Like Tree43Likes
Old 01-31-2012, 12:59 PM   #4006
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by symmetricon View Post
http://lutzinator.com/?page_id=78
I find it odd that some of you guys need more steering, you must be running inside on high bite clay? I have my d/r at 80% because i have so much steering running 4.5deg rear toe in(guess that is relative to the track).
You must have the wrong rear tires to be using that much toe in or your setup is way off. This buggy has so much rear grip as it is...
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 01-31-2012, 03:13 PM   #4007
murky123's Avatar
what brand oil does Lutz use ?
durango? or a other brand? couse durango .cst is not the same as Xray .cst and also different then AE .cst
so when Lutz uses 375 cst front and 275 cst rear what kinde oil is that in wt ?
I have 275 = 25wt associated factory team oil is that the same as 275 durango oil ?
so when I want 375 and 275 .cst what Lutz has, what associated factory team oil do I need?
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 01-31-2012, 03:17 PM   #4008
Matt Howard's Avatar
Here ya go
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-31-2012, 03:22 PM   #4009
fullsyzz's Avatar
Trader Rating: 107 (100%+)
Lutz uses PT Rc oils.
fullsyzz is offline   Reply With Quote
Old 01-31-2012, 03:22 PM   #4010
fullsyzz's Avatar
PT Rc Racing
Old 01-31-2012, 03:23 PM   #4011
murky123's Avatar
I know that chart, but it does not hold an awnser for me.
what brand oild does Lutz uses?
and if he uses durango oil, this chart does not have the 275.cst and 375.cst.
so I can not find the appropriate team associated oil
Old 01-31-2012, 03:24 PM   #4012
murky123's Avatar
ok, so PT it is.
but 275.cst from PT is how many wt from team associated ? and 375.cst ?
Old 01-31-2012, 03:26 PM   #4013
[QUOTE=murky123;10256995]what brand oil does Lutz use ?
so when I want 375 and 275 .cst what Lutz has, what associated factory team oil do I need?[/QUOTE]
He uses pt racing oils. unless pt releases the specifics for a chart you will not be able to get a straight answer as each manufacturer uses different rates
cm.stites is offline   Reply With Quote
Old 01-31-2012, 03:50 PM   #4014
DRCRacer299's Avatar
The PT RC oils that I use go exactly by the cst scale. So if you can find what oils you are running and how they convert to cst then you can see what i'm running.
Tekno RC -LUTZRC.com -Alpha Plus Engines -Byrons Racing Fuel -AKA Tires
- Futaba -Tekin -ProTekRC -Liverc.com -92 Zero Designs -PTRC Racing Oils
-4C Hobby Supply -R/C Hobby of Medina -Misunderstood Graphics -LutzRC
My website = www.lutzinator.com, Find me on Facebook at Facebook.com/lutzrc
-Follow me on Twitter @Lutzrc, #LutzRCRevolution
DRCRacer299 is offline   Reply With Quote
Old 01-31-2012, 03:58 PM   #4015
fullsyzz's Avatar
Found this in the DNX thread....275 should be around 22.5ish
Originally Posted by DRCRacer299 View Post
For the PT R/C Racing Oils that I am using here is the conversion to Losi Wt.
350=27.5
375=30
400=32.5
450-35
475=37.5
500=40
525=42.5
550=45
600=50
650=52.5
700=55
750=60
800=65
Old 01-31-2012, 04:02 PM   #4016
symmetricon's Avatar
Trader Rating: 27 (100%+)
The thing is that I run outside on a dry loamy 1/8 clay track. Traction is a precious comodity at here.
here is the track
http://www.youtube.com/watch?v=CTRjK7LyXoE
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 01-31-2012, 05:07 PM   #4017
kwiksi's Avatar
here is the track
What motor conf. you running? Still...sounds like your setup is unbalanced, better yet. Post it.
Thanks in 2017 to
Old 01-31-2012, 07:16 PM   #4018
hey guys,
Just gotten my DEX 210.. VERY VERY Pleased with the quality of the kit.
Just a few questions that i would like to ask, it may have been covered before somewhere along the 200++ pgs.
Question 1)
With regards to the ball diff positioning. which side should the nut be on, placing the front of the buggy away from u. Should it be on the Spur side or the other side??
Question 2)
What is the fastest way to remove the diff from its casing?? any tips or advice?? i see lots and lots of screws to remove.
Please do advise.
Thank you
kj2682 is offline   Reply With Quote
Old 01-31-2012, 07:29 PM   #4019
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by kj2682 View Post
Question 1)
I put the nut on the driver side
Question 2)
Please do advise.
Thank you
Take the day off work.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-31-2012, 07:37 PM   #4020
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Lmao!
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
