Like Tree24Likes
Old 04-28-2012, 11:32 PM   #5641
onekiwi's Avatar
Originally Posted by Jonny5 View Post
+1 for the Tresrey mount. 4mm carbon fiber- will not break, period. Plus cf is just sexy!
Not true I done my front tower on the 410, don't know how but it happened
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 04-28-2012, 11:53 PM   #5642
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Breaking the bracket for the rear linkage wouldn't really happen though with the 4mm CF. Shock towers are a different story since you can land on them and if your on clay can easily snap a 4mm shock tower at higher speeds.
nolimit208 is offline   Reply With Quote
Old 04-29-2012, 12:46 AM   #5643
Tunatsol's Avatar
Originally Posted by EvanAZ View Post
Anyone have a part number other than the manuel for the Diff nut and spring for the ball diff? Or an alternative that works?
I think will all the stuff u have to go though to git a ball diff just right and maintan it is not worth it. Put the geardiff in and never think about it for 1 to 1.5 months.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 04-29-2012, 04:25 AM   #5644
LoudOne's Avatar
Trader Rating: 31 (100%+)
I just read in the latest RC Car Action, that the open side of the thrust bearing needs to face the larger spacer. I put it facing the smaller spacer facing the head of the screw. The instructions were not clear at all (even the diff build video on their site). Before I take this all apart, I'd just like to know if this really makes a difference.
Team Durango's site says this: With the tighter thrust washer on the diff screw – coat it well with the provided black grease before dropping the caged thrust balls on top. Finish the assembly by coating the other thrust washer in grease and placing it on top to effectively sandwich the thrust balls.
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 04-29-2012, 06:02 AM   #5645
LoudOne's Avatar
Team Durango's site says this: With the tighter thrust washer on the diff screw coat it well with the provided black grease before dropping the caged thrust balls on top. Finish the assembly by coating the other thrust washer in grease and placing it on top to effectively sandwich the thrust balls.
Actually, I just looked at the video on the Durango site and if you look closely, he places it so that the inner part of the thrust bearing (where the bearings are recessed) is placed downwards towards the smaller spacer... I guess RC Car Action is wrong?
+ YouTube Video
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
Schumacher KF2
Old 04-29-2012, 06:49 AM   #5646
Trader Rating: 137 (100%+)
+ YouTube Video
I wouldnt trust RC Car Action to do anything right. Stick to the Durango vids. (after all they made the car) and your good to go.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-29-2012, 09:52 AM   #5647
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Default Diff question
Hey are any of you using the Bfast diff or have any thoughts on it .? I'm thinking of trying one out.
Thx,
Kevin
Kevin Murphy
Associated B5m/Reedy
AP Custom Paint/Kal-Gard/
Slimsh8t is offline   Reply With Quote
Old 04-29-2012, 09:54 AM   #5648
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Thx,
Kevin
Best in the business! Run them in everything.
Ray Kindstrom is offline   Reply With Quote
Old 04-29-2012, 10:41 AM   #5649
Trader Rating: 19 (100%+)
+1. Outdrives generally wear out for us before we need to replace the diff balls/rings. The carbide balls they use are extremely high quality and make for the smoothest diffs I've ever built. Check them out, you won't be disappointed!
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 04-29-2012, 11:51 AM   #5650
Jmuck69's Avatar
+1. I bought two sets initially one to use and one for future rebuilds. Extra set just sits there in my spares box unloved and feeling neglected. when rebuilding, just flip the diff rings an relube everything and your set.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-29-2012, 02:01 PM   #5651
Slimsh8t's Avatar
Awesome..! Thanks for the feedback fellas I ordered 2 complete sets this morning with some of their lube & grease as well.
Thx,
Kevin
Kevin Murphy
Old 04-29-2012, 03:03 PM   #5652
Trader Rating: 520 (100%+)
Thx,
Kevin
Good stuff, It's the only grease I use, I still have the stock rings in mine, flipped once after 20 packs, and they are still feeling like new..crazy..
flame56mx is offline   Reply With Quote
Old 04-29-2012, 04:17 PM   #5653
Thx,
Kevin
Love my bfast diff.
Old 04-29-2012, 04:18 PM   #5654
Are you guys having to crank down the diff pretty hard to keep it from chirping? Mine seems awefully tight compaired to other cars I have driven. Wondering if that is making my push issue even worse.
Old 04-29-2012, 05:03 PM   #5655
Capttaze's Avatar
Default Gear Diff
I agree 100% easier in the long run
Capttaze is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
