Like Tree26Likes
Old 04-16-2012, 05:34 PM   #5386
Jmuck69's Avatar
Originally Posted by Jonny5 View Post
We did a couple between the two cars before the switch to aluminum was made. As long as you have a quality metal gear servo all should be good. The bellcrank should break before the servo.
I have the Orion VDS-1007 so it should be bullet proof.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-17-2012, 01:35 AM   #5387
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by Mopar View Post
You can't just shim up the mounting plate as that would also push up the tranny, shock tower and everything else. That's the reason the kit comes with multiple plastic mounts. I run the TeamSR 3/3's on 2 cars like the kit standard. Works for me.
If the mounting plate hits that tab on the Tranny when and if i shim it I would just shave off some of that tab that sits above it if needed.
nolimit208 is offline   Reply With Quote
Old 04-17-2012, 02:44 AM   #5388
If you get a 3degree toe 0 degree antisquat plate then you can shim it to the max 3 degree antisquat. I bought the RC Junky aluminium rear front brace version which comes with shims and it works fine as the RF brace is attached to the chassis and not the gearbox so does not alter its height only the hinge pins for antisquat.
Schumacher K2, KF2, K1, KF | TeamC TM2 V1, TM4 | Durango DEX410 V3 | T-Rex 450SEV2,250SE | EMAX 250 | Gravity 250 | KC250
AmiSMB is offline   Reply With Quote
Old 04-17-2012, 11:25 AM   #5389
Fitted a New Savox 1258 servo and can't seem to achieve full lock either way, i've even have the EPA to 120% and still no joy. Is there a way to adjust the steering linkage?
retro_ryan is offline   Reply With Quote
Old 04-17-2012, 12:47 PM   #5390
Jmuck69's Avatar
Zero everything on your radio, EPA and trim. Make sure tie- rods are a match. The linkage from servo horn has a 2mm gap and servo horn is on straight and not cocked to one side or the other. The recheck.
B6D | B64D
Old 04-17-2012, 12:50 PM   #5391
TAMAK's Avatar
Trader Rating: 28 (100%+)
Also make sure your caster inserts are on the same direction. lol... Not very proud of my mistake.. lol
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 04-17-2012, 12:53 PM   #5392
Jmuck69's Avatar
I did that one race day. Went from #2 position to zero without changing caster block. Could figure out why I had a horrible push! After the second quali, I had homer Simpson moment. I was embarrassed for myself.
B6D | B64D
Old 04-17-2012, 02:17 PM   #5393
Anyone running in 17.5 no boost?
goofy4d is offline   Reply With Quote
Old 04-17-2012, 02:54 PM   #5394
Jmuck69's Avatar
Did anyone notice all of the new goodies added to the 210 "option parts"? Steel and aluminum pinions gears, tapered big bore pistons, dual tapered pistons, vented slipper plates, aluminum CVD axles, aluminum steering plate & steel front axle. Oh me..oh my!
B6D | B64D
Old 04-17-2012, 03:03 PM   #5395
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Yes...
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 04-17-2012, 03:09 PM   #5396
aloksatoor's Avatar
Trader Rating: 42 (100%+)
But seriously this has been the first car that I did not feel the need to upgrade anything!! That's awesome work by 'rango!! Doesn't mean I dint buy the tresrey shiny bits though
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-17-2012, 03:12 PM   #5397
Jmuck69's Avatar
True. i have a few Tresrey bits. rear CF camber brace, aluminum hexes and CF steering plate are the must haves. That's it! I do want Durango pinions because mine are wearing out.
B6D | B64D
Old 04-17-2012, 03:15 PM   #5398
aloksatoor's Avatar
I got the rw pinions and spurs whisper quiet and no wear yet !! the pinions I only found in speedtech online though but worth it
Old 04-17-2012, 05:49 PM   #5399
Autocratic's Avatar
Trader Rating: 26 (100%+)
Selling my DEX210.
FS: Team Durango DEX210 Many Upgrades + Huge Spares & Tires List
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 04-17-2012, 06:25 PM   #5400
DBL15's Avatar
Originally Posted by Autocratic View Post
i noticed your now selling both durangoes mate what car you moving onto?
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
