Like Tree24Likes
Old 04-01-2012, 07:12 PM   #5161
slick24's Avatar
Default 17.5 blinky gearing
Hey I'm running a Tekin RS with 17.5 D3 in blinky buggy and I'm trying to get alittle more speed out of the thing down the straightaways. Currently I'm running 32/75 and I've read about going to a 69 or 70 spur but I dont know if i should do that or just go with a different pinion first. Any thoughts? If I do go for the smaller spur what range of pinion should i try.
Dillon Buhr
current: TC5 w/SP Reventon Pro SP 4.5R
RJ Speed Speedway Sprinter w/HW 1s 21.5 reedy sonic
www.hexnutracing.com-INOX Supreme Lubricants
Slick offroad wash-Hobby World of Jax
slick24 is offline   Reply With Quote
Old 04-01-2012, 07:49 PM   #5162
rcjunky1's Avatar
Originally Posted by Jmuck69 View Post
Would this be a copy of or similar to the piece Jorn used at the Reedy Race with the extension spacer by the steering?
similar, not the same
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 04-01-2012, 08:10 PM   #5163
Autocratic's Avatar
Trader Rating: 26 (100%+)
What are some ways to dial in more on-power steering?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 04-01-2012, 08:15 PM   #5164
MantisWorx's Avatar
Trader Rating: 28 (97%+)
anti squat is the most effective
MantisWorx is offline   Reply With Quote
Old 04-01-2012, 09:07 PM   #5165
Autocratic's Avatar
I'm already at 3. I have to redo my battery wires but then I can move the shorty pack more forward, which will definitely help.
Old 04-02-2012, 03:41 AM   #5166
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Def go to a RW 69 spur. Start withg the same pinion and go from there. 75 spur is not gonna get you the speed you want.
kwiksi is offline   Reply With Quote
Old 04-02-2012, 04:11 AM   #5167
slick24's Avatar
Alright thank you
Dillon Buhr
Old 04-02-2012, 05:22 AM   #5168
bronc4now's Avatar
Trader Rating: 40 (100%+)
Originally Posted by TAMAK View Post
Looks like Daytons old car! (Signature gearbox box fix)
Yep and it still seems to work good ..
RACE-BASH-CRAWL
Two many toys not enough time..
bronc4now is offline   Reply With Quote
Old 04-02-2012, 05:30 AM   #5169
bronc4now's Avatar
Are people using anti squat in the rear or front .I have the tresrey front bulk head and it has none to use ..
RACE-BASH-CRAWL
Old 04-02-2012, 06:41 AM   #5170
Autocratic's Avatar
There is no ant-squat built into the front bulkhead.
Old 04-02-2012, 07:28 AM   #5171
MantisWorx's Avatar
FYI 1mm spacers under the block is equal to 1.5*, i broke my 3* but shimmed the 1.5 to be the same. I bet if you shimmed yours up another .5mm it may just be enough to get you where you want. I forgot to lock your number donw the other day send me a TXT when you get a chance.
To add to this, using weight to give you more on power steering will also give you more off power steering since it is weight and will actually probably give you too much off power since the weight goes from way up to way down under braking. on power steering needs to be mechanically adjusted.
Old 04-02-2012, 07:31 AM   #5172
MantisWorx's Avatar
Front would be caster, rear anti-squat.
Old 04-02-2012, 08:40 AM   #5173
bronc4now's Avatar
the stock one did have droop screw flats .
Maybe I'm mixed up I ment droop screws that are in the arms ..that's how you adjust anti squat ?
The reason I'm concerned about the front is in a crash witch I do often is the shock piston takes all the load and I'm sure it will break soon and my shock shaft will just pop out..
RACE-BASH-CRAWL
Old 04-02-2012, 09:05 AM   #5174
hopsing's Avatar
Trader Rating: 13 (93%+)
Droop screws are for adjusting the droop and have nothing to do with antisquat.
Most everyone either took their screws out or has them screwed all the way and runs full droop in the front and rear...you shouldn't have any issues with the piston breaking.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 04-02-2012, 09:06 AM   #5175
Trader Rating: 19 (100%+)
The droop screws in the arms are for adjusting droop/shock length and has nothing to do with caster or kickup. If using the Tresrey front bulkhead you need to add/subtract limiters inside the shock to adjust droop.
The 210 has no adjustment for changing the kickup, which is the equivalent of adjusting anti-squat in the rear. However you can easily adjust caster by swapping the inserts in the front caster blocks (where the steering arm mounts). In general, more caster (leaning further back) decreases entry steering and increases exit steering, while less caster (leaning further forward) increases entry steering and decreases exit steering.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CARD
