Like Tree23Likes
Old 02-13-2012, 06:41 PM   #4366
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Very cool,
I read somewhere that rear ball stud mount/diff case were almost impossible to find.
Like the carbon but don't like it when I'm upside down...
Looks nice.
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 02-13-2012, 07:00 PM   #4367
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by EvanAZ View Post
Very cool,
Looks nice.
There are a lot of things for this buggy you simply can't get. Some things I want, some things I need.
It's going to get better, hopefully, with this recent Hobbico buyout. Just need to happen sooner.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-13-2012, 07:16 PM   #4368
EvanAZ's Avatar
I was on the fence but now Durango is coming out with the DESC210 2wd short course so I want matching cars.
I am up to over $350 at amain in my cart and still shopping...
Old 02-13-2012, 07:18 PM   #4369
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by symmetricon View Post
No, there is a high speed 180, and a stepup, that needs some braking before entering. I have to be extremely easy on the breaks while going straight into the turn. I am running a shorty pack in the middle.
What is the spacing of your rear hubs. If it is moved forward at all move the rear hub back. I also made my rear shocks have the most camber as possible outer hole on arm and inner hole on tower. Running 25wt in rear with 6 hole 1.3 i think and stock spring. Front is 35wt outer on arm, inner on tower also.
I have a high speed corner like your suggesting and I moved my hub all the way back and it takes that corner faster than any other car I am against.
nolimit208 is offline   Reply With Quote
Old 02-13-2012, 07:36 PM   #4370
symmetricon's Avatar
Trader Rating: 27 (100%+)
My rear hub is in the middle position. I will try moving it back. Thanks.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 02-13-2012, 07:52 PM   #4371
nolimit208's Avatar
Mine was in the middle position first few races and moved it back and it made a big difference, hope it helps your situation also.
Old 02-13-2012, 08:47 PM   #4372
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Can anyone point out some of weak points if any?
The 2.5mm bearing on the front side of the slipper. Grab a half dozen or so of them. They wear out relatively quickly as TD chose a bearing size not quite up to the task. I had one disintegrate during a race causing a DNF. Id replace it here and there ahead of time as preventative maintenance.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-13-2012, 09:18 PM   #4373
nolimit208's Avatar
Had one of these go out on me this week actually. (switched form mm to rm) but was due to the shaft/gaer/bearing not being seeded properly. If you notice the shaft coming out the end with the nut rotating oblong or what not pull the case apart and re-seed it.
I had noticed before I put my car down the shaft wasn't straight thought it had been bent or something before I had put the car down but continued to run the qual and dmf'd because of it.
but would agree to the bearing being inadequate, but be sure when you put your casing together it is aligned properly or u'll blow it in a few minutes.
Old 02-13-2012, 09:35 PM   #4374
Super Moderator
A great shot of my dex210 at the Pacific Northwest Showdown series race this last weekend, stop #2 on the tour in Portland, OR.
- RCSpecialties -
Old 02-13-2012, 10:02 PM   #4375
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by MantisWorx View Post
I am biased but these are the best pads on the market! They do not wear,glaze and you can actually tune for slip and they dont "let go".
no trimming, they are a direct fit.
http://rcshox.com/shoxshop/catalog/i...hp?cPath=23_31
Thanks, but they are out of stock too
silvalis is offline   Reply With Quote
Old 02-13-2012, 10:06 PM   #4376
nolimit208's Avatar
LOL the similarities between our buggies..?.. lol
clear wing though dont think I approve of it..
Old 02-13-2012, 10:16 PM   #4377
nolimit208's Avatar
clearer pic last was on my car stand which was rotating.
Old 02-13-2012, 10:20 PM   #4378
nolimit208's Avatar
If u need pads you can buy the Schumacher gear(8*)/pads they are a direct fit for our dex210.
Old 02-14-2012, 12:36 AM   #4379
Ostach24's Avatar
Trader Rating: 85 (100%+)
Here is kind of an odd question... Has anyone tried to put a rb5 bulldog/any body on this buggy? All I have at the moment is a clear and a few painted rb5s
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 02-14-2012, 02:41 AM   #4380
hacker's Avatar
Trader Rating: 140 (100%+)
Default front wing
anyone tried fitting a front wing?
hacker is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Today 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
coaltrain
