Like Tree36Likes
Old 01-07-2012, 08:40 PM   #3346
Anyone making the rear kick up plates
SHAUN GRIDER is offline   Reply With Quote
Old 01-07-2012, 08:46 PM   #3347
Autocratic's Avatar
Trader Rating: 26 (100%+)
Tresrey has one coming in 2/3 in early February probably, and there is a guy in the UK that made the 3/3 that he posted in this forum. I've PM'd him several times though and no response.
IMO, its a must have upgrade. The stock kickup plastic is just way too soft. I've gone through two already.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-07-2012, 11:36 PM   #3348
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by RacerMike42 View Post
I had it like that initially (in the rear thumbscrew position) but the chassis support has that notch in it so it doesnt sit on the battery brace. if the chassis brace didnt have the notch it would be fine.
I removed my CF brace and moved the battery strap to the rear position so you can see what I mean.
It has that notch to allow for different height batteries....with my Racers Edge shorty packs in my 210, the stock battery strap is almost snug against that notch. It's really a non issue that the strap doesnt fit snug under the rear brace though since the strap is pretty tight when the thumbscrews are in place. I actually ran an RB5 carbon strap in my Tamiya that never fit under the rear bulkhead and never had an issue with it.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 01-07-2012, 11:43 PM   #3349
hopsing's Avatar
How are you guys breaking the rear kick up block? Any pics? Just curious cause I haven't any problems with mine and took a very hard hit to the rear suspension and it broke the arm out by the hub. Do you guys have a lot of slop in the arm at that pivot/hinge pin? Mine only has about .5mm of movement.
Steve Butts
Old 01-07-2012, 11:58 PM   #3350
Autocratic's Avatar
My first 3/3 block cracked on all the way through the RR pivot hole. It was ready to break completely.
My second block, 1.5/3, did the same thing, but was on the side of the LR pivot hole.
I was at my LHS tonight and there was a guy racing with a 210 and his RR ripped completely out of the pivot hole. That was his second block as well.
The material is just too soft. His buggy doesn't have any slop in the suspension. I have slight slop in different places and really don't have any shims that would fill the gaps.
Old 01-08-2012, 05:45 AM   #3351
Slash'em1's Avatar
Look at page 174 in this thread.
I bought one and it fits perfectly. Its an awesome piece. Check it out! He's also located in Illinois.
Slash'em1 is offline   Reply With Quote
Old 01-08-2012, 05:48 AM   #3352
I have not broke a pickup plate but a guy at the track broke 2 of them it is pulling the pin out the side the hole is where the hinge pin goes is where it
Is happening
Old 01-08-2012, 07:32 AM   #3353
jurquhart's Avatar
Trader Rating: 22 (100%+)
any tips on how to get rid of some of the on power push in corners. I'm running RM3 and using J Concepts Rounders up front. For power I'm running a Tekin 8.5.
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 01-08-2012, 07:44 AM   #3354
Trader Rating: 53 (100%+)
you try or have any other front tire ? big fan of PL scrubs and AKA rebars
you can also try adding a little weight up front or move battery forward if you think u have the right tire
rkhess is offline   Reply With Quote
Old 01-08-2012, 07:49 AM   #3355
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
are you running the front axles trailing or inline ?
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 01-08-2012, 08:11 AM   #3356
Trader Rating: 520 (100%+)
I haven't had any problems with mine either, my car has been very durable, but I run on a tight lower, speed track..
There are a few ways, as I ran into this myself initially, and now mine has almost too much low speed steering and a small amt of on power push, but its really manageable, what type of soil/track do you run on?
flame56mx is offline   Reply With Quote
Old 01-08-2012, 09:12 AM   #3357
tom235's Avatar
I moved my hubs all the way forward and that made a huge diff. But I would try tire frt tires
tom235 is offline   Reply With Quote
Old 01-08-2012, 11:09 AM   #3358
Trader Rating: 91 (100%+)
Default in door set up
put 30wt. oil in front and 25wt. oil in rear. use 22 springs all way around red in front and yellow in rear. used a full size battery. the car worked great in 17.5 class
redracerd is offline   Reply With Quote
Old 01-08-2012, 11:15 AM   #3359
jurquhart's Avatar
I run on an outdoor 1/8 scale track medium size medium to loose bite. Just seems like she is pushing really far in the corners
John Urquhart
Old 01-08-2012, 11:17 AM   #3360
jurquhart's Avatar
I had thought the ribbed tires might work up front but your probably right I should change my front tires to something else with some bite
John Urquhart
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
