Like Tree26Likes
Old 02-27-2012, 03:43 PM   #4606
ChadRacing's Avatar
Hello, I am about to purchase this buggy and was wondering what spring kits can i use so I can have a variety of choices from the start?
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 02-27-2012, 04:24 PM   #4607
Autocratic's Avatar
Trader Rating: 26 (100%+)
Your best bet is to order the single spring sets that are still in stock at a few online retailers, and then fill in the gaps with the Losi Big Bore springs.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-27-2012, 04:38 PM   #4608
rcman182006's Avatar
Send a message via Yahoo to rcman182006
I'm running 1.2 4 hole pistons all the way around with Losi Orange/ Durango Light Blue(since Losi Whites are a hot commodity) Losi 25 wt front/ 20 rear
Sweeps Tendr0ids blue compund rear, AKA super soft Vectors up front
Just waiting on my new Finnisher body
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 02-27-2012, 04:42 PM   #4609
Autocratic's Avatar
Looks good. I really love my Vector fronts.
Old 02-27-2012, 05:48 PM   #4610
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Lovin the old school tekin sticker on the wing!!
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 02-27-2012, 06:08 PM   #4611
Thanks!
I've got almost whole sheets of them in green and Orange, I need more of the black and white ones though
#NoChuck2015
Old 02-27-2012, 06:10 PM   #4612
Autocratic's Avatar
Few things I want to put out there:
Tested some tapered pistons this weekend. Front - 4 hole 1.3, rear - 4 hole 1.2, 30/20 oil. Previous setup was the same, except for the tapered pistons. Same size and number of holes.
Car felt slightly better in the triple "bump" section of my LHS track. Suspension seemed to work faster in getting the tires to contact the track better. Jumps & overall performance felt better as well.
For those running the Lunsford kit., are you finding that you don't have enough threads on the rear turnuckles? With the kit 2" length, using the 3rd outer hole on the hubs doesn't seem to leave a lot left. I ripped the turnbuckle out from the ballcup the other day. I bought the next length up from my LHS (2.25") and ordered a few sets of the 4.8mm cups.
Also, anyone interested in piecing together a full Titanium screw set, it's going to be expensive. I went back and followed the kit & checked the parts list in the manual. I had to order from Lunsford & Acer Racing to find most of them.
The only ones I couldn't find in Ti were button heads over 30mm length and M2 screws.
Side note, new Proline Square Fuzzies are pretty awesome. M4 compound really makes them worth it. I ran two 6min. heats this weekend and show no sign of wear at all. Still have slight molding excess material on the tread.
Old 02-28-2012, 07:39 AM   #4613
Trader Rating: 45 (100%+)
What's a good pinion to start off with for an 8.5, stock spur, and 80 foot straight on the DEX210? Just need a good starting point.
Apex is offline   Reply With Quote
Old 02-28-2012, 08:53 AM   #4614
MantisWorx's Avatar
Trader Rating: 28 (97%+)
A little off subject but Ryan Lutz wins the nitro challenge with RCshox 2 stage pistons!! Once we get the SC ironed out we will move to the 210!
He ran 4 hole 1.1/1.2 with 450/250cst!
http://www.youtube.com/watch?v=8jhSM...ayer_embedded#!
More news! Bugle boy bodies are in stock and they are making gearbox covers that wrap around the motor plate!! As soon as they are done I am going to import a bunch of them.
http://rcshox.com/shoxshop/catalog/
MantisWorx is offline   Reply With Quote
Old 02-28-2012, 09:08 AM   #4615
Default turnbuckle length
I'm going to start my build tonight. I went through the instruction manual online and printed version, and found a difference between them.
If I follow the online manual, all the camber links and steering links will be longer than the printed manual. Following are distance between ball cup:
Front camber links: 19.5mm vs 18mm
Steering links: 20mm vs 19.5mm
Rear camber links: 12.5mm vs 10mm
Any idea which instruction I should follow for the initial build?
niner is offline   Reply With Quote
Old 02-28-2012, 09:12 AM   #4616
Use the one online.
Old 02-28-2012, 10:21 AM   #4617
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
Link lengths are irrelevant until you put them on the car itself. That's when you'll adjust cambers and toe.
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 02-28-2012, 10:26 AM   #4618
CHIZZLE's Avatar
nevermind, my bad
Chance Renstrom
Old 02-28-2012, 11:00 AM   #4619
Default Diff Rings
Originally Posted by Cspurlock View Post
I can confirm that the person that tried the kyosho diff plates used the ones from the rb5 and they did not work. Inner hole is a different size.
If anyone comes across a diff plate that crosses over from another brand, please share with the group.
I found that RCLazy (with dot com) has their Durango & Tresrey stuff on Clearance. It's overseas for us in the US, but they had a small assortment, including diff rings, when I looked last weekend. They must not have a great amount of confidence in Durango when they've got it on clearance. Durango needs to get this parts & supply thing fixed.
jpeck is offline   Reply With Quote
Old 02-28-2012, 05:11 PM   #4620
forty6's Avatar
Originally Posted by jpeck View Post
........ Durango needs to get this parts & supply thing fixed.
I think it's a shame really. I gave up after I found a spare gearbox but no kits to be found. Maybe down the road, when parts availability gets sorted out.
forty6 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
