Like Tree19Likes
Old 03-25-2012, 11:18 AM   #5041
Trader Rating: 74 (100%+)
Finally, THANKS to Arno(PetitRC.com). You da Man!
http://www.petitrc.com/setup/durango...0323/setup.pdf
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-25-2012, 02:06 PM   #5042
Trader Rating: 520 (100%+)
Nice to see you got it done Raul...Here is a pic or two of mine, finally finished painting it, getting ready for the outdoor season...tips the scales at 1595 grams loaded..
Durango DEX210 Thread-imag0408.jpgDurango DEX210 Thread-imag0410.jpgDurango DEX210 Thread-imag0411.jpg
flame56mx is offline   Reply With Quote
Old 03-25-2012, 02:09 PM   #5043
Attachment 898887Attachment 898888Attachment 898891
Looks good....
Old 03-25-2012, 02:40 PM   #5044
eds24's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to eds24 Send a message via Yahoo to eds24
I really like the front bumper/skid, looks like it obviously works..Did you also make your owns rear ballstud plate, or are you using the Tresrey? I remember your K2 project a year or so ago, that was cool, very "out of the box"...
Thanks.. yeaa the bumper works very well.. no idea why durango doesn't put bumpers on their cars. I'm using the Tresrey rear chamber plate. Thanks.. I found that project to end up being too complicated of a design..when I went to re-design it.. I found my redesign was very similar to the Dex210.. so I decided to get that and do small changes to it.
eds24 is offline   Reply With Quote
Old 03-25-2012, 04:57 PM   #5045
Autocratic's Avatar
Trader Rating: 26 (100%+)
Anyone notice this from the Tresrey Blog? I'm assuming this would work in giving more weight behind the rear axle. Both rear shocks weigh ~40g, so if there is a change, I would think you should feel it.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 03-25-2012, 05:36 PM   #5046
Hmm, that's interesting, man that car is versatile...
Old 03-25-2012, 05:42 PM   #5047
Putting the shocks there should make the car very lazy. Also it wouldn't jump as well. But if the surface is smooth, it would be good.
Old 03-25-2012, 06:03 PM   #5048
Autocratic's Avatar
Well, someone in Japan thinks it works on something well enough to post a picture.
I really think moving the shock weight behind the axle does something.
Old 03-25-2012, 06:12 PM   #5049
So whats better ive seen the car run in rear motor and mid motor on three same track and they both seem to hook up
T3tsaya is offline   Reply With Quote
Old 03-25-2012, 07:13 PM   #5050
eds24's Avatar
I also ran my shocks like that ,but when I ran mid-motor.. with mid-motor the more weight in the back the better.. don't think you can tell much difference in the actual suspension working different.. just the extra traction
I ran mid-motor to try it out on a high traction clay track. It hooked up really well with new tires. But, once the tires wore down a lot or the track was watered in order to change the layout the mid-motor didn't have enough traction.
In my circumstance I need traction with used tires because I can't afford new tires, and I also need to have enough traction even when the track is wet. The other thing is I am running the buggy in 17.5 blinky and I am already 2 oz over the minimum so I couldn't add any weight to the rear to gain traction.
Usually the rule of thumb is if you have enough traction with mid-motor on your track then run mid-motor.. it will handle better and carry more corned speed.
Old 03-25-2012, 07:53 PM   #5051
Originally Posted by niner View Post
Just got the carbon chassis in the mail. The factory Al chasis is 106.7g. 8-Racing carbon fiber chassis is 52.4g
While I'm at it, I also weighted the shock towers. Factory plastic shock towers are 24.2g, Cream front and rear towers are 27.9g. Cream front tower has those Al mounts, which alone weight 8.1g, and make the tower heavier than plastic counterpart.
can you give us a mini review of how you like the 8-racing carbon fiber chassis? how's it alter handling, setup, etc? likes dislikes?
thanks!
slater333 is offline   Reply With Quote
Old 03-26-2012, 05:29 AM   #5052
dexon555's Avatar
Default Shock Flip
Funny, I did the same thing on the DESC410R, it made the wheel base longer which added stability.
CSRCCC -Officer-
Team Durango: DEX410 v.3, DESC410R
KO Propo: EX-10 Eurus w/ Drop Down
Tekin: RS-Pro & Redline 6.5, RX-8 & Pro4 4000kv
Hi-tec: X4/AC Charger
dexon555 is offline   Reply With Quote
Old 03-26-2012, 06:37 AM   #5053
Heavy B's Avatar
Trader Rating: 18 (100%+)
Originally Posted by tobamiester View Post
Thanks man. Same part# I quoted right ?
Close, 98455A108 . Here's a link: http://www.mcmaster.com/#retaining-rings/=gtwlvn
Scroll down to "metric internal retaining clips", then should be first one the list.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 03-26-2012, 07:06 AM   #5054
umm winning's Avatar
Are there still gear box problems? How is the durability? Are there needed upgrades out of the box?
umm winning is offline   Reply With Quote
Old 03-26-2012, 07:27 AM   #5055
TAMAK's Avatar
Trader Rating: 28 (100%+)
Durability is good, better than most cars out there. The only reason Durango cars may seem less durable is because people b*&^ more about parts availability.
I would buy extra rear hubs, gear cover, and shock tower set, other than that i am very happy. Build the stock ball cups right and you should be okay with the tranny camber mount. If you pop alot of ball cups, replace them and have a camber link "Fix" in your tool box.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
