Like Tree26Likes
Old 01-15-2012, 07:03 AM   #3571
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by The Juice View Post
I seem to be nosing up on the jumps and I cant seem to control it as much as with my sc truck using brake. Was thinking of trying some weight up front, where are you guys putting it, right in front of the servo? If so how much?
thats the nature of the beast, you have to make sure you are not on the throttle when you launch and some drag brake will also help. Adding weight will make it that much harder to get down once its already started to go up. Work on your launch technique first, second work on your front suspension settings, try thicker oil to slow down the rebound.
MantisWorx is offline   Reply With Quote
Old 01-15-2012, 07:11 AM   #3572
The Juice's Avatar
Trader Rating: 25 (100%+)
Thanks for the tips.
Tim M.
The Juice is offline   Reply With Quote
Old 01-15-2012, 07:21 AM   #3573
Jmuck69's Avatar
I am running my full size lipo in the forward position. This helps with the balance and jumping control tremendously. This is the battery position that would be used in mid-motor position. It places the battery right up next to the steering servo.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-15-2012, 10:04 AM   #3574
Autocratic's Avatar
Trader Rating: 26 (100%+)
he uses 2 stage pistons which control rebound and work better with bladders.
Auto, no worries i understand! your going to like RM much better, i am really liking the traction of RM4.
I dont think i would start off with 10k on the RM though, you may end up back that high but i didnt even like 3k!!
So, what is it about the oil you're not liking? Is the diff unloading too much or not enough for you?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-15-2012, 10:16 AM   #3575
The Juice's Avatar
I'm doing that as well.
Tim M.
Old 01-15-2012, 10:23 AM   #3576
onekiwi's Avatar
Jörns using 600 wt shock oil in his diff im going to start around that I think
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 01-15-2012, 10:44 AM   #3577
Atomicsickness's Avatar
I installed the Diggity Designs carbon towers today. The bolted up fine and the quality is great.
I did run into a small issue. The tower is thinner than the shoulder on the shock standoffs. I had to drill out a 1mm washer to space it out so that they could be tightened down.
The inside front camber stud is at an angle, but does not rub.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 01-15-2012, 11:55 AM   #3578
onekiwi's Avatar
What lipo are you running? Are they EFRA/ROAR appoved?
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 01-15-2012, 12:05 PM   #3579
ReVtech Double Deuce and yes they are ROAR approved.
http://www.trinityrc.net/shop/index....&product_id=92
Old 01-15-2012, 01:06 PM   #3580
Autocratic's Avatar
Ya but doesn't he and you run on carpet?
Waaay over priced for a 60c shorty. If you're sponsored, you probably get them for a lot less, but to the general consumer that's just ridiculous.
ProMatch Racing. 60c shorties for $60 shipped.
I'm also pretty sure LiPo's are like how NIMH batteries are. You have a few manufacturers (IP/GP/EP for NIMH cells) and then everyone buys from those few companies. All these shorty LiPo's have the same cells, same case, different sticker. For someone to pay double the price for the same product is crazy.
Old 01-15-2012, 01:17 PM   #3581
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
You can find the rev tech for 89.99. That is still high. I just ended up getting the Protek 70c shorty which was still quite a lot of money but I could not find anything else that wasn't sold out other than the venom.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 01-15-2012, 01:19 PM   #3582
onekiwi's Avatar
True, still med-high grip like a few clay tracks
Are those lipos approved? 60 shipped is pretty good
XB2 CE
XB4 16
Sanwa
Hobbywing
Old 01-15-2012, 01:25 PM   #3583
Autocratic's Avatar
$60 shipped in the USA. Not sure what it work be for overseas.
As far as approval, no idea. My pack doesn't have a sticker.
http://www.promatchracing.com/
Great products though. I ran a ton of their NIMH batteries and never had a single issue with any of them.
Old 01-15-2012, 02:08 PM   #3584
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yep.. those promatch are the identical packs as the proteks from amain.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-15-2012, 02:54 PM   #3585
Autocratic's Avatar
Actually, the 60c Protek I have is slightly shorter, and weighs less than the 60c ProMatch I have. It's definitely a different case.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
