Like Tree26Likes
Old 03-26-2012, 10:01 AM   #5056
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Hey Guys got a couple of chassis to run this summer in blinky and mod.
People mention the taper pistons, are they ghea or the durango stock ones are taper? Also I am having trouble finding the correct springs around these parts so losi ones work? The rear shocks are shorter so does it affect anything? Those are easy to get actually...
Also had a question about reading the setup sheets. The front trailing axle needs 2 things to setup in the car. The type of part, which is ticked in most sheets and how to install the part. I am not sure how to orient the part though. There is one field in the sheets which says 0mm from front, does that mean say I select the 4mm axle holder and mount it such that the axle is furthest away from the rear wheel (i.e almost inline) ?
Hey Raul
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 03-26-2012, 11:31 AM   #5057
umm winning's Avatar
Originally Posted by TAMAK View Post
Durability is good, better than most cars out there. The only reason Durango cars may seem less durable is because people b*&^ more about parts availability.
I would buy extra rear hubs, gear cover, and shock tower set, other than that i am very happy. Build the stock ball cups right and you should be okay with the tranny camber mount. If you pop alot of ball cups, replace them and have a camber link "Fix" in your tool box.
How does the Durango do on outdoors-high traction, you probably just sold me on getting one now.
umm winning is offline   Reply With Quote
Old 03-26-2012, 03:23 PM   #5058
Trader Rating: 520 (100%+)
Originally Posted by dexon555 View Post
Funny, I did the same thing on the DESC410R, it made the wheel base longer which added stability.
Um, I am really confused, or totally missing something..How did mounting the shocks on the back of the tower increase the wheelbase?
flame56mx is offline   Reply With Quote
Old 03-26-2012, 03:31 PM   #5059
Trader Rating: 19 (100%+)
Without comparing arms side by side, my assumption would be that the offset of the arms is such that running the left or the right and right on the left moves the hub back a bit. No matter for us, still running stock configuration and loving it.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 03-26-2012, 05:00 PM   #5060
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Hey Raul
The kit pistons aren't taper.
This should help with the inserts.
http://www.team-durango.com/blog/201...-insert-guide/
kwiksi is offline   Reply With Quote
Old 03-26-2012, 05:06 PM   #5061
aloksatoor's Avatar
I read that. I am fine building the car with stock specs. I did not understand the team drivers setup sheets before but now I have figured it out I think Thanks for the pistons. I also found springs from stormer hobbies today so can copy few setups!! LHS had none they are discontinuing durango
Old 03-26-2012, 08:16 PM   #5062
Trader Rating: 74 (100%+)
Welcome to the club...
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-26-2012, 09:12 PM   #5063
Ah, I knew I was missing something, for some reason I was thinking about the ZX5-SP when I first saw the pic, and the way they used to move the shocks to the back of the arm..thanks for the clarification...
Old 03-26-2012, 10:57 PM   #5064
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Anyone know if any other brand shock ends work for this car one if mine is split in half.
Also what shims do I need to run the sc10 gear diff.
nolimit208 is offline   Reply With Quote
Old 03-26-2012, 11:01 PM   #5065
WheelNut's Avatar
Send a message via MSN to WheelNut
Bwahahahahahahahaha! Why? Because basher race car. (btw- haven't run these tires yet)
•Brad Comis
WheelNut is offline   Reply With Quote
Old 03-26-2012, 11:26 PM   #5066
aloksatoor's Avatar
wot car ?
Old 03-27-2012, 01:42 AM   #5067
murky123's Avatar
your paint is disrespectfull to Piet Mondriaan
and your tire choice is disrespectfull to Durango.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-27-2012, 03:34 AM   #5068
tobamiester's Avatar
Trader Rating: 278 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
HPIZ892
tobamiester is offline   Reply With Quote
Old 03-27-2012, 05:59 AM   #5069
dexon555's Avatar
Default Shock flip
On the DEXC410R which is what I was talking about, you flip the a-arms over and to allow the shocks to mount backwards, which moves the hubs back, giving a longer wheel base.
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 03-27-2012, 06:52 AM   #5070
Jmuck69's Avatar
+1 I would gone for more of a Jackson Pollock scheme...
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
