Like Tree23Likes
Old 10-04-2011, 06:22 PM   #436
Jmuck69's Avatar
I like the inserts to change suspension settings such as rear toe-in and front caster. You do not need to carry different hubs to make setting changes and when slop starts to develop, change the insert and not the whole hub.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-04-2011, 10:03 PM   #437
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ifuonlyknew View Post
I can't understand how someone would not understand why all mid-motor cars have 4-gear transmissions.
actually the 210 can run 3 or 4 gears in either mid or rear motor.
http://www.team-durango.com/race-cars/dex210/
and there are setup sheets available
http://www.team-durango.com/in-the-p...artNo=TD102006
asc6000 is offline   Reply With Quote
Old 10-05-2011, 04:26 AM   #438
Matt Howard's Avatar
build link
http://tresreyblog.com/
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-05-2011, 05:02 AM   #439
Jmuck69's Avatar
I see they put a groove in the chassis for the ESC wire. good!
B6D | B64D
Old 10-05-2011, 05:20 AM   #440
UK.hardcore's Avatar
Never been into buggy much but i'm feeling a change.
This thing is filled with awesome.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 10-05-2011, 05:29 AM   #441
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
This car looks awesome except for one thing... I think the body is hideous. I guess I will just have to deal with it
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 10-05-2011, 05:33 AM   #442
I actually like the look of the body, and the fact you can use the same body with rear or mid-motored setups is a bonus
RCTech #361
Old 10-05-2011, 05:38 AM   #443
Jmuck69's Avatar
Proline or Jconcepts will probably have a body for it soon.
B6D | B64D
Old 10-05-2011, 06:25 AM   #444
FRONTI3R's Avatar
Doesn't look like there is Servo Saver on the DEX210?
Same with the Shumacher Cougar I have, had to install a Tamiya Servo Saver since I kept breaking gears on my low profile Savox servo (5 times before I decided to install the Servo Saver).
I'm wondering if the Tamiya Servo Saver will fit well on this vehicle? (I had to grind some of Saver to fit it under the Cougar Top plate) I guess I will know once I do the build on the DEX210.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 10-05-2011, 08:56 AM   #445
murky123's Avatar
my losi 22 doesnt have a servo saver either.
no need for it . just make sure all end points are ok.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 10-05-2011, 09:00 AM   #446
I've snapped servo arm before gears never broke on me yet.
Old 10-05-2011, 09:33 AM   #447
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
i think the body looks awesome! kinda remind me of formula 1 bodies!
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-05-2011, 09:41 AM   #448
Originally Posted by Jmuck69 View Post
Proline or %$#!&*$#@ will probably have a body for it soon.
We can only hope
Old 10-05-2011, 09:44 AM   #449
The 4 Gear rear motor option sounds very interesting for some the tracks here in GA with less than perfect traction.
Old 10-05-2011, 09:46 AM   #450
FRONTI3R's Avatar
The end points were always set on my Cougar before I used it, yet I still broke the servo gears on certain hits or crashes.
Almost NO one else breaks the servo gears on their Cougar... I'm thinking the low profile servo is weaker and is why I kept breaking the gears.
I would agree that the servo horn should strip before the gears breaking... but it NEVER did when I had the low profile servo.
Just saying... it wasn't due to USER error as you are implying.
www.teknorc.com
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
