Like Tree32Likes
Old 02-04-2012, 02:56 PM   #4141
jurquhart's Avatar
Trader Rating: 22 (100%+)
Originally Posted by sideways88 View Post
is any one else having problems with the screw that holds the piston on the shock shaft coming off? I cant seem to keep them on. I have used lock tight and still they come off after a few runs.
I had the same problem had my shock come apart luckily I found all of the pieces when the shock came apart on the track
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 02-04-2012, 06:03 PM   #4142
wfdfiremedic's Avatar
Thanlks to the guys that replied back about carpet setups etc. I didn't know they had carpet setups on the durango site. I will check it out.
thanks
B4.2
SCTE
wfdfiremedic is offline   Reply With Quote
Old 02-04-2012, 07:18 PM   #4143
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by CHIZZLE View Post
Mine definitely took a major chunk off. No way to drill another hole. But I think the bearing should hold. Is the RCShox the only option right now for what I have?
sorry, been busy.. got a G10 and a Dremel and you can do similar to what i did to mine.
Just removed the spacer and removed some portion on the G10 to match the height of the spacer then screwed in the ball stud.
Now the gearbox ears is a bit stronger than before.
also did the steering link.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 02-04-2012, 07:29 PM   #4144
Trader Rating: 74 (100%+)
G10 wont last, sorry to say. I made a link out of carbon also and made it double thick, it still broke. So I decided to take the carbon one to a CNC shop. I had them make a 5mm thick aluminum mount that bolts directly tho the lower plate. I used it this weekend and it worked awesome. I actually finished a race weekend.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-04-2012, 08:07 PM   #4145
slow_jun's Avatar
so far mine is still not broken. will just re-fabricate when its toasted.
mine still got the ears so its just a reinforcement, if the ears are already gone and i think g10 will not hold up.
Old 02-04-2012, 09:28 PM   #4146
forty6's Avatar
Now that is nice!
forty6 is offline   Reply With Quote
Old 02-04-2012, 09:35 PM   #4147
slow_jun's Avatar
how much did it cost for that allu mount? ou have to remove the ears first right? most robust so far, so i have seen... me like
Old 02-05-2012, 12:38 AM   #4148
Trader Rating: 19 (100%+)
Originally Posted by forty6 View Post
I checked it out but I prefer something made out of cf or aluminum. Maybe Diggity will come up with something.
Tresrey has theirs designed and should be here within a week or two if nothing gets delayed- it's made from cf plate. Their design does not require the mounts to be cut off the gearbox.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 02-05-2012, 03:06 AM   #4149
autocadsteve197's Avatar
Location: Queensland, Australia, Earth, Galaxy, Universe, A Childs Sandpit
Trader Rating: 42 (100%+)
Thats an awful lot of extra weight to be carrying around?!?
God is Science to the Disbelievers!
autocadsteve197 is offline   Reply With Quote
Old 02-05-2012, 03:38 AM   #4150
Matt Howard's Avatar
It's just aluminum, can't weight that much
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-05-2012, 03:53 AM   #4151
Huh? Aluminim is heavier than plastic or carbon fiber by a long way in scale. You have to remember to put the weight in to scale.. For example 5 grams is not 5 grams in 1/10th scale. It would be like having some bags on concrete in the back of your 1:1 car.. Alunimun
Old 02-05-2012, 04:11 AM   #4152
and if you look, it seems like he already has some lead in the corners of his chassis. I really don't think an aluminum part in that area is a problem at all.
RCTech #361
Old 02-05-2012, 05:37 AM   #4153
Trader Rating: 520 (100%+)
Actually the mount that breaks off is higher in the chassis, so he added a bit more weight, but its "LOWER" ..
flame56mx is offline   Reply With Quote
Old 02-05-2012, 07:22 AM   #4154
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
Originally Posted by Cpt.America View Post
If you are running on carpet, start with MM4.
his car is in mm4 already !
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 02-05-2012, 08:50 AM   #4155
1st post BOOM lol!
i wanna get a 210... i plan to change the cups to losi HD (using losi 22 rods as i have these spare)
ive seen a few people using J concepts at the rear how are people getting on with these and are there any alternative i could use?
plan to run MM4 for carpet high grip
superseal is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
