Durango DEX210 Thread
#5716
My nano-tech shorty packs arrived today, and I must say what an improvement they make on the car. I had some kyosho battery spacer foam in different sizes, removed the front battery stopper and placed a small piece to protect the servo while still being able to run the battery all the way to the very edge. If I didn't prefer the HV savox servos I would definitely consider that shorty one so I could place the battery even more forward.
I've always been a big fan of kyosho springs, thought I'd try and find a good spring combination and I settled on the buggy soft/white for front and rear. Have been very happy with them, with the shorty pack now though the front and rear have almost perfect balance spring wise.
All that with a tresrey steering plate, lunsford ballstuds, turnbuckles and cups, TD gear diff with kyosho 5k diff oil, absolutely loving this car couldn't be happier.
#5718
Running gear diff indoor carpet med traction. AE black grease mm4 smooth as butter. Ball diff was a pain in the back side to git just right, and make it stay that way. Using red o-rings with green slime on the out drives. Also using the AE B4.1 slipper pads V2 the rango ones seamed to gloss over really fast. Thinking i have a bent lay shaft screw
#5719
in what situation would you benefit from a longer chassis ? and why +8mm and not a other figure.
what are the benefits of a longer chassis
#5721
Oh, and downsides? Im not gonna swap all my stuff on a longer chassis when I race a bumpy track and put it all back to the original chassis when racing on a smoother track.
there should me a nice chassis in the middle, or are there no downsides on a longer chassis
#5724
I almost think that because these drivers drive sooo many classes. They try to get each car to handle similarly. And extending the chassis of a buggy will help get you there.
#5726
Just get another car... one for indoor/smooth and one for outdoor/rough...
