Durango DEX210 Thread
#5071
Is there any toe built into the arms or is it all in the hubs?
If you were to flip the arms backwards to mount the shocks in the rear, are there any other changes you'd have to make to keep the car the same as if the shocks are mounted normally? I can't think of anything, but thought I'd ask.
With my former Schumacher Cougar SV, mounting the shocks in the back made a noticeable difference in handling without doing anything else to the car. I'm interested to try this out and see what happens.
#5072
DEX410 for DEX210
If anyone is interested in trading a DEX210 for a DEX410 2010 SPEC, message me.
Full on race ready upgrades including TD machined diff gears Tresrey Parts New clear body etc...
This is my spare.
This is my spare.
#5073
Just installed the Tresrey slipper hubs and shaft. The dimensions of the shaft are off slightly. had to take some length off the aluminum spacer between the outer support bearing and the gear. It was notchy and have considerable bind when the motor plate screws were tightened down. After reducing the length of the spacer it was free. then used two of the included shims and it's perfect now. I am using the RC Shox slipper pads. Overall, very nice. The hubs would look cooler in Tresrey red!
#5074
R/C Tech Elite Member
I built my front shocks the other night, with the black ti shafts. I used Kyo seals, as they seemed to have less shaft drag, and they have always worked for me in the past, they feel really smooth..Can't wait to get my car dirty again.
#5075
Nice Jmuck, I was thinking about that also, but I have a few rw spurs in stock, so I am good to go there. I did however order a few items from Tresery that should be here tomorrow, so I have a little wrenching to do...
#5077
I'm running the gold shafts and are nice. I believe the black shafts are smoother (sounds like a 70's era film...). I just did the rear arm flip mod to try out this weekend. It is right around +6-7mm difference than stock. It was such an easy mod that I think TD designed it like this from the start.
#5078
#5080
3mm difference in rear shock shaft length doesn't change anything. Also, I've found having some droop taken out of the rear helps keep the outdrives in better condition, as they bind and make a lot of noise at full droop with 55mm shafts.
Jmuck,
Definitely waiting to hear some feedback. I'm not sure my next race will require that much change in wheelbase, but it might be something to look into in the future.
Jmuck,
#5081
Jmuck,
Jmuck,
I noticed that also, noisy at full droop, but doesn't 3mm seem a bit much...I just switched mine to RM4, as our outdoor track is going to be shared with 1/8, so its going to get loose and dusty..
#5082
Facing problems with dex210. Need help
Hi guys,
Jus got a dex210. Need some help with some problems I'm currently facing.
Firstly, does the gear box housing be needed to tighten fully? Cos wen I do tighten it fully, the screws end up producing n jamming the big gear connected which is connected to e pinion.
Secondly, after assembling the gear box... The plastic piece which covers the gears on e outside doesn't seem to fit perfectly leaving gaps(as if warping) which I'm afraid dirt, n sand will enter thus hindering the gears(the pinion n the gear connected to e pinion).
As fr ride height n settings, maybe u experts can advice me on wat setup I should be running as Im a beginner to rc cars World.
Jus FYI, I'm configured to 3 gear mid motor.
Thx guys.
Cheers
Vin
Thx guys.
Cheers
Vin
#5083
Hi guys,
Thx guys.
Cheers
Vin
Thx guys.
Cheers
Vin
#5085
Hi guys,
Thx guys.
Cheers
Vin
Thx guys.
Cheers
Vin
