Like Tree23Likes
Old 03-13-2012, 03:49 PM   #4861
Whats the amount of shims should I use when using the sc10 diff in mm or inches? I ran it last weekend and I wrecked a idler gear? I run my 210 on carpet this time of year so the gear diff is a must have.
thanks
chet is offline   Reply With Quote
Old 03-13-2012, 03:52 PM   #4862
Autocratic's Avatar
Trader Rating: 26 (100%+)
thanks
HPI Z892.
I used 10 on each side. I had a hair of play side to side which was about the same as the stock ball diff.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 03-13-2012, 07:42 PM   #4863
Trader Rating: 21 (100%+)
What are you guys gearing an 8.5 no boost.... 81 spur
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 03-13-2012, 07:44 PM   #4864
slow_jun's Avatar
Trader Rating: 14 (94%+)
Default DEX 210 T-Bone Bumpers Now on Stock!!
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 03-13-2012, 07:47 PM   #4865
Trader Rating: 74 (100%+)
I'm geared 83/22 w a 7.5.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-14-2012, 12:40 AM   #4866
Redwings's Avatar
Default Springs
I know that this my be an NO NO, but here we go. Will TLR springs fit on the 210 shock bodies?
Redwings is offline   Reply With Quote
Old 03-14-2012, 12:47 AM   #4867
onekiwi's Avatar
yes they fit but the fronts require lots more preload than the 210 ones
Shimming the diff Im a little unsure but idle gears will suffer as I think the ae diff is a different diameter than the stock one so there will always be a risk that youll somke them
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 03-14-2012, 05:54 AM   #4868
TAMAK's Avatar
Trader Rating: 28 (100%+)
I am at 81/23. Jorns Speed Passion setup. 8.5t. I may gear up a tooth though.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-14-2012, 06:01 AM   #4869
Heavy B's Avatar
Trader Rating: 18 (100%+)
I ran 87/25 with an 8.5, but I run a 7.5 now at 87/23.
Raul, is the 83 spur from TD? I haven't heard of that one.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 03-14-2012, 06:28 AM   #4870
MantisWorx's Avatar
Trader Rating: 28 (97%+)
nope, they are exactly the same, been running my AE diff for months now!
MantisWorx is offline   Reply With Quote
Old 03-14-2012, 08:47 AM   #4871
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Anyone have a good Loose dirt outdoor setup, the usual tire setup is Red IFMAR Studs or M3 Calibers in the rear and Red 7202's upfront. Gonna try to keep it RM3 but might try RM4 to gain a little bit more traction
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 03-14-2012, 09:14 AM   #4872
Autocratic's Avatar
Are those the tires that work best for you, or are they what everyone else runs?
I would start back at the kit setup, and adjust your oils for your track's jumps. Also, stock or mod?
IMO:
-RM4
-battery all the way back.
-raise your front and rear roll centers. Start with 1mm f/r
-3rd outer hole on the rear hub
-start -1 camber all around
-slight toe out front
-Hot Bodies Gigabites Pink rear or Proline Holeshots M4
-Longest wheelbase setting on rear hubs
You could also try some more rear toe, but only as a last option if you're still struggling for traction.
Old 03-14-2012, 09:35 AM   #4873
IMO:
-RM4
Sweet, im not far from box stock so it should be easy
Tires are a combo of personal experience/everyone else, when it was really nice I could get away with Green Flip Outs, I am collecting Losi Springs (atm running Orange front/White rear for indoor)
a little vid from last year (it is shared with 1/8th)- http://www.youtube.com/watch?v=QAciMZqtApc
#NoChuck2015
Old 03-15-2012, 02:20 AM   #4874
murky123's Avatar
Default team durango gear diff
I have heard that the gear diff is recalled due to
them being slightly to big for the casing, it fits together ok but when it
swells it cracks the gear casing etc. So they have been redesigned and have
been told they will be in early late next week at durango
anybody ?
Ill guess I will wait for the second batch
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-15-2012, 04:57 AM   #4875
slow_jun's Avatar
anybody ?
hmmm... good thing im using sc10 Gear diff, no problems here.....
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
