Like Tree17Likes
Old 10-05-2011, 10:06 AM   #451
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by FRONTI3R View Post
The end points were always set on my Cougar before I used it, yet I still broke the servo gears on certain hits or crashes.
Almost NO one else breaks the servo gears on their Cougar... I'm thinking the low profile servo is weaker and is why I kept breaking the gears.
I would agree that the servo horn should strip before the gears breaking... but it NEVER did when I had the low profile servo.
Just saying... it wasn't due to USER error as you are implying.
Well, its all user error really. Dont hit anything. . Also a plastic servo horn should be used in that case. cheaper to replace those.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 10-05-2011, 10:11 AM   #452
Jmuck69's Avatar
Originally Posted by Atomicsickness View Post
We can only hope
Ha!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-05-2011, 11:18 AM   #453
murky123's Avatar
Sorry.. if I have upset you. I also run low profile savox servos. and others like the Ace ds1015
Never felt the need of any servo saver in all sorts of trucks I run. and when a truck has a servo saver I tighten it as much as I can.
Even in my SC10 4x4 I tighten the servosaver to a lockup.
you want fast and responsive steering, and a servosaver takes away a bit of that fast and responsive steering. that is my thought about a servosaver.
best servo saver is a plastic servo horn
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 10-05-2011, 11:25 AM   #454
Mike Marshall's Avatar
The AE and Kyosho guys at our track glue the servo saver closed.
Blaze RC / Smac Trac / St. Louis Dirt Burners
Mike Marshall is offline   Reply With Quote
Old 10-05-2011, 11:43 AM   #455
FRONTI3R's Avatar
Don't worry about it... I wasn't upset... just trying to say that I knew all that already. lol But I'm sure it was good info for others.
BTW. I was running the stock plastic servo horn, not an aluminum one.
And I agree with you about not running a servo saver is better for responsive steering.
I didn't want a servo saver either... for those exact same reason you just mentioned... but when it breaks 5 times on you... you don't really have a choice but to add a servo saver now do you?
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 10-05-2011, 11:48 AM   #456
aloksatoor's Avatar
Trader Rating: 42 (100%+)
did you shim the ball stud or you were using factory servo horns? it might be putting strain on teh gearing which its not designed to handle.... I get away with the 1257 savox which is only 10 oz less than the low pro savox servo and never broken gearing...
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 10-05-2011, 01:51 PM   #457
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Somebody help me out here.. it was my understanding that 3gear/Rear motor makes the spin of the motor put energy downward, improving rear traction on throttle... so why does TD say that 4gear/Rear motor is for very low traction? wouldn't it reduce rear traction on throttle, or is something backwards in my understanding?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-05-2011, 01:55 PM   #458
Jmuck69's Avatar
The way i interpret it is the motor rotation would force the whole chassis down vs just forcing the rear down. of course I could be entirely wrong.
B6D | B64D
Old 10-05-2011, 02:05 PM   #459
TAMAK's Avatar
Whys the sky blue? Why are trees green? How does a posi trac work on a Plymouth?? IT JUST DOES!!!!
Yeah, I was wondering the same
Old 10-05-2011, 02:38 PM   #460
Racing089's Avatar
no matter what you do all the centrifugal mass is centered in the same place. There really is no advantage either way in my opinion.
Racing089 is offline   Reply With Quote
Old 10-05-2011, 02:41 PM   #461
ABBOTT's Avatar
Looks to me that a full size will work in the 210 why go with a low pro if its not needed? They all suck IMO really weak for my taste. I do run use a 300 once without a saver in the 410 so maybe I get a little carried away.
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 10-05-2011, 02:51 PM   #462
Trader Rating: 19 (100%+)
Rather than thinking of the rotation as upward or downward, think of it as forward or rearward. With that in mind, a 4 gear rear-motor configuration will spin rearward and will transfer more weight to the rear wheels. This had been my theory since it was announced that the car would offer this type of adjustment- now with TD's explanation on the site I am more convinced of this. Looking forward to trying it out on Cush's buggy.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-05-2011, 03:21 PM   #463
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Losi Associated parts house said mine should be in the mail next week .
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 10-05-2011, 03:25 PM   #464
Super Moderator
I don't think were discussing mass... but ok...
- RCSpecialties -
Old 10-05-2011, 03:37 PM   #465
A motor turning at 20,000+ rpms. ya it matters which way its turning. Xfactory has been using 4 gear tranny for a few years now.
Lendel Smith
SikKustomz is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Yesterday 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
