Like Tree23Likes
Old 02-25-2012, 08:48 AM   #4591
Trader Rating: 74 (100%+)
Originally Posted by jurquhart View Post
anyone know when they will be releasing the gear diff? I haven't been having much luck with the ball diff
Funny, I have had nothing but problems with my gear diff..
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-25-2012, 09:01 AM   #4592
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Ok, dumb question. I just got my SC10 gear diff yesterday and have had zero time to look at the SC10 thread. The instructions show assembly with grease. If I am using silicone diff fluid, do I use only silicone or do I use some grease as well. Thanks guys
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 02-25-2012, 01:13 PM   #4593
onekiwi's Avatar
The SC10 diff is 1mm smaller so be careful you may strip the idle gears
Grease/green slime for the orings and to help slide it all together
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 02-25-2012, 01:40 PM   #4594
Moderator
Posvar's Avatar
Thanks! I did not know it was smaller. I am running 10.5 with very little boost.
I heard it was a perfect direct fit but I guess I will find out.
Thanks for the tips.
Old 02-25-2012, 01:56 PM   #4595
Dog Runner's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to Dog Runner
The associated gear diff works fine, even if a tad smaller in diameter. Note that the "valley" of the teeth on one side of the diff gear does not go down as far as the "valley" of the other side. Because of this, you will likely have to shim it to one side to make sure the diff gear and idler gear mesh correctly. It seems to me that if you put the side of the gear diff with the screws facing the driver's side of the buggy, it seems to fit/mesh better. 2,000 weight associated oil is a good place to start.
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 02-25-2012, 04:51 PM   #4596
Autocratic's Avatar
Trader Rating: 26 (100%+)
SC10 diff works fine. Take an exactoknife and cut the ridge on the teeth. 10 HPI Z892 shims on each side and it should be perfect.
FYI, the SC10 diff is really noisy; atleast mine was.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-25-2012, 06:48 PM   #4597
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by Matt Howard View Post
schumacher sells some, I've got them on my ride and they look trick with the other gold parts.
Are these the ones and do they work all around
These ones?
see the others now those ones were the first to pop up. see they have a few diff lengths
nolimit208 is offline   Reply With Quote
Old 02-25-2012, 07:33 PM   #4598
Matt Howard's Avatar
These ones?
Those are the ones, just match up the lengths in the manual for the ones listed. If I remember right they were within 1-2mm of each other, the lengths weren't exact but they work fine.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-25-2012, 07:56 PM   #4599
Are those steel or aluminum?
niner is offline   Reply With Quote
Old 02-26-2012, 10:13 AM   #4600
Trader Rating: 31 (100%+)
Originally Posted by Posvar View Post
^^^I heard of some one using Kyosho but can not validate that.
I can confirm that the person that tried the kyosho diff plates used the ones from the rb5 and they did not work. Inner hole is a different size.
If anyone comes across a diff plate that crosses over from another brand, please share with the group.
Cspurlock is offline   Reply With Quote
Old 02-26-2012, 10:16 AM   #4601
onekiwi's Avatar
Why not just use the original?
And you guys runnig the sc10 diff are you running mod or stock?
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 02-26-2012, 11:14 AM   #4602
they're steel, I only got 'em for the bling factor. I'm sure the stock turnbuckles are just fine, I just wanted gold ones
RCTech #361
Old 02-26-2012, 11:20 AM   #4603
because they are not available, out of stock everywhere in US.
Old 02-26-2012, 11:44 AM   #4604
triplesix's Avatar
I'm running mod (7.5T) on an indoor carpet track. The SC10 gear diff works like a charm
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 02-26-2012, 07:11 PM   #4605
anyone tearing up the outdrives my outdrive on the nut side is all messed up
SHAUN GRIDER is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
