Like Tree17Likes
Old 01-30-2012, 08:07 AM   #3946
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I'm glad I wasn't the only one that missed what he meant...
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 01-30-2012, 08:10 AM   #3947
Jmuck69's Avatar
Originally Posted by Cpt.America View Post
We talkin about the girl?
The girl extends other parts...but not the buggy chassis. SCHWING!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-30-2012, 08:16 AM   #3948
hopsing's Avatar
Trader Rating: 13 (93%+)
Unless Jorn changed it, his chassis is not stock......Hupo, Jorn, Travis, Billy and Carson were all running a longer chassis for this race.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 01-30-2012, 08:20 AM   #3949
Jmuck69's Avatar
Sweet! Was there any other option parts being tested?
B6D | B64D
Old 01-30-2012, 08:28 AM   #3950
hopsing's Avatar
Hupo's 210 with the new PL bulldog body...... forgot to ask Daniel Adams from PL the availability but it looks pretty good and I'm not a big fan of cab forward bodies. And yes, his car is long.
Steve Butts
Old 01-30-2012, 08:30 AM   #3951
hopsing's Avatar
Hupo had the aluminum rear hubs in his car and they look sick! Other than that, I didn't notice anything different.
Steve Butts
Old 01-30-2012, 08:40 AM   #3952
February 15th for the bodies.
cm.stites is offline   Reply With Quote
Old 01-30-2012, 08:40 AM   #3953
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by Slash'em1 View Post
Steve Amain has a CF steering link in stock.
http://www.amainhobbies.com/product_...-Steering-Rack
Thanks Tom, untill I get my new parts I just fit an SC10 center link in the 210. It's a little shorter n had to shave it a little but I will atleast be able to make a race next weekend.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 01-30-2012, 08:41 AM   #3954
Jmuck69's Avatar
I heard somewhere else that they will be available mid Feb. I have the Jconcepts on there now and looks cool but the Proline looks better.
B6D | B64D
Old 01-30-2012, 08:43 AM   #3955
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
How did Luttz do in 2wd buggy?
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-30-2012, 08:50 AM   #3956
hopsing's Avatar
He ended up 4th overall in Open 2wd after A2..... there was no A3 for this race. His car looked good and he was running the standard "short" chassis.
Steve Butts
Old 01-30-2012, 09:05 AM   #3957
Heavy B's Avatar
Trader Rating: 18 (100%+)
I know I've read about this a few times in this thread, but going to discuss again. I ran the 210 for the first time this weekend and could not get a full run in due to diff issues. Unfortunately, I did not take my snap-ring pliers with me so I couldn't flip the circlip at the track. When I was running it the rounds side was up and that did not work. So, I flipped the circlip so the flat side is up but found when breaking in with drill that the diff had the same problem. It works for ashort time then "clicks" and the diff no longer works. I monkeyed arond with it for a while and found that if I reversed my pliers and spread the circlip after install it would stay for the drill break-in while adjusting speeds and directions. Also, I made sure the diff was tight prrior to break-in and did not tighten again as tightening the diff seems to be the cause of the circlip shift (click sound).
Anyone have any suggestions on how to insure I won't have diff issues again.? The car is fantastic when I can run it, but right now I can't even finish a heat.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 01-30-2012, 09:13 AM   #3958
hopsing's Avatar
Definitely put a new circlip in the next time around..... and when you install make sure the flat side is up and that you squeeze the clip the absolute minimum when installing it. Then take a flat head screwdriver and twist in the open end of the clip to push it outward into the groove to make sure its in all the way. Check the diff tech tip article on Team Durango's site for excellent build tips.
And don't forget to make sure you have the thrust washers in correctly as well.
Steve Butts
Old 01-30-2012, 09:34 AM   #3959
Heavy B's Avatar
I have the thrust washers installed with the small hole to the outside and the bigger hole to the middle. Is that the correct way?
Brian Bernt
Old 01-30-2012, 09:38 AM   #3960
Trader Rating: 21 (100%+)
http://www.team-durango.com/blog/201...ild-guide-pt1/
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16561 Yesterday 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
