Like Tree26Likes
Old 03-28-2012, 04:19 AM   #5086
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Proline Bulldog is on A-Main but what's with the $29.49 price? All the other Bulldog buggy bodies are $21.99...
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 03-28-2012, 04:25 AM   #5087
Originally Posted by Jmuck69 View Post
Just installed the Tresrey slipper hubs and shaft. The dimensions of the shaft are off slightly. had to take some length off the aluminum spacer between the outer support bearing and the gear. It was notchy and have considerable bind when the motor plate screws were tightened down. After reducing the length of the spacer it was free. then used two of the included shims and it's perfect now. I am using the RC Shox slipper pads. Overall, very nice. The hubs would look cooler in Tresrey red!
I have one coming, thanks for the heads up.
I have many Tresrey parts. Usually their stuff are made perfectly. I wonder if it is by design or an overlook.
niner is offline   Reply With Quote
Old 03-28-2012, 04:44 AM   #5088
Ok thx guys.
One of e 3 screws r long n I hv put it in e correct place n I hv not let either of the screws protrude out, so next i am going to put some threadlocker at e tip of the screw. Thanks for e heads up guys.
As for the cover, will try again and keep u guys updated. Thx again.
Btw, do u guys hv any recommendations on ride height camber setting n etc?
Cheers guys
wickkerr82 is offline   Reply With Quote
Old 03-28-2012, 07:17 AM   #5089
Oh n yes to add another question if u guys do not mind.
Do u guys tighten the nut of the rear wheels very tightly?
When I do tighten the screws tight or after a certain notch, my wheels tend to lock and so r my gears too. Any idea why? Or am I suppose to not tighten e nut too much?
Vin
Old 03-28-2012, 07:20 AM   #5090
TAMAK's Avatar
Trader Rating: 28 (100%+)
Less Demand with Durango cars?...?
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-28-2012, 07:20 AM   #5091
you want the rear wheels tight but not super tight as it will cause alot of binding and tracking issues.
cm.stites is offline   Reply With Quote
Old 03-28-2012, 07:29 AM   #5092
Trader Rating: 45 (100%+)
Will this body work in Mid Motor configuration?
Apex is offline   Reply With Quote
Old 03-28-2012, 07:31 AM   #5093
TAMAK's Avatar
Hupo uses his in mid motor.
Old 03-28-2012, 07:42 AM   #5094
TAMAK's Avatar
So, I decided to slow myself down last night and raced "blinky" stock buggy to nail down a basic setup. I was really happy with how my car felt all round except for one thing... Corner exit, I could pull away enter and exiting sweepers and S's but on the 180* corners it was a loading the rear and pushed hard. I dont have a setup sheet filled out yet but will soon. I run Losi red F / yellow R and 4 hole pistons 1.3 all round. 22 / 27.5 . Protek shorty all the way forward. No weight up front ( I am leaning towards that as my problem). Thoughts, I have plenty side bite and forward bit, a stiffer rear spring? Thoughts?
Old 03-28-2012, 08:10 AM   #5095
Trader Rating: 19 (100%+)
Vin
Put one or two axle shims between the hex and the bearing and that should solve your issue. You're compressing the hex against the bearing and binding it.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 03-28-2012, 08:13 AM   #5096
Harder rear spring will help. If you're running any outboard toe that might be it too. Outboard toe locks the rear down on power and can cause understeer.
Old 03-28-2012, 08:45 AM   #5097
Trader Rating: 74 (100%+)
Or, increase caster, I have run 35* caster with great success. I run 30* now though. Plenty of steering all through.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-28-2012, 10:17 AM   #5098
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Just buy from proline site is cheaper with the discount code sqrl10 or something. I have one coming.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-28-2012, 12:53 PM   #5099
murky123's Avatar
my yellow dex210
http://www.youtube.com/watch?v=_bitr5C4N6Y&hd=1
[YOUTUBE]_bitr5C4N6Y&hd=1[/YOUTUBE]
track lay-out is about 2 weeks old. it had been very dry for a week now. soil is hardpacked clay/dirt.
you can see a blue groove coming up. this video is taken 2 days after the first raceday on this track
edit: I dont know why but when I preview my post the video is nicley embedded, but as soon as I post it, it doesnt work
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-28-2012, 12:54 PM   #5100
murky123's Avatar
double
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
