Like Tree43Likes
Old 02-06-2012, 12:04 AM   #4171
Autocratic's Avatar
Trader Rating: 26 (100%+)
Ryan Lutz and Jorn Neumann setups from the Reedy Race are up on the Team Durango website.
Interesting to see the differences between Ryan and Jorn's setups.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-06-2012, 12:56 AM   #4172
mdowney's Avatar
Trader Rating: 21 (100%+)
Also interesting to see that they didn't admit to running an extended chassis.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 02-06-2012, 12:58 AM   #4173
slow_jun's Avatar
Trader Rating: 14 (94%+)
Guys,
need to double check if this is correct,
for the Cups upgrade.
LOSA6015 LOSA6015 Super Duty Ball Cups, Natural
ASC31282 ASC31282 Ballstud, short, 10MM
ASC31285 ASC31285 Ballstud, long, 10MM
wont the cups of the losi hit the gear cover?
thanks,
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 02-06-2012, 01:03 AM   #4174
Autocratic's Avatar
Ryan ran stock, Jorn ran long. I noticed that too. Probably don't want to give everything away.
What's weird is, even after running the long chassis, Jorn is still running 1mm shim in front of the rear hubs. So, that long chassis (what looked like ~8mm) was missing 3mm from the longest wheel base he could have had.
Old 02-06-2012, 01:06 AM   #4175
Autocratic's Avatar
Originally Posted by slow_jun View Post
Guys,
thanks,
Really want white?
I'm running the Lunsford kit and my ball cups don't hit. I am however running 2/2 on the rear hub, so I would suspect if you're running full wheelbase they might hit. You can swap rear hubs so the ball stud faces forward and that will give you a little more room. Don't forget to change your pills if you have something other than 0.
Old 02-06-2012, 01:13 AM   #4176
slow_jun's Avatar
Really want white?
yup i like the white one rather than the black, i already have a spare buckles thats why i opt not to get the Lunsford kit,im also running on 2/2 on the rear hub,sorry but what do you mean by change your "pills" . sorry for my english.
Old 02-06-2012, 01:14 AM   #4177
Autocratic's Avatar
English is better than most
By pills I mean the rear hub inserts to change your toe. If you swap rear hubs and are running more toe than the stock 3 you need to flip the inserts to keep your previous settings.
Old 02-06-2012, 01:17 AM   #4178
slow_jun's Avatar
opss, i get it... thanks....
Old 02-06-2012, 01:26 AM   #4179
slow_jun's Avatar
the Lunsford Kit specs are also similar to other manufacturers specs.
(2) M4.8x8mm Ball Studs (Steering Rack)
(2) M4.8x8mm Ball Studs (Steering Spindle)
(2) M4.8x8mm Ball Studs (Rear Brace)
(2) M4.8x8mm Ball Studs (Rear Hub)
(2) M4.8x10mm Ball Studs (Caster Block)
(2) M4.8x10mm Ball Studs (Front Shock Tower)
Like Losi 22 studs, i might as well get the losi one and the price is a fraction of the cost......
Old 02-06-2012, 06:22 AM   #4180
TAMAK's Avatar
Trader Rating: 28 (100%+)
Jorn ran long and also had about a 60gram bulkhead on his car!! So do not use his setup unless you plan on running those two items. Ryans setup is more realistic to us "kit" owners.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 02-06-2012, 07:03 AM   #4181
jurquhart's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Terra Rover View Post
These are the ones I use. I just have them in white.
http://www.jconcepts.net/store/index...products_id=23
Does anyone have the link to the ball studs to be used with the J Concepts ball cups?
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 02-06-2012, 07:37 AM   #4182
Trader Rating: 70 (100%+)
Originally Posted by kwilke View Post
his car is in mm4 already !
What is mm4?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 02-06-2012, 07:38 AM   #4183
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Originally Posted by steve eaves View Post
What is mm4?
Mid Motor 4 Position
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 02-06-2012, 07:39 AM   #4184
Mopar's Avatar
Just use Associated TC5 or TC6 ballstuds. They're titanium nitride coated for long wear. I use the Losi standard HD ballcups, including the inside rear. You don't need to use the offset ballcup. BTW the Jcon ballcups are very soft material, which is way I changed to the Losi ones.
Mopar is offline   Reply With Quote
Old 02-06-2012, 07:52 AM   #4185
Dog Runner's Avatar
Send a message via Skype™ to Dog Runner
What changes would there generally be in going from the 6-hole pistons to just 4 holes (on both front and rear shocks)?
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 Today 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
