Like Tree26Likes
Old 02-05-2012, 09:29 AM   #4156
tomdav's Avatar
Trader Rating: 42 (100%+)
Originally Posted by superseal View Post
1st post BOOM lol!
ive seen a few people using J concepts at the rear how are people getting on with these and are there any alternative i could use?
You have to use a new ballstud for the jconcepts cups. I think the TC6 ballstuds are what most are using.
ON another note I raced my second 210 on saturday. On my first pack I ran into a marshall walking down the front straight. My chassis was severly tweaked and I had to get medieval on it with channel locks and a vise. The good news is not one of the ballcups popped off from normal abuse. I did pop one of the steering links after hitting a wall jumping a 24 foot double.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 02-05-2012, 10:43 AM   #4157
Autocratic's Avatar
Trader Rating: 26 (100%+)
BTW,
If anyone needs to replace the thrust bearing assembly when rebuilding your diff, the Losi HD thrust kit fits perfect; it's also slightly thicker when assembled and this helps to fill the gap between the top race and the clip slot.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 02-05-2012, 12:39 PM   #4158
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
I went with RPM ends and used ball studs from my Associated TC5 black short outter and silver long inner for the rear.
I herd to wait for the new rear camber link mount to come out because they are breaking the current ones.
I would like to go with the aluminum one if I can find something the weight may help some.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 02-05-2012, 01:06 PM   #4159
What is the link for the mantis works mount any way?
Old 02-05-2012, 02:09 PM   #4160
Originally Posted by Autocratic View Post
BTW,
do you have a part number?
superseal is offline   Reply With Quote
Old 02-05-2012, 02:37 PM   #4161
http://www.rcshox.com
cm.stites is offline   Reply With Quote
Old 02-05-2012, 02:46 PM   #4162
jurquhart's Avatar
Trader Rating: 22 (100%+)
does anyone have the part number for the jconcepts ball cups and the ball studs that fit on the 210?
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 02-05-2012, 02:47 PM   #4163
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by cm.stites View Post
Thanx! new version will be tested tuesday!
MantisWorx is offline   Reply With Quote
Old 02-05-2012, 02:55 PM   #4164
CHIZZLE's Avatar
Trader Rating: 37 (100%+)
How does the new version differ from the old?
Chance Renstrom
Repeat after me......"toy cars"
CHIZZLE is offline   Reply With Quote
Old 02-05-2012, 02:56 PM   #4165
MantisWorx's Avatar
2pc design, 3mm thick garolite with delrin base.
Old 02-05-2012, 02:58 PM   #4166
CHIZZLE's Avatar
Got any mounted pics?
Chance Renstrom
Old 02-05-2012, 03:01 PM   #4167
MantisWorx's Avatar
there will be no pix until i am finished testing! should have some late tuesday. there will be two of us testing it along with new spec pistons.
Old 02-05-2012, 03:05 PM   #4168
MantisWorx's Avatar
i did get a small shipment of bugleboy bodies in! RCink is painting mine up right now here is the body, still has to finish the wing and undertray.
Old 02-05-2012, 05:12 PM   #4169
Terra Rover's Avatar
These are the ones I use. I just have them in white.
http://www.jconcepts.net/store/index...products_id=23
Terra Rover is offline   Reply With Quote
Old 02-05-2012, 05:54 PM   #4170
Autocratic's Avatar
Finally got around to painting my Finnisher.
I ordered the brace from you last week. You going to wait and send me the v2?
I think this was the one. Pretty sure it was in a TLR package though.
http://www.amainhobbies.com/product_...st-Bearing-Set
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
EbbTide
