Like Tree23Likes
Old 02-11-2012, 05:38 PM   #4306
SMcD's Avatar
Trader Rating: 61 (100%+)
Originally Posted by Cpt.America View Post
Going more inline with your front axles won't give you more overall steering. If you have an on power push, and are running carpet... You should be running mm3... Also limiting your front droop will help. But I would definitly convert to mm3.
Did not even think of that. Thanks!
SMcD is offline   Reply With Quote
Old 02-12-2012, 12:03 AM   #4307
onekiwi's Avatar
Originally Posted by hacker View Post
do you have a link to where you bought it from?
rcjunky is selling them i think
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 02-12-2012, 12:04 AM   #4308
hacker's Avatar
Trader Rating: 140 (100%+)
yep no worries, I found him on 'oople' after I posted
hacker is offline   Reply With Quote
Old 02-12-2012, 04:48 AM   #4309
rcjunky1's Avatar
http://www.oople.com/forums/showthread.php?t=92330
I'd rather if those interested pmed my on oople to help me keep things strait. I'm running low on some stock so I'll be updating quantities probably tonight.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 02-12-2012, 05:46 AM   #4310
Jmuck69's Avatar
I saw your pics of your parts and they look great! One suggestion, slot the screw holes of the shims. Easier to insert by simply loosening the screws instead of removing.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-12-2012, 06:09 AM   #4311
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Smcd
I would not got to mm3 because traction is still limited there. What tires are you running. I have found once I figured out the shocks my car has been decent. But if you are running stock springs, stock pistons, wrong tires, and too much motor as most of the guys there run. Then it will be hard to get your car to work. I just adjust set up with tires from week to week.
And on a side note. Do not waste your money on trying a gear diff there.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 02-12-2012, 06:13 AM   #4312
rcjunky1's Avatar
I thought about that, maybe I'll get that changed for the next batch, I still have a bunch of shims in stock though.
Team Durango Canada
Old 02-12-2012, 06:19 AM   #4313
Jmuck69's Avatar
I like the shim concept better than the current system. To change it out you have to take apart the backend and is time consuming. Would like to see adjustability from 0, 1, 2, 3 degrees.
B6D | B64D
Old 02-12-2012, 09:15 AM   #4314
spiro's Avatar
Loving the look of these, but I am wondering - is alu or CF the best choice for the steering rack?
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 02-12-2012, 10:52 AM   #4315
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Had another DNS in a big race this weekend due to TD quality control issues... Wheel hex pin broken in two. Anybody know of any direct replacements for the hex pins?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 02-12-2012, 11:06 AM   #4316
rcman182006's Avatar
Send a message via Yahoo to rcman182006
When I'm in a tight situation, I trim down an old body clip to fit
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 02-12-2012, 11:06 AM   #4317
SMcD's Avatar
Thanks West. Yeah, just gotta work on it a bit. Just looking for that quick fix
Old 02-12-2012, 11:07 AM   #4318
Autocratic's Avatar
Trader Rating: 26 (100%+)
Wheel hex pin...that's a first.
I lost one of my pins, so I used a spare XXX-CR hex pin I had. Same size, just a little shorter. I put a dab of CA glue on each pin so they stay in.
I had a good 17.5 race this weekend.
New Revtech worked amazing. Geared 69/35 seemed to be the best, and stock timing. Took 2nd in the A-Main, but should have had first. I messed up the setup to our double/double jumps on one lap and had to roll all four. I was only 1.1 secconds behind the leader at the end who qualified behind me in 5th and was slower in Top 5 and Top 10 average laps by over 500ths.
Completely different setup from last week seemed to work out very well. Had tons of grip and tons of steering. Didn't make a single chassis adjustment all day. The car just wanted to go where I told it. Very happy with the end result.
Have a few things I'll be testing on it next time I'm able to practice. Same pistons front and rear but tapered. Should help make the car even more smooth in the bumps. 12.5 HT rotor for the Revtech and same gearing/timing. With a little more punch I should be able to clear a small single/double whoop section that most people have to roll 3xsingle.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-12-2012, 11:39 AM   #4319
Trader Rating: 74 (100%+)
On my 210 and 410 I am using the J Concepts 12mm hex for the b4.1, spaced with the 2mm spacer. I use Associated roll pins for the hexes. Not one problem here, and putting down plenty of power..
I did have the opportunity to run a gear diff the other night. I filled it with Losi 5k, it defintetly accelerates faster, but steps out easier. I need to get that nailed down.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-12-2012, 11:46 AM   #4320
Super Moderator
Yeah, Iv been running one of those for a while when I lost one of my originals. Ironically, I was worried about breaking the body pin, not one of the factory ones! Body pins are a bit small and create a bit of slop/play between the pin and axle. I was hoping to find an OEM type pin that fit better than the stock ones.
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16563 Yesterday 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
