Like Tree23Likes
Old 02-23-2012, 07:46 AM   #4561
Glowster21's Avatar
Trader Rating: 116 (100%+)
Originally Posted by littlejohn View Post
sure it will.. just take the fan off. You won't need it in the 210.
If you're talking about the Mamba Max Pro it's the sensored version and the fan is in a removable case which is why the fan plug is external, so you can remove it as its not needed in 2wd. If its the older Mamba Max non sensored unit then it's a bit more work to get the fan out.
Glowster21 is offline   Reply With Quote
Old 02-23-2012, 08:48 AM   #4562
Heavy B's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Cspurlock View Post
Was wondering if the guys running on med traction indoor clay can tell me the following on their setup:
Rear toe
Kickup
Mm spacer under ball stud of front hub
Just curious to see what everyone is running
I am running 3, 1.5, 6
I am running 3, 3, 2. I'm thinking of bumping up to 3 or 4 on the front. I get a little too much with tapers and not enough with scrubs with 2mm. Is it a handful with 1.5mm anti-squat (kick-up)?
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 02-23-2012, 08:52 AM   #4563
Trader Rating: 31 (100%+)
yes until you put the 6mm in, then it calms it down.
Cspurlock is offline   Reply With Quote
Old 02-23-2012, 09:40 AM   #4564
Heavy B's Avatar
I saw some of 22's running that much up front. My track is indoor clay as well. This is the first year, so we are still guessing on a lot of things. Right now the track temps are ranging from 25-35 deg F, so even though it should be high bite it gets a little slick. I think I've got the front dampening pretty close, but still uncertain on the rear. It's a big 1/8th scale type layout. Last week I tried 4x1.2 with 27.5, 3 upper & 2 lower, dk green springs. Next time, I'm dropping to 22.5 and moving the lower to 3.
Brian Bernt
Old 02-23-2012, 11:05 AM   #4565
sounds like our track is similar other than the temp. I am 4x1.2 with 25, 3 upper and lower with dk blue springs. works good, but track is smooth with no really big jumps.
Old 02-23-2012, 07:33 PM   #4566
Autocratic's Avatar
Trader Rating: 26 (100%+)
Saw these today:
http://tresreyusa.blogspot.com/2012/...l#comment-form
Can't tell if these are to add toe, or remove it, or change to the number on the block. They mention having +2 blocks in, but does that add 2 degrees, remove it, or change to 2 degrees assuming 0 inserts?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-23-2012, 07:45 PM   #4567
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by Autocratic View Post
Saw these today:
+ would mean adding toe.
hacker is offline   Reply With Quote
Old 02-23-2012, 07:49 PM   #4568
Autocratic's Avatar
That's what I was leaning towards. However them mentioning +2 blocks just seems like alot of toe.
Old 02-23-2012, 07:53 PM   #4569
hacker's Avatar
well going by the pics above which you have found, they would be 3.5 and 4.0 degrees toe in, wouldn't it, as the standard ones have 3 degrees toe.
and yes the +2degree is extreme
Old 02-23-2012, 08:35 PM   #4570
Jmuck69's Avatar
Wouldn't this defeat the purpose of the inserts? To change one of these would take a while since you have to remove the motor plate.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-23-2012, 10:46 PM   #4571
murky123's Avatar
you guys know any gold turnbuckles I could use? to pimp my camber/steering links ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-23-2012, 11:36 PM   #4572
Mopar's Avatar
My guess would be + refers to positive (naturally) and the number is total toe, not added toe. These would be for use with the toe inserts in the hub carrier. Removing toe at the arm mounts and adding it back in the hubs would increase the wheelbase if you don't change the arm spacing. The Cougars a ways back used this arrangement somethimes.
Mopar is offline   Reply With Quote
Old 02-24-2012, 03:10 AM   #4573
KyoshoShawn's Avatar
Default Momba max pro
The mmp fits snug in my 210. It is all i run. My sens wire comes out the back. And i took my dremel with a 1/4" drum and shaved a little off the left front corner of the pod. Picks will be available if needed. Works perfect and has not come out yet.
Zx5 FS2 SP NCG Edition. R10 Powered. Rt5
Rb5SP2. Orion & Castle Creations ESC's
Ultima SC-R. Orion & Novac motors
MP9Tki2WC. MP9e. Orion & Savox servos. Kal-Gard Lubricants
Team Terribles Byron Fuel OS Speed engines
KyoshoShawn is offline   Reply With Quote
Old 02-24-2012, 05:11 AM   #4574
Tunatsol's Avatar
What size is the inner bearing on the lay shaft. I've gone through two from boca and 1 of the original. Make any suggestions?
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 02-24-2012, 06:31 AM   #4575
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
sounds as if you need to shave a little off the top shaft spacer.Going through that many bearings there has to be a reason, and i know with mine when I went to do the tranny Mine needed a little shave to get everything to spin nice and free..I ended up taking about .005" off the length of the top shaft spacer to get her freed up..
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
