Like Tree43Likes
Old 03-10-2012, 10:07 PM   #4801
Trader Rating: 520 (100%+)
Originally Posted by CHIZZLE View Post
Anybody else have issues with the small bearing on the nut side of the slipper assembly? I fried two today!
On that same note, I've become quite fast at removing my tranny. Had it completely out of the car, replaced the bearing and back in ready to go in about 12 minutes.
I replaced mine with avid, but only after I heard some had failures..apparently they changed the size mid stream in some kits if I remember correctly. 12 minutes is amazing CHIZZLE, it took me longer than that to decide if I really wanted to do it or not..lol
flame56mx is offline   Reply With Quote
Old 03-10-2012, 10:29 PM   #4802
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Try changing anti-squat block...painful
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-11-2012, 12:37 AM   #4803
can someone tell me why my preload is slamed down down in front and rear.. is it common or am i just not building my shocks right
tito8167 is offline   Reply With Quote
Old 03-11-2012, 03:41 AM   #4804
hacker's Avatar
Trader Rating: 141 (100%+)
if you dremel/cut out the side pods, changing Anti-squat should be alot easier. Have not done it myself yet. Also easier to make up shims and use 0/3.
hacker is offline   Reply With Quote
Old 03-11-2012, 03:46 AM   #4805
i like carbon
danielxie is offline   Reply With Quote
Old 03-11-2012, 06:51 AM   #4806
Originally Posted by danielxie View Post
i like carbon
That's weird, I was thinking the same thing...
Old 03-11-2012, 07:08 AM   #4807
Jmuck69's Avatar
It needs a shim system like the B4. Use the 0 degree and then use slotted shims that you slide underneath. Simple.
B6D | B64D
Old 03-11-2012, 07:10 AM   #4808
Jmuck69's Avatar
i like carbon
I like cookies.
B6D | B64D
Old 03-11-2012, 07:17 AM   #4809
I like cookies.
Oooh, ok wait, cookies are better than carbon, until the cookies are gone, then it's carbon again..
There are a few things that could be changed..On a positive note though, the front end is a dream to wrench on, I have never owned a car that removing or changing out a servo was so easy..Kudos on that design..I hope every other manufacturer copies that..
Old 03-11-2012, 09:39 AM   #4810
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Lol, yeah a power screwdriver is the key. I replaced mine the first time with an Avid but it still happened after two packs. I think I'm getting some binding when I snug down the 3 screws that hold the motor plate which is putting too much pressure on that little bearing. I might try shaving a bit off the layshaft spacer and see if it frees it up a bit.
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 03-11-2012, 09:56 AM   #4811
murky123's Avatar
Guys, what is the best looking carbon rear shock tower? Broke the stock rear tower today, and ready to upgrade.
Oh, and I keep pulling out the ballstuds on the rear hubs while running the car. Im using longer ballstuds now and use a locknut on the back of the hub.
Anybody ele having this?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-11-2012, 10:32 AM   #4812
Jmuck69's Avatar
I love my 210. I think the rear can be simplified a bit. The transmission is very nice. It's the the rear brace that is overly complicated. I am very pleased with mine.
B6D | B64D
Old 03-11-2012, 11:03 AM   #4813
anybody???
Old 03-11-2012, 11:14 AM   #4814
CHIZZLE's Avatar
anybody???
What springs are you running? Shorty pack or full size? Position of the battery? Mid motor? Rear motor? Although I have no idea if you're building your shocks correctly, internally, the springs are the only thing holding your car up. Where the preload collars are placed determines your ride height. Pistons and oil have nothing to do with preload collars.
Chance Renstrom
Old 03-11-2012, 11:17 AM   #4815
anybody???
Thats going to be a hard question to answer from this side of the screen. Really need to see it and feel the shocks to be able to diagnose it. I have seen the piston screws back out, too thick of oil, wrongs pistons etc..Disassembling it will be the only way..
St Ives RC Club B4Bandit Australian Racing 16580 Today 03:10 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
