Like Tree26Likes
Old 02-21-2012, 09:37 PM   #4546
The Juice's Avatar
Trader Rating: 25 (100%+)
Originally Posted by nickypoo View Post
before i bite the bullet, is anyone running a mamba max pro in their buggy?
its the only sensored esc i have and ill run a 10.5 with it
Dont think that esc will fit in there.
Tim M.
The Juice is offline   Reply With Quote
Old 02-21-2012, 09:53 PM   #4547
Trader Rating: 19 (100%+)
Originally Posted by Cpt.America View Post
What you want then, is more pack, not less. Pack is only intrudced when shaft speed reaches a certain point (like landings). So it is possible to create more pack for the hard landings, without changing how the damping feels elsewhere on the track. You increase pack by decreasing the hole sizes in your piston, and running a lighter oil to compensate.
So for example, if you are running 4 hole 1.3 in the back with 27 weight oil, switch to a 4 hole 1.2 and run 25 or 22 instead. The overall slow pulse damping will be about the same, but pack will be higher, helping the car land.
If you go to a larger hole, the bottoming out issue (even if you go with a thicker oil) will only get worse.
We're on the same page, I think. The 4x1.2 was too much pack in the mod buggy, the 6x1.2 is not enough. I rarely get dedicated test days with Cush, so I usually setup a few different things to try and work on in the few hours we have before racing starts, but if he doesn't like the changes we just revert to his base setup with 6 hole pistons all around. He's usually fast enough with it to make the A and run up front, but once we find the balance between too much and not enough pack I think the car will be even easier for him to drive fast with confidence. Hence, I pondered making some 5 hole pistons and inquired about Raul's experience with 3 and 4 hole pistons with larger holes. I would expect a 4 hole piston, even with holes as large as Raul mentioned to have more pack than the 6 hole 1.2 pistons. Simple math says there is less area for the oil to travel through.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 02-21-2012, 11:20 PM   #4548
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It will have slightly more pack with the 4 hole, but not because of the area for the oil to travel through, but because you will run lighter oil with 4 holes than 6 to keep the same static damping... and lighter oil tends to pack more easily than thinker oil.
I think what you are looking for, is something like a 6 hole 1.1, with very light oil... maybe 20 or 25 (not sure.. just tossing it out of my head, i would subtract between 2.5 and 5 from what you are running now, with the 6 hole 1.2). That will give you the same static damping as the 6 hole 1.2, but more pack.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-22-2012, 04:38 AM   #4549
Trader Rating: 21 (100%+)
I didn't like the 5 hole pistons and went back to 1.2 4 hole......just seems more balanced. I run on high to med clay with losi 25/20
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 02-22-2012, 06:36 AM   #4550
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
I can't tell if I learned something today or my head has just been filled with more B.S., lol.
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 02-22-2012, 06:42 AM   #4551
TAMAK's Avatar
Trader Rating: 28 (100%+)
Thats where i'm at right now as well. I like it however, I think my new weight plate replacement for the plastic TD piece will make the car more balanced.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 02-22-2012, 07:32 AM   #4552
jurquhart's Avatar
Trader Rating: 22 (100%+)
I just tried to put the mamba max pro in the buggy and it did not fit. I had the esc and was trying to use it while I sent my RS in for service, but now I will just have to wait
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 02-22-2012, 07:52 AM   #4553
ohdeeuhm's Avatar
Trader Rating: 18 (100%+)
Originally Posted by slow_jun View Post
works great, less maintenance and more run time between runs.... using mine and no issue here...
Awesome, I went ahead and ordered it while I was picking up tires and parts.
Ahh, bummer. I had one laying around so I figured I would use it in the 210. Guess not lol.
www.advrider.com
Riverside RC Raceway -- Petal, MS
Braaaaaaaaaaaap!
ohdeeuhm is offline   Reply With Quote
Old 02-22-2012, 09:15 PM   #4554
Trader Rating: 31 (100%+)
Default Setup
Was wondering if the guys running on med traction indoor clay can tell me the following on their setup:
Rear toe
Kickup
Mm spacer under ball stud of front hub
Just curious to see what everyone is running
I am running 3, 1.5, 6
Cspurlock is offline   Reply With Quote
Old 02-23-2012, 01:57 AM   #4555
littlejohn's Avatar
sure it will.. just take the fan off. You won't need it in the 210.
http://sydneyrc.com/entries.php
Sydney|RCCC
littlejohn is offline   Reply With Quote
Old 02-23-2012, 02:33 AM   #4556
The Juice's Avatar
Width is more the issue.
Tim M.
Old 02-23-2012, 03:24 AM   #4557
murky123's Avatar
then you would have to destroy the whole case of the speedo.
MMP has the fan integrated in the casing
my opinion :
an MMP is nice for bashing but not for a race buggy
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-23-2012, 04:24 AM   #4558
joelwhite's Avatar
Trader Rating: 55 (100%+)
my opinion :
The fan is removable.
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 02-23-2012, 06:46 AM   #4559
murky123's Avatar
maybe with a dremel
http://traxxas.com/forums/showthread...g-fan-from-MMP
Old 02-23-2012, 06:51 AM   #4560
direct from castle
http://www.castlecreations.com/suppo...x_pro_case.pdf
cm.stites is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16569 Yesterday 10:02 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
