Like Tree43Likes
Old 04-24-2012, 02:16 PM   #5521
Trader Rating: 19 (100%+)
Originally Posted by Dog Runner View Post
I'm wondering about shock oils and am currently using the 4-hole pistons (I think that's 1.3 and 1.2) with losi oils anywhere in the range of 25 to 37.5. It's a high-speed, medium-traction indoor clay track that's kinda bumpy with a few big jumps. Currently running 30wt oil front and back.
Any thoughts on what others are currently using for oils? I'm running RM with a full stick battery pack.
Cush's car has Losi 27.5 front and Losi 30 rear with those same pistons. I'd say he's been pretty fast at LHR lately
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 04-24-2012, 02:48 PM   #5522
murky123's Avatar
Default gear diff
I have a gear diff from the second batch. filled with durango 1000cst.
It does feel smooth but at the same time it feels a bit to tight/heavy.
Is it because I use the 2 copper shims from the ball diff on each side? or do I need lighter diff oil ?
I only ran 1 raceday ( 6 heats of 6 minutes ). Do I need to give it some time? maybe after a few packs ?
any thoughts ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 04-24-2012, 03:11 PM   #5523
MantisWorx's Avatar
Trader Rating: 28 (97%+)
any thoughts ?
There will be some that disagree with this but after talking to a few 210 "fast" guys at the nats and my own experience just use AE black grease and only enough to lubricate. it will not "dif " out and responds much better than the thicker stuff. which to me made the car darty and it wanted to follow the track ie if the track was uneven the car would go with the track instead of straight. went to a light grease and it all went away. maybe on carpet or turf you could go up if you need to.
MantisWorx is offline   Reply With Quote
Old 04-24-2012, 03:28 PM   #5524
murky123's Avatar
so just the AE black grease "in" the diff ??
By the way I love that grease, use it for almost everything
oh and this is where I race. hardpacked dirt, mostly low/mid grip
http://www.petitrc.com/setup/durango...203/index.html
edit:
Or is it maybe , that I used O-rings from Tresrey # TYS246 red o-rings
when installing those O-rings they were slightly to big, but I got them to fit and put the e-clip in the groove with a little force. Could they couse such a drag ?
Old 04-24-2012, 06:22 PM   #5525
Konich's Avatar
The Tresrey P-5's are Black, but they will be a tight fit and loosen up after a couple of runs. ALWAYS use some AE green slime on them before installing them though.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 04-24-2012, 07:20 PM   #5526
MantisWorx's Avatar
edit:
yup, just the black grease !
Old 04-25-2012, 04:57 AM   #5527
Trader Rating: 139 (100%+)
Originally Posted by Ray Kindstrom View Post
Not sure about the K ones but I know the tamiya ones fit like a glove. Before guys were upgrading to the alum block I was handing them out like candy on Halloween! Plus they have a nice coating on them that makes them "oh so smooth"
http://www.speedtechrc.com/store/ebp...id=618&id=1786
Looked at an RB5 that was being rebuilt at the track, and it looked like the Kyosho bushings might be a tad bit too big. The Tamiya ones look very nice indeed though.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-25-2012, 07:30 AM   #5528
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by Jmuck69 View Post
I am using the delrin pieces from Ghea.
http://www.ghea.se/produkt.php?sd_esp_1_pid=32
How do you like them? Did u order direct or is there an online U.S. dealer?
BOLISARIO is offline   Reply With Quote
Old 04-25-2012, 08:04 AM   #5529
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I like them, they seem to take the slop out. There is a US dealer for Ghea but they only seem to carry the AE Ghea parts so I ordered directly from Ghea in Sweden. Took only 4-5 days to get here. You get 10 to a pack.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-25-2012, 08:20 AM   #5530
dexon555's Avatar
Is that price really $45 for ten?
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 04-25-2012, 08:27 AM   #5531
Jmuck69's Avatar
It's 75 SEK which is $11.12 US
B6D | B64D
Old 04-25-2012, 08:33 AM   #5532
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
- For those of you who flipped the steering rack -
Are you running the ball stud underneath the spindle or on top?
Yokomo USA - Protek - AMain - ProLine - Fantom - Exotek
Ray Kindstrom is offline   Reply With Quote
Old 04-25-2012, 08:37 AM   #5533
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
How much was shipping?
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 04-25-2012, 08:50 AM   #5534
Jmuck69's Avatar
It was 50sek or $7.42 US. Total order was 125sek or $18.55 and took less time than many US orders.
B6D | B64D
Old 04-25-2012, 09:13 AM   #5535
BOLISARIO's Avatar
Hey fellas, got any setups you would recommend for a med-high bite indoor clay tracks like WCRC, OCRC, or any other tracks with similar grip characteristics? Since the 210 has a good amount of rear grip, I'm looking for a setup that will provide me with plenty of steering. I was hoping to try MM but it seems like the majority of the setups online use RM3 or 4 and only saw one with MM3(Lutz) for indoor clay.
I'm going to get my 210 soon and need a great baseline setup. Thanks.
Also, where are you guys getting tapered pistons from: GHEA, RC Shox, Oople,etc? What should I use front/rear: 1.2,1.3,or 1.4 & 2,3,4 hole?
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
