Like Tree24Likes
Old 03-19-2012, 06:05 PM   #4951
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Redwings View Post
Finally got my 210 all put to gether, now just looking for a gearing set up for a 13.5 and a 10.5 motors. now just running the standard kit 87tooth spur gear. I believe taht it is a 48 pitch? show looking for a pinion combe for it.
Paul
I'd like to know what gears peeps are using with the standard 87t spur also.
I have some 75t and 83t on order but want to run my buggy tomorrow.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 03-19-2012, 06:45 PM   #4952
Trader Rating: 74 (100%+)
Try 87/26 for either motor. I run 83/22 for a 7.5.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-19-2012, 06:53 PM   #4953
Trader Rating: 31 (100%+)
IMO I would put the 75 in it, I don't think u will get the 87 to work with the 13.5
Cspurlock is offline   Reply With Quote
Old 03-19-2012, 06:55 PM   #4954
Autocratic's Avatar
Trader Rating: 26 (100%+)
75 is best for 13.5. Anything lower and you should run the 81.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 03-19-2012, 06:57 PM   #4955
EvanAZ's Avatar
Thanks guys, Yea I've tried everything from 21-28 and it just doesn't have the get up and go. I have them on order and hope to have them (69/75/83) this week.
Old 03-20-2012, 07:58 AM   #4956
Default Tresrey rear camber link w/ mod
I received my Tresrey camber link last night. As usual, I went overkill for the install. Instead of mounting the ball stud just on the camber link, I used a HA flange ball, some cone washer and spacers. A longer screw connects the camber link and the original mounting hole on the gearbox. I doubt I will have a problem with the rear link.
niner is offline   Reply With Quote
Old 03-20-2012, 08:15 AM   #4957
Trader Rating: 62 (100%+)
That is a really good idea.
patrick is offline   Reply With Quote
Old 03-20-2012, 08:40 AM   #4958
If you are going to have a choice between the 69 & 75 I would opt for the 69. I am running a 13.5 with a 69 and it gives plenty of room to go up or down on the pinion. The 75 will work, but you will most likely be tight on room to adjust, depending on your track layout.
Old 03-20-2012, 08:53 AM   #4959
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by onekiwi View Post
Whats a good setup someone can recommend for this track
+ YouTube Video
Im now going from MM to RM and won't get a lot of time for warm up and testing things.
The set up Murky used is my set up I've made a couple small changes, mainly springs/oil/pistons. Been doing some light testing when I have time and have my set pretty close to where I want it think. I'll get my set up posted a little later this morning. My local track (sdrcraceway.com) looks quite a bit like yours and several of us run either AKA Rebars or AKA Vektors in front and rear or a combo of both. If you have to run the Rebar rear, I would run the Vektor front if you are allowed a choice. Pretty much all the top guys in 2wd mod at our track all run the Vektor front "backwards". Depending on the rules allowed as far as modifying your rear "spec" tire, making them a smaller diameter like in the post Autocratic posted is a good option to try. One thing about Rebars on a med grip clay track that we have found is that they work best when the pins are worn down about 60-70%. The shorter pins help greatly with traction and keep the tire from being "squishy" feeling. so if you can find a way to wear the tread down before running them (like with a dremel or belt sander), you'll be steps ahead of the competition. On our track, we also use tire sauce like Buggy Grip, Dirt Gripper, TrackStar Gold, or Sticky Kicks Green. Another thing to look at since it looks like you are using the AKA foam as well, is to try and make the foam a little softer...I've been doing some testing with trimming the foam or punching holes in the foam to try and make it a little softer which can help in lower grip situations.
Originally Posted by murky123 View Post
I use this setup http://www.petitrc.com/setup/durango...112/index.html
with a fullsize "heavy" stickpack all the way up in the front it gives good steering and still keeping the rear locked
Awesome!! Glad the set up works for you!
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 03-20-2012, 09:19 AM   #4960
onekiwi's Avatar
Maybe you could PM me the sheet when you get it up.
Ill try and get some vektors but think it might be hard as the reseller in sweden doesn't have them in stock and I think that getting them shipped to be before friday might be tight and expensive.
Can't find them in the UK either
Anything else you could suggest? I may just have to go ribs or maybe scrubs or barcodes what ya think
Ill keep in mind about the softer foams.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 03-20-2012, 09:32 AM   #4961
murky123's Avatar
the sheet is up for grabs at petitrc ( the link I posted ) And I do use the 4 hole 1.2 drilled pistons in the back. but I use 25wt instead of the 22.5 oil
it is a great setup that will get the most out of your dex210 with the stock springs that comes with the kit.
just play a little bit with oil, ride height, and battery placement and its golden
Edit: the AKA vectors are in stock at liquidrc. just 1 dollar shipping across the world
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-20-2012, 09:36 AM   #4962
onekiwi's Avatar
I got the link thanks and the cars set up just wondering what changes he said he has made since it was posted.
I also used 25 in the rear
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 03-20-2012, 09:37 AM   #4963
murky123's Avatar
all credits to you !!
Old 03-20-2012, 09:39 AM   #4964
murky123's Avatar
I think he means these changes
Rear camber link changed to #3
Rear shock piston changed to drilled 4 hole x 1.2mm
Rear shock oil to Losi 22.5
Old 03-20-2012, 11:39 AM   #4965
hopsing's Avatar
Yes, these changes ^^^ plus, I changed the springs to Lt Green Durango fronts, and Lt Red Durango rears (you can use Losi Yellows from the 22 in the rear). In the front I went to 4 hole pistons as well with 30wt losi oil....in the rear I've been testing RC Shox two-stage pistons (6 hole 1.1/1.2 with 22.5wt right now) but the 4 hole set up on my current sheet is good to go. Mount lower front shock mounted outside hole on arm and one other thing is I'm down to a 1mm shim under the ball stud on the inner rear camber link and rear hubs mounted in the middle on the arm. Everything else the same.
Steve Butts
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Doughty, jcr
