Like Tree23Likes
Old 01-04-2012, 12:56 AM   #3241
murky123's Avatar
Originally Posted by Autocratic View Post
The plastic spacers are also pretty crap. I have the aluminum gold spacers on order to replace everything + extras.
what are the partnumbers? the alu gold spacers
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 01-04-2012, 02:12 AM   #3242
Autocratic's Avatar
Trader Rating: 26 (100%+)
http://www.amainhobbies.com/product_...k-Spacer-Set-4
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-04-2012, 05:50 AM   #3243
jurquhart's Avatar
Trader Rating: 22 (100%+)
wow those little spacers are expensive but I bet they would look nice
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 01-04-2012, 08:02 AM   #3244
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by dirt_scooter View Post
Does anyone know a good final drive ratio for the 210 with a 6.5T?
If I geared the car 81S/26P that would give the car an 8.06 FDR per the 2.6:1 transmission. I am not familiar with a good FDR for off road; Any help would be greatly appreciated! Oh and btw I am assuming the car comes with an 87T spur stock based on what I've read here. Is this correct? Thanks guys
81/26 is a little high for a 6.5, I gear my 7.5 at 81/23 which is around a 9.1 final drive..... I would prob start your gearing around 81-21 and go up or down a tooth depending on track size, how it feels, and motor temp after a run.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 01-04-2012, 08:35 AM   #3245
onekiwi's Avatar
If you want spacers get the hiro seiko spacers
I got mine from xfactoryrc in the UK 2 for 6 spacers (I think)
They come in a 3 paired pack 2/3/4 etc
THere are more colours and different sizes
Here found the US distributor, cheaper than what I paid
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 01-04-2012, 08:39 AM   #3246
Originally Posted by hopsing View Post
This is a few days late, but you should have no problem getting more ride height than that with the kit springs. I measure my ride height right under the trans and basically right under the servo and have mine set at 24mm with the stock springs.... and yes the adjusters in the rear are pretty near maxed out, but there is still some adjustment left in them. Make sure your shocks arent binding, with no oil in them, they should feel pretty smooth with very little drag on them. Also make sure your suspension is free with no binding when the shocks are off the car...the rear hubs are a tight fit, if you just shove all the shims in it will probably bind up. I had to run a file slightly on my hubs to free it up before final assembly because it was pretty tight and wouldnt allow the suspension to move freely on its own.
A good answer is never to late.. Will definately recheck the possible binding bits.
Cheers for the tip..
Sleepstream is offline   Reply With Quote
Old 01-04-2012, 09:18 AM   #3247
tom235's Avatar
i used the losi ones since the durango's were BO. the losi number is TLR6019
tom235 is offline   Reply With Quote
Old 01-04-2012, 10:35 AM   #3248
Racerx336's Avatar
Trader Rating: 34 (100%+)
Couple of questions for you guys.
I just ordered a DEX210 to get back into 2wd buggy for the winter months. I am planning on running the new Viper system with an 8.5. What would be a good starting point as far as gearing?
Also, I am going to be running full size lipo packs, so what is a good starting shock setup for the car while keeping that in mind? Are there any popular spots where people are adding weight to the buggy? I will mostly be running on a medium traction indoor track with rather large jumps.
Thanks in advance!
-Andrew Clark-
/ Nemo Racing USA /Agama / Pro-line Racing / VP Powermaster / RC Shox / Triton RC / Dutch Oven Designs / Paradise Air / TIX RD /
Racerx336 is offline   Reply With Quote
Old 01-04-2012, 10:52 AM   #3249
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
sent you pm racerx336
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 01-04-2012, 11:32 AM   #3250
21-23t is a good starting point with the 8.5 i'm currently running the 22t.
cm.stites is offline   Reply With Quote
Old 01-04-2012, 12:08 PM   #3251
Trader Rating: 19 (100%+)
Thanks in advance!
If your budget allows I would really consider some shorty packs. The ability to move the weight around in the chassis is a major plus, and honestly made a huge improvement in how the car feels/drives. With a full size pack there was so much weight in the back that the car always felt too locked down in the rear, causing a push on corner entry. The shorty allowed made the car steer in much better while still having enough rear traction to confidently drive through the corner.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 01-04-2012, 12:19 PM   #3252
lockmouth's Avatar
Trader Rating: 33 (100%+)
+1.. this is what I built my car useing
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 01-04-2012, 01:00 PM   #3253
hopsing's Avatar
+1
Steve Butts
Old 01-04-2012, 01:42 PM   #3254
Racerx336's Avatar
I plan to try short packs soon, but at the moment, 1/10 is really just something for me to use for fun as well as practice and driving time rather than putting tons of time on my 1/8th stuff. Im sure I will get back into it and get deeper and deeper though, it always happens!
-Andrew Clark-
Old 01-04-2012, 09:55 PM   #3255
HSLD's Avatar
Can you tell me who makes those offset turnbuckles in the pic?
HSLD is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
