Like Tree26Likes
Old 01-06-2012, 09:01 PM   #3331
Trader Rating: 520 (100%+)
Originally Posted by Autocratic View Post
Flame you have any suggestions as to what I could use to replace the stock diff screw & nut? The stock screw would work, however just needs smaller threads. My tap/die set doesn't go to the required size for the Losi nut.
If it were me, and I happen to have Kyosho parts, I would try their nut and plastic cage, it's not as deep, but it holds a regular lock nut, so one may have to shim it out a bit before the ears break off..Hope this help a little.. If you found a tap, I would tap the nut, instead of cutting the screw with smaller diameter threads..
Here is a pic of the new electronics layout..
flame56mx is offline   Reply With Quote
Old 01-06-2012, 09:23 PM   #3332
Autocratic's Avatar
Trader Rating: 26 (100%+)
The Losi 22 diff nut setup is designed differently than I think you're imagining.
http://www.amainhobbies.com/product_...-Holder-TLR-22
That is the main reason I wanted to thread the stock 210 diff screw smaller.
I'm going to look for other solutions while still using the Losi holder. I really don't want plastic ears anymore.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-06-2012, 10:23 PM   #3333
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Attachment 858466
I was thinking about running my esc down the middle as well....
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-07-2012, 04:55 AM   #3334
Diggity's Avatar
Trader Rating: 29 (100%+)
Default New Carbon Fibre parts from Diggity Designs
4mm front shock tower, battery strap and steering rack / drag link are now available from Diggity Designs. Please check the website for more information, here are some pictures -
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 01-07-2012, 08:45 AM   #3335
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Default DEX210 Roller F/S
Guys I am leaving the 210 family. Gotta make room for the DEX408! I am selling as a roller. So if you know anyone interested please forward this link in the for sale section. Thanks....
DEX210 Roller
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 01-07-2012, 09:29 AM   #3336
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
i just ordered the rear just last week. it'll been nice to combine shipping with the front.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-07-2012, 10:02 AM   #3337
Slash'em1's Avatar
What I did was I bought the losi 22 Differential-Through-Screw-Nut-Set. Went to the hardware store and bought a nut for the Durango diff screw. Ground the nut down and glued it into the nut cap. So far it has worked.
http://www.amainhobbies.com/product_...Nut-Set-TLR-22
hope this make since. I'm at the track getting ready for the first heat.
Slash'em1 is offline   Reply With Quote
Old 01-07-2012, 11:45 AM   #3338
asc6000's Avatar
Trader Rating: 15 (100%+)
anyone in the US making these yet?, my buddie broke the ball stud mount off of his gearbox this morning and I have a 210 coming so it would be a durability hopup as well as a tuning option
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 01-07-2012, 03:17 PM   #3339
jurquhart's Avatar
Trader Rating: 22 (100%+)
Looks sweet are you making them? Also, who makes the best front & rear shock towers? I'm looking to get some up grade components for my buggy.
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 01-07-2012, 03:34 PM   #3340
MantisWorx's Avatar
Trader Rating: 28 (97%+)
my version will be out in a week or so , just recieved the donor gearbox the other day.
MantisWorx is offline   Reply With Quote
Old 01-07-2012, 04:11 PM   #3341
asc6000's Avatar
Marcus, I had you in my mind as soon as I saw his break. Will your version also work in the rear motor position? I need some of your stuff anyway, pm you later.
Those pics I pulled from OOPLE, I knew those euro guys would have one already.
This will be a must have part unlike some of the bling imo.
We opened a new indoor clay track today
http://www.facebook.com/TQSpeedway?sk=wall&filter=1.
Online video feed under the media heading here
http://www.tqspeedway.com/
Ayrton Senna
Old 01-07-2012, 04:48 PM   #3342
Autocratic's Avatar
Originally Posted by Slash'em1 View Post
What I did bought the losi 22 Differential-Through-Screw-Nut-Set. Went to the hardware store and bought a nut for the Durango diff screw. Ground the nut down and glued it into the nut cap. So far it has worked.
So are you using the Durango Diff screw or the Losi?
Also, anyone have gearing options for a 6.5?
Old 01-07-2012, 06:06 PM   #3343
MantisWorx's Avatar
not sure if it will work with mid motor or not, but since 90% of the owners run RM i will make the RM version first.
Old 01-07-2012, 06:28 PM   #3344
Slash'em1's Avatar
I am using the Durango diff screw. The only part I used out of the Losi Diff Screw set was this cap. I had to grind the nut down a little so it would fit in the cap and also used some CA glue to hold it.
So far it has worked perfect.
Old 01-07-2012, 06:35 PM   #3345
Autocratic's Avatar
I bought that same TLR part kit and the plastic nut holder broke the ears off too. I'm barely getting these things tight and just come apart. I was able to get the diff tight enough that I can overpower my slipper and turn the spur gear by hand while holding the diff out-drives solid, so hopefully this should be tight enough. This also means I have no ability to tighten it after running the car, so it's just going to have to work until someone gets diff parts instock. Will have to order a complete rebuild kit as this diff will probably never come apart.
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
