Like Tree23Likes
Old 02-21-2012, 07:19 AM   #4531
murky123's Avatar
Originally Posted by Jonny5 View Post
Actually stock/mod does make a difference. The faster speeds of mod class increase the shaft speed considerably and can make the rear end pack up harder than stock. My buggy feels great with 4 hole pistons but Cush's buggy is bouncy off of fast jump landings. We keep trying different 4 hole combinations on his and keep reverting back to 6 holes. Next up is a set of blanks drilled to 5 hole 1.2 and another set at 5 hole 1.3. His car drives very well but needs more pack, but 4 holes have been too much pack for his car and our track.
Ahhhh this is good info. keep me posted if you can.
I cant test different pistons at this moment due to bad weather.
But I can use your info very well
so you are saying that the faster mod buggy will like 6 or 5 holes better than 4 holes ? due to the higher speeds and rear end packing up ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-21-2012, 08:11 AM   #4532
Trader Rating: 19 (100%+)
That's what we found for our particular track. It's all relative to what you're running on, but the shaft speed of the shock is faster off the same jumps between my stock and Cush's mod buggy, or at least that's what I have concluded after trying identical setups on both cars. My car is marginally lighter than his due to different escs, but really should not be enough for the drastic difference in jumping we have seen. We won't be out again til this weekend, but I'll post up what we find.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 02-21-2012, 09:26 AM   #4533
Trader Rating: 74 (100%+)
I've been playing with 1.5 3 hole, and 1.5 4 hole pistons. They are definetly softer.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-21-2012, 09:54 AM   #4534
Are you bottoming much? I know that bottoming is expected and unavoidable in certain situations, but his car bottoms even on smooth downside landings, so that is what we are trying to tune out. We are trying to do this though without compromising the handling elsewhere on the track though as it does everything else very well. I hadn't considered larger holes in the 4 hole pistons, but as easy as it is it looks like we have more stuff to try.
Old 02-21-2012, 10:01 AM   #4535
MikeFriery's Avatar
Have you tried laying the rear shock down? We were having alot of the same problems, but since switching to 3-1 mounting with 4 hole 1.3's w / Losi 20 wt, TLR pink spring, have been pretty happy with the result.
Droop screw all the way out, shock-end unscrewed 1 turn
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 02-21-2012, 11:03 AM   #4536
Autocratic's Avatar
Trader Rating: 26 (100%+)
Im gonna try this !!
doesnt really matter if you run 17,5 blinky or a 8.5 turn regarding springs and oil right?
your description of your track sounds a lot like mine.
I do not have huge jumps, not to technical but can be quite high speed.
low/med clay/dirt out doors
My track has jumps, but I wouldn't consider them to be technical. The only real technical part is making sure you're setup on the correct line coming off the 3rd table top.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-21-2012, 12:07 PM   #4537
ohdeeuhm's Avatar
Trader Rating: 18 (100%+)
Just picked up my 210 today after much debate. I saw a post a few pages back about using a 2WD sc10 diff and HPI shims and I was wondering if anyone else has tried this setup. I run on a medium/loose outdoor track and gear diffs just seem to work better for me.
I wish TD would get on the ball and get the parts stock back up to par. I almost ordered the 22 because of the parts support but I've been drooling over the 201 for quite some time.
www.advrider.com
Riverside RC Raceway -- Petal, MS
Braaaaaaaaaaaap!
ohdeeuhm is offline   Reply With Quote
Old 02-21-2012, 01:27 PM   #4538
goBezerk's Avatar
Send a message via Skype™ to goBezerk
FWIW, our track is "very" rough with big jumps and I tried both 4 and 6 hole pistons, 6 too little pack and 4 too much. So I made some simple flap valves to put on top of the pistons, so 5 hole compression, 6 hole rebound...they work a treat
► Paul Sims - KRCORCC - BRCCC - TFTR
► R/C racin', 1 percent car, 99 percent driver
► BEZERK RC on Facebook, PayPal accepted
► PROLINE - TEAM AE - GFORCE - R/C Race Supplies
goBezerk is offline   Reply With Quote
Old 02-21-2012, 01:36 PM   #4539
any pictures?
cm.stites is offline   Reply With Quote
Old 02-21-2012, 03:11 PM   #4540
goBezerk's Avatar
Something like this...
Originally Posted by cm.stites View Post
any pictures?
Old 02-21-2012, 04:25 PM   #4541
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
What you want then, is more pack, not less. Pack is only intrudced when shaft speed reaches a certain point (like landings). So it is possible to create more pack for the hard landings, without changing how the damping feels elsewhere on the track. You increase pack by decreasing the hole sizes in your piston, and running a lighter oil to compensate.
So for example, if you are running 4 hole 1.3 in the back with 27 weight oil, switch to a 4 hole 1.2 and run 25 or 22 instead. The overall slow pulse damping will be about the same, but pack will be higher, helping the car land.
If you go to a larger hole, the bottoming out issue (even if you go with a thicker oil) will only get worse.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-21-2012, 07:29 PM   #4542
nickypoo's Avatar
before i bite the bullet, is anyone running a mamba max pro in their buggy?
its the only sensored esc i have and ill run a 10.5 with it
braaaaaaaaaaap
nickypoo is offline   Reply With Quote
Old 02-21-2012, 08:05 PM   #4543
slow_jun's Avatar
Trader Rating: 14 (94%+)
works great, less maintenance and more run time between runs.... using mine and no issue here...
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 02-21-2012, 08:06 PM   #4544
rcman182006's Avatar
Send a message via Yahoo to rcman182006
If you remove the fan, it "should" fit (I've never owned a MMP before but I've seen them in buggies like that)
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 02-21-2012, 09:06 PM   #4545
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Kirby went with your shock setup today 1.2 4 hole all around 25 front w/ orenge and 20 rear with stock spring (close enough car was pretty hooked up during practice will see my times tomorrow during the races.
nolimit208 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
