Like Tree43Likes
Old 04-21-2012, 12:55 PM   #5461
Konich's Avatar
Sounds like an outdrive or the scew is backing out of the shock piston. Those would be the next 2 things I look at.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 04-21-2012, 01:33 PM   #5462
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally Posted by Raul Garcia View Post
Bolisario,
the only way to go it the shorty lipo. Most people dont use one because they dont already have one. But.... if they had one they would never use a full size pack again. It allows for adjustability on the chassis. You can place balance weight where you want. My Venom 3800 60c weighs 7 oz less than my Venom 5000 60c packs. Much happier all the way around.
Murky123 Looks good... Needs some red though!
Kwiski, Getting a new 410?
Alex, hows the sale going?
Konich, HI!
Awesome,thanks.
So 3800-4000mah is enough to last 5-6min?
How are those Venom Lipos holding up?
BOLISARIO is offline   Reply With Quote
Old 04-21-2012, 01:44 PM   #5463
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I have a 3800 and it lasts longer than any main. I practiced with it for 15 minutes last week and it just kept going.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 04-21-2012, 02:28 PM   #5464
Trader Rating: 520 (100%+)
Originally Posted by TAMAK View Post
Hey guys, I am experiencin some chatter from the rear wheels on steady throttle when lifted off the bench. Never really noticed it before. I checked the hub / cvd assembly replaced bearing and no dice. I am thinking its the outdrive wearing out a bit. Thoughts?
The chatter is from the angle the cvd in is from the outdrives at full droop, if you compress the arms just a slight bit, it goes away..I run the black (nitride or whatever) shock shaft, which are 3mm shorter, and my chatter disappeared..
flame56mx is offline   Reply With Quote
Old 04-21-2012, 05:51 PM   #5465
Trader Rating: 138 (100%+)
Default Manual help needed.
building to run rear motor, on page 34 of the manual there is a step where you put 2 black spacers on the 30mm counter sunk screw that come through from the bottom of the chassis. Any idea how these are supposed to work in there? mine according to the parts tree they came off of (the spacers), are way too big to go in there anywhere that I can see. Any help would be appreciated. Spacers are pt. number 320128-6 black plastic.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-21-2012, 05:53 PM   #5466
Sticking 3 1mm spacers in there would do the same trick? Not ready to buy new shock shafts just yet. Also are you even using the droop screws?
Old 04-21-2012, 06:02 PM   #5467
The spacers fit inside the angled plastic chassis plate, they should slide in to give the nut holder thing a flat surface to land and be bolted to-understand what I am saying? Droop screws-I dont use them, and yeah, the spacers will limit the shock the same way.
Old 04-21-2012, 06:18 PM   #5468
Trader Rating: 74 (100%+)
Originally Posted by BOLISARIO View Post
Awesome,thanks.
Venom lipos are awesome. Can beat the value for dollar. And they have the lifetime guarantee. 3800 is plenty , I've run it on my 4x4 SCT for a 8min main no sweat.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 04-21-2012, 06:28 PM   #5469
netmaster's Avatar
I believe the printed instructions have it wrong, the ones online have it corrected.
Gary Mazur
811Be, DEX210
JConcepts
netmaster is offline   Reply With Quote
Old 04-21-2012, 06:42 PM   #5470
Same in the manual, The black bits circled in red are what im having a problem with.
Old 04-21-2012, 06:42 PM   #5471
hacker's Avatar
Trader Rating: 141 (100%+)
the whole point of droop screws is to remove the labour intensive process of pulling the shocks apart and putting internal spacers in. Use them
hacker is offline   Reply With Quote
Old 04-21-2012, 06:43 PM   #5472
hacker's Avatar
use online manual, I did this a couple of weeks ago, its a -4 if I remember correctly.
Old 04-21-2012, 06:44 PM   #5473
Gotcha, thanks alot. You running yours in mid-motor? I know you were playing around with the X-60 last time we talked.
Old 04-21-2012, 06:45 PM   #5474
netmaster's Avatar
I know myself and many others came across this. The right parts are in there. The online manual does not give a different part number?
Gary Mazur
811Be, DEX210
JConcepts
Old 04-21-2012, 06:47 PM   #5475
hacker's Avatar
here it is
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
