Like Tree23Likes
Old 02-10-2012, 07:53 AM   #4291
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
Really thinking about this buggy, looks pretty cool. I was wondering what spares are good to have? I thought I heard where the car comes with spare arms????
Looks like a trans case and some ball studs are needed for spares....any others?
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 02-10-2012, 08:00 AM   #4292
grapejuice's Avatar
Trader Rating: 132 (100%+)
Shock towers and car does not come with spare arms
MHOR RC Raceway / 5280 Raceway
grapejuice is offline   Reply With Quote
Old 02-10-2012, 08:31 AM   #4293
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by T-BirdJunkie View Post
Has anybody had any issues with the doodad that holds the servo mounts mating properly with the chassis wings and lining up with the holes properly?
The right side seems to mate up just fine and line up with the steering rack mount, but the holes don't line up, and the left side just doesn't line up with ANYTHING.
Are you talking about during assembly? You need to leave the side pods loose so everything can be moved around during the assembly of that section. Once you get it all together and the screws started then you can tighten everything down its all good.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 02-10-2012, 11:42 AM   #4294
Furtado66's Avatar
I had some on-road shims from my corally that I used. There was quite a bit of play though. When I change the fluid after this weekend I will get back to you.
Furtado66 is offline   Reply With Quote
Old 02-10-2012, 11:45 AM   #4295
Furtado66's Avatar
Have been running the car since it came out and have only broken a front shock tower. Car is awesome
Old 02-10-2012, 09:16 PM   #4296
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Broke my first piece today on the car. a SCT landed on top of me and decided to continue to 4x4 over me during practice. Thought it broke my shock towers but it broke one of my rear arms. Kind of an odd break.
nolimit208 is offline   Reply With Quote
Old 02-10-2012, 09:37 PM   #4297
Jmuck69's Avatar
Broke a rear A-arm as well but it had a Lunsford titanium hinge pin and bent that! I was fighting for the same airspace after a jump with a ST, truck won and I came down on the rear a-arm. snap!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-11-2012, 12:27 PM   #4298
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Bugle boy side profile!
New improved Gearboxfix:
MantisWorx is offline   Reply With Quote
Old 02-11-2012, 01:46 PM   #4299
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Hey Mantis, are those BB shells in stock at your store???
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 02-11-2012, 01:54 PM   #4300
also you guys with noisy trannsmissions---I tore my tranny down to switch from MM3 to MM4 for running ozite.In MM3 my tranny was noisy.so I gave the trans a quick go-thru while I was at it..I noticed that the top shaft gear fit the top shaft a little sloppy..so i used some thin CA to put a thin layer of CA on the top shaft where the gear rides..just put it on and wiped it off with a rag..the gear still slid on the shaft, but way more snugly than it previously did..No more sloppy wiggle on the shaft and viola, no more noisy trannsmission when it went back together
Old 02-11-2012, 03:42 PM   #4301
MantisWorx's Avatar
I have them and plan on adding them to the site tonight. i did not get very many in on this run, kinda feeling the market. iI like it though!
this is where they will be:
http://rcshox.com/shoxshop/catalog/i...hp?cPath=23_31
Old 02-11-2012, 04:11 PM   #4302
thanks!! will be ordering 1 up as soon as I check with the banker (wife) to make sure it wont cost me a beating,LOL
Old 02-11-2012, 04:12 PM   #4303
Dave,
You will appreciate the tunability of the car. As for breakage; Jeremy and I have been running the car since its release with only a steering rack and shock eyelet for breakage. We run the TC5 ballstuds with Jason's ballcups as well as his body and rear hexes. Make the jump....you'll be glad you did!
Airtronics/www.airtronics.net ~ JConcepts/www.jconcepts.net ~ KustomRCGraphics/www.kustomrcgraphics.com
Jeff Harris is offline   Reply With Quote
Old 02-11-2012, 04:52 PM   #4304
also just got this in the mail today..from a seller in canada,it was $15.Nice peice.Is a direct replacement for the stock 3/3 front rear toe block.
Old 02-11-2012, 05:32 PM   #4305
hacker's Avatar
Trader Rating: 140 (100%+)
do you have a link to where you bought it from?
hacker is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
