Like Tree24Likes
Old 04-10-2012, 08:27 PM   #5296
jonski's Avatar
Trader Rating: 233 (99%+)
Looking for some ball cups...part #330293. If anyone has any, please let me know.
jonski is offline   Reply With Quote
Old 04-10-2012, 08:49 PM   #5297
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by EvanAZ View Post
Anyone know if the B4 Lunsford tie rods will work on the buggy? they look like they are just a tad bit longer and can be shaved down a bit.
Didn't want to drop $80 on a complete T.I. kit.
Originally Posted by ajj View Post
I was wondering about cheaper options for Ti turnbuckles too. Anyone know the average weight saving of the Ti turnbuckles and how much extra you save with the Ti ballstuds?
I haven't had any problem with the standard ballstuds myself so not really ready to change.
So, i got these lying around so i decided to use em in my 210
Lunsford Tie rod for 22
and i partnered it with these...
and the end result.
no issues so far and much cheaper than $80 buks......
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 04-10-2012, 08:51 PM   #5298
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I am in same boat
only place i see them is ebay.
http://www.ebay.com/itm/Team-Durango...item5d330813b1
nolimit208 is offline   Reply With Quote
Old 04-10-2012, 08:53 PM   #5299
slow_jun's Avatar
Originally Posted by DBL15 View Post
do you mean the gear diff is out for this now ? i have been holding off as i dont like ball diffs but if gear diffs are out i am interested for sure
not exactly the same but i believe i heard from another site (oople) that the first batch of Gear diff from TD the main gear is a bit off and will cause some binding with the gear casing and they are recalling.. maybe the same batch with issues.....
Old 04-10-2012, 08:55 PM   #5300
EvanAZ's Avatar
Trader Rating: 99 (100%+)
and the end result.
Very cool, did you have any issues threading the ball studs into the metric holes? Going to LHS tomorrow and will look for these.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 04-10-2012, 08:56 PM   #5301
slow_jun's Avatar
Originally Posted by nolimit208 View Post
I am in same boat
if you have time......
Tower Hobbies
Old 04-10-2012, 08:58 PM   #5302
slow_jun's Avatar
No issues, just that the TI is a bit long, if your heart can take it, you cut it shorter coz its a bit longer than the 210. so i think the only issue is when you try to adjust the buckles, it will be a bit tough though..... or you can over tighten it then screw back so that when you adjust it will be a bit smoother...
cheers!!!
Old 04-11-2012, 12:44 AM   #5303
Huleboer's Avatar
I didn't know there had been an issue with the diff, but it makes sense.
I ordered mine from JEspares.com on the 2nd of february, and it was in stock at that time, but not enough to send one to me apparently.
I later mailed JE spares asking for an update and they responded that Durango had made some changes at the factory and that had caused the delay.
So I guess that means I've gotten one from the second batch. I cant feel any mentional binding at least. It's a bit tight but nothing I wouldn't expect from a gear diff that hasn't been run in yet.
Team Associated RC8b3e w/ Hobbywing Xerun 150A 1800KV and Gens Ace 6750mAh 70c
Huleboer is offline   Reply With Quote
Old 04-11-2012, 04:53 AM   #5304
slow_jun's Avatar
from Mb models,
Old 04-11-2012, 04:56 AM   #5305
dexon555's Avatar
Default Turn Buckles
Just get the Lunsford kit. Comes with everything, cups, studs, shafts, and tool. All Ti and build for life.
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 04-11-2012, 10:59 AM   #5306
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Plus lunsfords service is awesome. I had bent 4 Ti turnbuckles, mailed them to lunsford in Oregon, 4 days later got brand new replacements!! I don't know if they do the same for the ball studs and all though!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 04-11-2012, 11:07 AM   #5307
Jmuck69's Avatar
Do not purchase the ti hinge pins! They bend mad crazy, must be made of noodles. The stock ballcups work perfectly with the Lunsford tie-rods. I popped more ballcups with the RPM pieces than stock.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 04-11-2012, 04:25 PM   #5308
slow_jun's Avatar
yeah same(rpm) here,when i changed to Losi HD cups, it dissapeared... hmmm maybe the driver ....
Old 04-11-2012, 04:27 PM   #5309
Anyone now the nuber to get a hold of TD, not the new 217-398-3630 number but the number to someone that knows the buggy and the parts for it?
goofy4d is offline   Reply With Quote
Old 04-11-2012, 04:34 PM   #5310
Autocratic's Avatar
Trader Rating: 26 (100%+)
I wouldn't call the Ti hinge pins "noodles". I've only bent one hinge pin on my 210 and that was from a massive hit due to getting hit from behind off a jump which sent the car off sideways. Broke the left rear hub in two pieces and the arm in half. The hinge pin was bent in the middle of the toe insert; which was still attached to that portion of the arm.
I also have the Lunsford turnbuckle and ballstud kit. Very nice pieces, but I had to purchase longer rear links as the kit 50mm links don't do well on the two outer holes. Not enough threads in the ball cup.
You also have to understand that the hinge pins aren't as thick as the turnbuckles. If you bend a turnbuckle on this car, Lunsford or not, you probably need to start driving something else.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
