem was gone.
Old 05-07-2012, 09:59 AM   #5800
onekiwi's Avatar
same thing here I swapped to a schumacher slipper which is a little thicker
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 05-07-2012, 10:00 AM   #5801
spiro's Avatar
How can you tell when the pads are beyond the point of rescue?
Old 05-07-2012, 10:01 AM   #5802
spiro's Avatar
Thanks for this tip, I'll investigate...
Old 05-07-2012, 10:04 AM   #5803
onekiwi's Avatar
Have a look at them if they are shiny then you can use some fine sandpaper and or scrape off the glazing.
Flip them first and use the other side then look at sanding or replacing them
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 05-07-2012, 11:24 AM   #5804
aloksatoor's Avatar
Trader Rating: 42 (100%+)
x2 on that
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-07-2012, 11:26 AM   #5805
aloksatoor's Avatar
Might sound funny but you sure the diff is not slipping? Did that to my last diff rebuild kit from bfast today!!
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
