Like Tree23Likes
Old 02-29-2012, 05:42 PM   #4636
that esc is designed for pan cars. if you run it in offroad its gonna burn up.
Originally Posted by Redwings View Post
I decided to go with hobbyking. Never heard of this product so I decided to gothere is the other guy. not bad for $67.00
http://www.hobbyking.com/hobbyking/s..._Car_ESC_.html
cm.stites is offline   Reply With Quote
Old 02-29-2012, 05:49 PM   #4637
eds24's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to eds24 Send a message via Yahoo to eds24
I would have to disagree.. I haven't run that esc.. but it is rated at 120a.. 2s 1/10th offroad down to 6.5T...
As long as he uses the heatsink/fan if using a mod motor he should be just fine..
good luck!
eds24 is offline   Reply With Quote
Old 02-29-2012, 06:01 PM   #4638
its a copy of the hobbywing 1s which is designed for 10th pan car and 12th scale wgt.and is designed more for 1 cell racing without the need for a booster. he can run it but why save 20 bucks or so to step up to a better esc if your gonna eventually have to replace a 67$ esc. the hobbyking 100 amp is a much more suitable suggestion http://www.hobbyking.com/hobbyking/s...ESC_1_10_.html .. theres a reason hobbywing/speed passion and a few other brands dont recommend using that esc for offroad.
or even this 120 amp http://www.hobbyking.com/hobbyking/s..._Car_ESC_.html
Old 02-29-2012, 06:22 PM   #4639
eds24's Avatar
Yes, it is designed to allow for the use of 1s without a voltage booster but, it can handle 2s perfectly fine. I haven't heard anything from Hobbywing or Speed Passion about not using that esc in off road applications.. what matters is how many amps it can handle. 120a is 120a wither its in a 1s esc or a 2s-3s. The specifications posted on that esc, as well as on the hobbywing 1s esc state that it can be used in a off road car with 2s down to a 5.5T or 6.5T motor . That esc is more than capable of being run in a Dex210.. as far as the reliability of that company I don't know.
I personally would recommend a Hobbywing esc.
Old 02-29-2012, 07:22 PM   #4640
Redwings's Avatar
the only reason i went with the hobbyking was because of the size. the hobbywing was too big for the Durango 210> also there is thee specs on the hobbyking esc.
The Turnigy TrackStar One Cell 1/12th and 1/10th scale ESC is the latest addition to Hobby Kings Sensored Car ESC range.
The TrackStar One Cell features a built in voltage booster for single cell Lipoly use in 1/12th and 1/10th scale racing. An additional heat sink and cooling fan have been included for 2S 1/10th race applications making the TrackStar One Cell a truly versatile ESC.
Using a Fast Silicon Labs MCU and high quality On-Semiconductor MOSFETs the TrackStar One Cell 120A ESC sets a new standard in high quality yet affordable car ESCs. With Intelligent MCU logic the TrackStar series ESCs allow extremely precise start up control and positioning feed back from the motor. This translates in to very smooth start up and acceleration.
Timing Indicator LED.
To conform with ROARs Sportsman Class racing rules and assist race organizers monitor driver compliance in non-timing modified race classes the TrackStar 1/10th ESC includes a timing mode indicator LED. At all times when the ESC is powered on and dynamic motor timing is set to a value greater than zero the white LED will illuminate indicating that the timing mode has been modified.
The Turnigy TrackStar One Cell 120A ESC also boasts a host of programing options not usually found in an ESC at this price and can be programmed with ease via the Turnigy TrackStar programing card (sold separately).
Specification:
Cont. Current: 120A
Burst Current: 200A
Motor Rotation: Fwd/Rev or Fwd/Brk
Input Power (Cells): 1-2S LiPo/LiFe, 3-6 NiMH (8.4V Max)
Motor Type: Sensored and sensorless Brushless Motors.
BEC Output: 6.0V, 1Amp, Built-in BEC with DC booster for 1 cell LiPo use.
Status LED (2 LEDs): White LED, 3 color LED (Red, Green & Orange)
Thermal Overload Protection: Yes
Dimensions (L*W*H/without fan): 36.5*42*18mm (1.44*1.65*0.71in)
Weight(Without wires): 34g (1.20oz)
Motor Limits
1S LiPo or 3-4S NiMH): ≥3.5T (1/12 on- road)
2S LiPo or 5-6S NiMH): ≥4.5T (1/10 on-road) ≥6.5T (1/10 off-road) *
Programming Options (Via Optional programming card or Throttle input)
Brake/Reverse type
Brake amount
Reverse amount
Punch Control
Drag Brake
Throttle Dead Band
Voltage Cut off
Motor Timing
Note: * 2S Lipoly use requires installation of the supplied heat sink and fan.
Redwings is offline   Reply With Quote
Old 02-29-2012, 07:28 PM   #4641
MantisWorx's Avatar
Trader Rating: 28 (97%+)
good luck!
I have been running this Esc on my 210 for a month now with no fan and a boosted 8.5 with absolutely no issues at all, I also run it on my DESC boosted with a pro4 4000kv also without any issues. Its rated at 120a!! It only specifies 1s because of the booster, everything else is the same! Fan not needed on the 2wd.
MantisWorx is offline   Reply With Quote
Old 02-29-2012, 09:08 PM   #4642
eds24's Avatar
Awesome to here that! The specs just said he needs to use a fan and a heatsink..so that's what I recommended if he is useing a modified motor since I haven't run that esc. Awesome to know he doesn't need it though! Thanks for the input.
Old 03-01-2012, 02:10 AM   #4643
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Are you talking about the Hobbywing 60A/120A? I fit one in my 210 without trouble.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 03-01-2012, 05:26 AM   #4644
Got some new Tresrey parts today.
igyrigged is offline   Reply With Quote
Old 03-01-2012, 05:33 AM   #4645
Matt Howard's Avatar
oooh, the chassis is nice I wonder how much $$$?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-01-2012, 05:40 AM   #4646
Redwings's Avatar
probably cheaper before it hits the US anyway. But very nice.
Old 03-01-2012, 05:50 AM   #4647
forty6's Avatar
9,240.00 JPY = 113.815 USD
Made in Germany by 8-Racing.
forty6 is offline   Reply With Quote
Old 03-01-2012, 05:55 AM   #4648
spiro's Avatar
Originally Posted by onekiwi View Post
Who does?? Norwegians are dodgy
I'd expect that comment from just about any guy here, but coming from the New Swedland dude...
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 03-01-2012, 05:56 AM   #4649
About $110 with the yen conversion.
Old 03-01-2012, 06:17 AM   #4650
murky123's Avatar
how much does your dex210 weigh ?
mine is 1550 grams with wheels and without battery
So race ready with fullsize stickpack is over 1750 grams
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
EbbTide
