Like Tree43Likes
Old 05-02-2012, 02:13 PM   #5701
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by jpcopeland1 View Post
Funny thing is I thought I had. Guess I didn't... Live and learn. spacers were fine. 4mm on each side rear of hub.
At a club race, I had the axle in the #4 insert with 2 spacers behind the caster block. At full turn, the front wheel was binding on the A-arm and locking it up which caused a horrible push. Finally i had the A-ha moment and realized my absent mindedness.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 05-02-2012, 04:51 PM   #5702
Azagar's Avatar
My nano-tech shorty packs arrived today, and I must say what an improvement they make on the car. I had some kyosho battery spacer foam in different sizes, removed the front battery stopper and placed a small piece to protect the servo while still being able to run the battery all the way to the very edge. If I didn't prefer the HV savox servos I would definitely consider that shorty one so I could place the battery even more forward.
I've always been a big fan of kyosho springs, thought I'd try and find a good spring combination and I settled on the buggy soft/white for front and rear. Have been very happy with them, with the shorty pack now though the front and rear have almost perfect balance spring wise.
All that with a tresrey steering plate, lunsford ballstuds, turnbuckles and cups, TD gear diff with kyosho 5k diff oil, absolutely loving this car couldn't be happier.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 05-02-2012, 04:54 PM   #5703
goBezerk's Avatar
Send a message via Skype™ to goBezerk
Originally Posted by murky123 View Post
I wanna know , who drives the durango gear diff, on what surface and what kinda grip level.
But most importantly, what oil you have in the gear diff.
I run on outdoor rough clay tracks. They vary from low/medium grip with dust to medium+ when it's had a good amount of rain.
I run the AE black grease and it feels great, I run a lot of motor and the 210 just eats it up. The gear diff allows me to run the slipper a bit tighter so it has awesome punch when needed. I run both MM4 and RM4, starting to lean back toward the RM4 tho...
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 05-02-2012, 07:06 PM   #5704
Jmuck69's Avatar
My new Proline Bulldog body. I like the looks of this a little better than the Jconcepts Finnisher. Supposedly, the Bulldog is a little less aggressive than the Finnisher in regards to handling and steering. I will find out Friday night.
B6D | B64D
Old 05-02-2012, 07:23 PM   #5705
jonski's Avatar
Trader Rating: 241 (99%+)
Hey guys...I bought these upper shock mounts http://www.team-durango.com/part-inf...artNo=TD330032 and the shock cap doesn't fit them very well. Is there another part I need to get to get these to work? The shock cap is very sloppy on the mount.
First RC car was a RC10T - 1992
jonski is offline   Reply With Quote
Old 05-02-2012, 07:38 PM   #5706
Jmuck69's Avatar
http://www.amainhobbies.com/product_...vot-Ball-Set-4
B6D | B64D
Old 05-02-2012, 07:43 PM   #5707
does anybody use the gear diff? does it work better than the ball diff ?thinking about getting one less matenance thats the best thing.
zylstra is offline   Reply With Quote
Old 05-02-2012, 09:03 PM   #5708
Tunatsol's Avatar
Running gear diff indoor carpet med traction. AE black grease mm4 smooth as butter. Ball diff was a pain in the back side to git just right, and make it stay that way. Using red o-rings with green slime on the out drives. Also using the AE B4.1 slipper pads V2 the rango ones seamed to gloss over really fast. Thinking i have a bent lay shaft screw
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 05-02-2012, 09:42 PM   #5709
jonski's Avatar
Thanks Jmuck
Old 05-02-2012, 10:12 PM   #5710
Trader Rating: 520 (100%+)
Looks great, didnt like the bulldog when I first saw it, but your paint scheme makes that body look better than I thought it would-NICE
flame56mx is offline   Reply With Quote
Old 05-02-2012, 10:21 PM   #5711
Jmuck69's Avatar
I like the long sweeping curve of the cab better than the Finnisher. larry at KustomRCGraphics.
B6D | B64D
Old 05-03-2012, 03:42 AM   #5712
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
It is virtually maintenance free when comparing to the ball diff.
I run the Gear diff with just a dab of (real car engine assembly tacky oil) and it performs like a champ. I run on 2 different tracks. One HIGH traction indoor clay and the other outdoor track that is lumy. I have roughly 40 hours of run time on the diff and is still butter smooth vs. the ball I would had issues with grit getting into the thrust bearing and would adjust it during driving.
The biggest thing i see is the consistency with the diff.
nolimit208 is offline   Reply With Quote
Old 05-03-2012, 03:45 AM   #5713
nolimit208's Avatar
use this guide to assemble the gear diff. has part numbers for the better o-rings to use in the diff then its stock rough edged rings that people say leak. I have been using the stock ones with out issue but use a tacky oil
http://www.petitrc.com/setup/durango...bly/index.html
Old 05-03-2012, 03:48 AM   #5714
nolimit208's Avatar
the aerodynamic profile of the body is almost identical to the finnisher. Unless your running a tunnel with 200+ winds, you will not notice the difference between the two (besides it's original placebo effect)..
Old 05-03-2012, 04:40 AM   #5715
murky123's Avatar
great info for me, thanks.
Im still on RM3, why do you prefer RM4 ?
Im down to 50wt Losi shock oil in my gear diff
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
