Like Tree17Likes
Old 02-13-2012, 12:08 PM   #4351
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Jonny5 View Post
More anti squat can help with this, but I would think your brakes are just too strong and need to be turned down. This of course is assuming that all else is working properly.
I am running the 3/3 block, so I cant add more. Should I stiffen up the front end? I am running the stock 6 hole w/30wt front and 6-hole 20wt rear.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 02-13-2012, 12:17 PM   #4352
jnslprd's Avatar
Originally Posted by symmetricon View Post
Well, I like the brakes to be strong, so I can get better mid air correction. Yes, the rear end dumps pretty badly with even a little braking.
orion r10 pro, brakes feel magical
WGAS, WGAF
jnslprd is offline   Reply With Quote
Old 02-13-2012, 12:23 PM   #4353
I am using the Xerun 120amp esc with speed passion software. Its not the esc that is giving me issues. Should I move to the 4 hole up front?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 02-13-2012, 12:30 PM   #4354
MikeFriery's Avatar
Trader Rating: 19 (100%+)
i think its most likely your rear shock setup.
Im running 4 hole 1.3's with 20 weight, 3 on the tower, 1 on the arm ( i think, durango's mounting holes are backwards, if it were a XXX it would be 1-outside) with TLR pink springs
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 02-13-2012, 12:50 PM   #4355
Well, Im not sure which setup to go by form TD's website. I dont know any of the tracks listed, and the tracks in houston are big 1/8 scale(1st track is smooth, medium to high grip when wet to dry and blue groove, and the othertrack is rough, and can be high traction when wet, and loose when dry) All the tracks have high speed turns, step-ups, and big jumps. I figured the 4 hole would pack to easily onthe rough track, so I opted for the 6 hole. I dont have any chassis slap unless i overshoot the huge double single( cant quite trippe it) Other than the rear end dumping out at high speeds on brake, the car is amazing! Any shock setup sugestions is welcomed
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 02-13-2012, 01:06 PM   #4356
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
nvm
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-13-2012, 01:26 PM   #4357
Jmuck69's Avatar
+1 best ESC ever!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-13-2012, 01:52 PM   #4358
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
so i been on the hunt for an affordable Lo-pro servo for this ride...Ended up finding one with a decent transit time(.18@4.8v,.11@6v) and MG for around $30..will post some pics later..Between the new servo and the small justock speedo I put in last week I am 1534gms with full sized lipo,down from almost 1700, with full sized stuff, now for the shorty pack!!
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 02-13-2012, 03:25 PM   #4359
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
If the only reason you like a lot of brake is for mid-air correction you need to remember that even a very light brake setting on the esc or tx, your brakes will lock up pretty quick without any load on them(ie: in the air). Lighten up your brake setting just to the point where you're rear end isn't locking up on the ground.
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 02-13-2012, 03:26 PM   #4360
jimkoimanis's Avatar
i run on large tracks in australia my shock setup is 6 hole 1.3 front muchmore 300 shock oil all round and 6 hole 1.2 on the rear middle hole on front shock tower and inside hole on front arms. rear is middle hole on shock tower and outside hole on rear arms hope that helps u and stock springs aswell
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
Old 02-13-2012, 04:04 PM   #4361
KyoshoShawn's Avatar
Dave, I run mine at fastlane and letko all the time. Chuck is getting in parts for my 210 as they can. They are a big help and parts are all over the place now. I have jst now only broken my akerman plate but thanks to fastlane I already had a spare. This car is very stout after hitting the back wall at letko almost 30 times before I pulled the hingpin out the mount. Lol no shocktower issues here and I chassis slap HARD ALL the time. Hit me up and take it for a ride. You will end up getting one. Trust me
Zx5 FS2 SP NCG Edition. R10 Powered. Rt5
Rb5SP2. Orion & Castle Creations ESC's
Ultima SC-R. Orion & Novac motors
MP9Tki2WC. MP9e. Orion & Savox servos. Kal-Gard Lubricants
Team Terribles Byron Fuel OS Speed engines
KyoshoShawn is offline   Reply With Quote
Old 02-13-2012, 04:58 PM   #4362
EvanAZ's Avatar
Trader Rating: 99 (100%+)
I am about to drop the bomb on this,
Can someone tell me besides a-arms, hubs, and casters.
What other spares should I order right away.
I also see some using Losi springs are they a direct fit.
Can't wait to get my 210 and later going to get the DESC210r
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 02-13-2012, 05:14 PM   #4363
Jmuck69's Avatar
I carry extra shock towers.
B6D | B64D
Old 02-13-2012, 05:30 PM   #4364
EvanAZ's Avatar
Cool, shock towers.
Can anyone point out some of weak points if any?
I am coming from a b4.1 and am very curious as to how they compare.
Old 02-13-2012, 06:30 PM   #4365
Cool, shock towers.
The only other thing that is hit or miss is the ballcups. I have only had problems with the rear inner camber mount. for some reason they were prone to poping off real easily. So I upgraded, then broke the inner camber ballstud mount. If that happens, and you need a quick fix, rcshox.com has a solution.
http://rcshox.com/shoxshop/catalog
Diggitydesignes also has some nice carbon fibre stuff for a very good price!
http://www.diggitydesigns.com/D3_Off...rango_210.html
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
St Ives RC Club B4Bandit Australian Racing 16561 Yesterday 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
