Like Tree24Likes
Old 02-08-2012, 04:16 PM   #4246
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by MantisWorx View Post
tested all day yesterday, i will make a few adjustments to the CAD work and start production tomorrow. will post proto pix later today!
Sweet, I'm still good on that part but I want it for when or if the case mounts go.
I just got my front CF tower. Looks sweet on the car. I think the screws could have been a little longer. Not that I run a front sway bar but there isn't much thread left if you leave the sway bar retainers on. The stock ones the same way though.
Thanks for the speedy n safe delivery .
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 02-08-2012, 04:21 PM   #4247
tomdav's Avatar
Trader Rating: 42 (100%+)
So it seems the shock orings have a fair bit of drag out of the box. Has anyone tried a different brand or used a smaller spacer?
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 02-08-2012, 04:27 PM   #4248
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by tomdav View Post
So it seems the shock orings have a fair bit of drag out of the box. Has anyone tried a different brand or used a smaller spacer? I just picked up some of the black shock shafts, very cool.
Try loosening the lower shock caps a tad. If you make them too tight the black spacer will compress the o-rings too far and can cause excessive friction.
Another thing you can do is sand down the spacer with fine grit paper if you still have alot of friction.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-08-2012, 05:03 PM   #4249
Matt Howard's Avatar
I use one stock O ring and one HPI clear one. The HPI clears are quite a bit softer, it seems to be a good compromise running one of each as my shocks are nice and smooth but don't leak a bit either.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-08-2012, 05:06 PM   #4250
Autocratic's Avatar
How dirty does your oil get after a day a Mikes? The stock o-rings don't seem to protect very well.
Old 02-08-2012, 05:14 PM   #4251
MantisWorx's Avatar
Trader Rating: 28 (97%+)
this is the one i tested yesterday, production parts will be black with a slightly different design. it is now two pcs with the base made of acetyl polymer and the top plate made of 3mm Garolite.
MantisWorx is offline   Reply With Quote
Old 02-08-2012, 05:22 PM   #4252
still clear after a day. Are you using any green slime on your O rings? Helps out alot with keeping the shock both smooth and well sealed.
RCTech #361
Old 02-08-2012, 05:47 PM   #4253
Trader Rating: 44 (100%+)
Can someone give an estimate of sensor wire length for RM3 using a LRP esc?
sstoffer is offline   Reply With Quote
Old 02-08-2012, 06:01 PM   #4254
slow_jun's Avatar
Trader Rating: 14 (94%+)
Kyosho Grooved O-Ring
Kyosho P3 Grooved Low Friction Shock O-Ring
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 02-08-2012, 06:03 PM   #4255
slow_jun's Avatar
some says that you need to soak it in oil first prior installation, mine i changed it and used Kyosho P3 Rings. and no leaks and dirt on my oils.
Old 02-08-2012, 06:25 PM   #4256
Autocratic's Avatar
Is there a big difference in friction between the non and low ring?
Old 02-08-2012, 07:55 PM   #4257
slow_jun's Avatar
Honestly i dont know, i also asked that to my friend that did the same to his Car. maybe similar to losi's low friction oring whereby you need to put the low friction inside and the standard one on the outer most to keep of the dirt. might try that one, one of these days.
Old 02-08-2012, 10:29 PM   #4258
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
New body and switched to rm3 from mm4. Was a lot more forgiving in rm then mm on my indoor clay track.
nolimit208 is offline   Reply With Quote
Old 02-08-2012, 11:03 PM   #4259
murky123's Avatar
http://www.team-durango.com/part-inf...artNo=TD330347
Pivot Ball C-Type 10mm
last night I broke one of these on the front shocktower. it's split in two where the 2.5mm driver goes in.
what other can I use besides durango's ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-08-2012, 11:26 PM   #4260
Tunatsol's Avatar
I did the same trying to unscrew it bound up and broke. Got new one from Durango. Make shur that the ball cups line up right and u should have no more probs. Think that the one i broke was thin on one side. Hope this helps.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
EbbTide
