Like Tree26Likes
Old 01-31-2012, 06:49 PM   #4021
Trader Rating: 520 (100%+)
Originally Posted by Cpt.America View Post
I put the nut on the driver side
Take the day off work.
Now that there is funny- and partly true...
flame56mx is offline   Reply With Quote
Old 01-31-2012, 07:15 PM   #4022
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by kwiksi View Post
What motor conf. you running? Still...sounds like your setup is unbalanced, better yet. Post it.
rear
RM4 4.5 toe 3 deg kick up/losi 22 pink springs rear-stock 6hole piston-20wt/ stock rear comber setting- -1deg
front
0 trailing / 35deg caster/ linkage stock camber -1deg/0 toe in/ 6 hole piston 25wt
waiting on my shorty packs, running 6000mah 2s battery all the way back...lol
As far as setup goes, I dont even know what to change, there are never setups for 2wd on an outside track like the one I posteed a link to. I have only driven it at the track for 2 days, but it drove very well. It handled very well, cornered very well on and off power, and soaked up the rough stuff and the washbard very well. Any suggestions are welcome
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 01-31-2012, 07:56 PM   #4023
Hi Cpt America,
Thanks for the reply, could u explain what u mean by driver side.
As of now my Nut is on the same side as the Spur Gear. Btw i'm using the RM3 set up.
So if looking from the rear of the buggy, Nut for the ball diff is on my right.
Is that the correct position??
or should it be on the left hand side which is on the same side as the slipper adjustment nut??
How this makes sense.
Damn... you got to be joking!!!
kj2682 is offline   Reply With Quote
Old 01-31-2012, 09:38 PM   #4024
Default durango DEX210
anyone know how to find parts for this thing? I need a new Diff Case, a couple complete ball diff rebuild kits, and a bunch of Diff Rings
I have the upgrade carbine towers, and carbine steering rack. W/ aluminum Shock Collars
riley lawlor
[email protected]
rtlawlor is offline   Reply With Quote
Old 01-31-2012, 11:29 PM   #4025
onekiwi's Avatar
Whats the part number for the alu shock collars? think I found it this right TD330161 Who has them in stock?
Would the losi collars work?
Ill see if I can borrow and try a pair tonight at the track
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 02-01-2012, 12:26 AM   #4026
iTz IAN's Avatar
Trader Rating: 21 (100%+)
riley lawlor
[email protected]
where did you get those shock towers and what brand are they
iTz IAN is offline   Reply With Quote
Old 02-01-2012, 02:08 AM   #4027
jimkoimanis's Avatar
here is my bugle boy body for dex 210 paint by me habib bodies their is a matching under tray for it to ill post pics of it when its finished
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
Old 02-01-2012, 02:20 AM   #4028
onekiwi's Avatar
I think they are from www.akularacing.co.uk
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 02-01-2012, 03:51 AM   #4029
murky123's Avatar
you run Mid? on a clay track ?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-01-2012, 04:18 AM   #4030
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by symmetricon View Post
rear
front
The 0 trailing and 35 castor is giving you the most aggressive front end. Kit setting is -4 trailing. I like 30 castor and 3 to 3.5 toe in rear. Your damping is way light. Try these changes and you should see less aggressive going in.
kwiksi is offline   Reply With Quote
Old 02-01-2012, 04:48 AM   #4031
Jmuck69's Avatar
Actually those are the pieces from 8-Racing. Tresrey will be importing them soon.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-01-2012, 05:22 AM   #4032
Ill give it a shot, but the oils is pretty good, altough in the front I could use some more pack. Maybe try the 4 hole in front?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 02-01-2012, 06:30 AM   #4033
Trader Rating: 25 (100%+)
anyone had a video amain 2wd mod reedy race ? thanks
taztal3 is offline   Reply With Quote
Old 02-01-2012, 06:35 AM   #4034
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
+1
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 02-01-2012, 09:30 AM   #4035
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by kj2682 View Post
Hi Cpt America,
The left side of the car is the drivers side as if you you were sitting in it looking out the front of the vehicle....if you're running RM3, then the motor is on the left side. The diff nut should be on the left side with the adjustment screw on the right side.
And yes he's joking....sort of. It definitely takes longer than any other car out there to get the diff out but it shouldnt be more than 10-15 minutes total to get it in and out.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
