Like Tree24Likes
Old 02-20-2012, 12:12 PM   #4516
murky123's Avatar
is there a good conversion chart for the losi BB springs / durango BB springs ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-20-2012, 12:52 PM   #4517
hopsing's Avatar
Trader Rating: 13 (93%+)
http://www.petitrc.com/reglages/BuggyBigBoreSpring.pdf
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 02-20-2012, 01:31 PM   #4518
FrEaKiShTuNER's Avatar
Trader Rating: 200 (100%+)
Originally Posted by hopsing View Post
Very nice!! Thanks for that link....
~AdamQ~
**Lower feedback ships first**
FrEaKiShTuNER is offline   Reply With Quote
Old 02-20-2012, 01:42 PM   #4519
murky123's Avatar
yep, thank you.
gonna try some losi rear pink springs instead of the durango light blue.
I need some stiffer springs for my RM3 setup
I feel the light blue springs are ok, but a little bit on the soft side for a RM config
Old 02-20-2012, 01:52 PM   #4520
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by spiro View Post
That's a great tip Captain, or should I say it would be - if my problem was the bottom of the shock, not the top. Thanks anyway!
oh shoot.. you're right.. sorry, I read that wrong! The top is easy... simply make sure the inside rim of the cap is sanded smooth, make sure you put shock oil on the o-ring itself... and it should be fine. If it catches, simply back the cap off till it lets go of the ring, and then try again.. after a couple of snags it will cinch up just fine. After a rebuild or two, it will just stop all on it's own.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-20-2012, 02:01 PM   #4521
Trader Rating: 21 (100%+)
yep, thank you.
I'm currently running the Losi white rear spring which is rated slightly softer @ 1.80...compared to the TD light blue. I've been running this car for 3-4 weeks and tried every oil, piston and spring I could get my hands on. 4 hole 1.2 pistons on all 4 corners....f/25wt r/20wt losi oil......Orange losi fronts and white rear springs worked the best in my opinion....ride height f/23mm r/22mm
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 02-20-2012, 03:20 PM   #4522
Autocratic's Avatar
Trader Rating: 26 (100%+)
What kind of surface?
For me on med. bite clay/dirt mix, 17.5 blinky I had really good laps on these:
-Losi Silver front
-1.3 4 hole
-30w
-Stock rear springs
-1.2 4 hole
-20w
Track is medium bumpy and not very technical.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-20-2012, 04:22 PM   #4523
-Losi Silver front
-1.3 4 hole
-30w
-Stock rear springs
-1.2 4 hole
-20w
Blinky 17.5. Our rear shock setup is almost exact. Clay med to high bit. Fairly flat with no huge features
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 02-20-2012, 05:46 PM   #4524
Autocratic's Avatar
I'm going to be trying the same pistons, but tapered this weekend. I really don't want to change the buggy setup at all, but I think the tapered pistons should help settle the buggy in the bumpy sections.
Old 02-21-2012, 12:10 AM   #4525
murky123's Avatar
-Losi Silver front
-1.3 4 hole
-30w
-Stock rear springs
-1.2 4 hole
-20w
Im gonna try this !!
doesnt really matter if you run 17,5 blinky or a 8.5 turn regarding springs and oil right?
your description of your track sounds a lot like mine.
I do not have huge jumps, not to technical but can be quite high speed.
low/med clay/dirt out doors
Old 02-21-2012, 12:41 AM   #4526
spiro's Avatar
Goodie! I'm gonna take a look at the inside edge later on, and sand them down a bit. I still think it could be a good idea to "cone" it in as well with a dremel, to force the o-ring inwards while tightening. I'll try this as soon as Durango gets the caps back in stock. Like this other guys said here as well - it might also be a good idea with a tighter smaller o-ring. If I remember the AE ones right, they have to be streched quite a bit to fit them over the shock body edge.
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 02-21-2012, 02:36 AM   #4527
You remember correctly plus the Associated caps are beveled as well
adam lancia is offline   Reply With Quote
Old 02-21-2012, 05:00 AM   #4528
spiro's Avatar
Aha! I rest my case...
Uhm. Actually, I won't - I'll follow my case up with a Dremel.
Old 02-21-2012, 06:15 AM   #4529
My DEX210 comes tomorrow!
I think I will go straight to the 4 hole pistons, and will close the other 2 holes with the solder-station and some plastic of the plastic-trees.
25 rear, and 30 front losi shock oil will be my start setup.
Everything else will I leave stock.
I'm really looking forward to it, new manufacturer, after leaving yokomo after 2 1/2 years.
What are the other important steps to watch, than diff and shock cap?
I will use the 23 pinion, with 87, using a 8.5T X12 octa motor.
Fatal1ty is offline   Reply With Quote
Old 02-21-2012, 07:09 AM   #4530
Trader Rating: 19 (100%+)
Actually stock/mod does make a difference. The faster speeds of mod class increase the shaft speed considerably and can make the rear end pack up harder than stock. My buggy feels great with 4 hole pistons but Cush's buggy is bouncy off of fast jump landings. We keep trying different 4 hole combinations on his and keep reverting back to 6 holes. Next up is a set of blanks drilled to 5 hole 1.2 and another set at 5 hole 1.3. His car drives very well but needs more pack, but 4 holes have been too much pack for his car and our track.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
