Like Tree23Likes
Old 01-03-2012, 08:42 AM   #3226
Slayer1904's Avatar
added photobucket IMG, instead of other RC site.
Slayer1904 is offline   Reply With Quote
Old 01-03-2012, 09:02 AM   #3227
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by Sleepstream View Post
Where exactly do people measure their ride height from?
Struggling to get anything above 20 from kit springs in the rear. Spring preloads are almost maxed out. Anyone having the same issues?
This is a few days late, but you should have no problem getting more ride height than that with the kit springs. I measure my ride height right under the trans and basically right under the servo and have mine set at 24mm with the stock springs.... and yes the adjusters in the rear are pretty near maxed out, but there is still some adjustment left in them. Make sure your shocks arent binding, with no oil in them, they should feel pretty smooth with very little drag on them. Also make sure your suspension is free with no binding when the shocks are off the car...the rear hubs are a tight fit, if you just shove all the shims in it will probably bind up. I had to run a file slightly on my hubs to free it up before final assembly because it was pretty tight and wouldnt allow the suspension to move freely on its own.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 01-03-2012, 09:20 AM   #3228
tomdav's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Slayer1904 View Post
Hey guys, running into a little bit of a problem with my build.
In putting together the trans and adding the internal (silver) spacer to the top shaft the bearing actually pushes out of the the plastic piece that holds the motor plate to the transmission and won't allow any top shaft movement.
Now if I take the spacer out everything goes together smooth and the transmission spins freely. I've been told the spacer does need to go in there but for whatever reason it's just not working.
Anyone else have this problem?
Running the mid-motor 3 gear setup.
here is a picture of the problem, you can see the bearing pushing out and thats not even tight (or threaded). That's only pushed onto the lip of the actual gear box. if I tighten it up or even thread the top 2 motor plate screws it's almost an instant drive line bind.
thanks for any tips,recomendations.
Measure the small topshaft bearing. The kit calls out for a 5x8x3 but mine came with a 5x8x2.5 and has no play. Also measure your spacer when its out and I'll check it against mine to see if its off. Need to flip my outdrives again, one side is gouged up a bit after two races. I think its my Agro driving style!
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 01-03-2012, 10:16 AM   #3229
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Picture of the car from this weekend. The track was very sticky.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 01-03-2012, 10:57 AM   #3230
Jmuck69's Avatar
Dirty!!!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-03-2012, 11:59 AM   #3231
JeremyHarris's Avatar
Which wing are you using?
Jeremy G. Harris
Pro-Line-RCWrapz-LFR-SXT-KustomRCGraphics-Airtronics-Team Associated-Reedy-LRP-Superiorhobbies.com
JeremyHarris is offline   Reply With Quote
Old 01-03-2012, 12:03 PM   #3232
Proline
http://prolineracing.com/performance...ad-wings-2-pk/
Old 01-03-2012, 02:09 PM   #3233
Autocratic's Avatar
I had to do this with every suspension point on the car. The plastic spacers are also pretty crap. I have the aluminum gold spacers on order to replace everything + extras.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-03-2012, 02:27 PM   #3234
jurquhart's Avatar
Trader Rating: 22 (100%+)
I've got my buggy all together now I'm just waiting on the body to get painted so I can finally drive the buggy on the track
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 01-03-2012, 04:37 PM   #3235
Slayer1904's Avatar
Default measurements
^^^ is the bearing that was in the gear box for the top shaft.
Old 01-03-2012, 05:06 PM   #3236
tomdav's Avatar
Mine measured the same. I just measured the raised(keyed) section of the topshaft and its 12mm. My larger bearing measures 4mm in width.
Are you using any other internal spacers besides the 11mm one?
Tom
The Couve, WA
davesrctracks.net
Old 01-03-2012, 09:35 PM   #3237
So what motors is everyone running in the 210?? I'm thinking about getting one, but i'm on a budget. Would i be stupid to even think about putting my castle 3800 sct system in one? thanks!
TLR 22 Viper VTX10 VST 17.5
Jato 2.5r
tjbgtv8 is offline   Reply With Quote
Old 01-03-2012, 10:34 PM   #3238
Trader Rating: 19 (100%+)
The 210 has great rear traction, but for 2wd buggy I would definitely go with a sensored setup. Plus an 8.5 can give you all the power you'll ever need if your esc has boost capabilities. I see that 1410 being very hard on the drivetrain too with all of the torque it makes- that little motor rocked in our 4wd sc trucks, couldn't imagine how insane it would be in a buggy.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 01-03-2012, 11:08 PM   #3239
dirt_scooter's Avatar
Does anyone know a good final drive ratio for the 210 with a 6.5T?
If I geared the car 81S/26P that would give the car an 8.06 FDR per the 2.6:1 transmission. I am not familiar with a good FDR for off road; Any help would be greatly appreciated! Oh and btw I am assuming the car comes with an 87T spur stock based on what I've read here. Is this correct? Thanks guys
As seen above a urinal: What are you looking up here for? The real joke is in your hands.
dirt_scooter is offline   Reply With Quote
Old 01-03-2012, 11:08 PM   #3240
Thanks for the reply! Perfect, I was thinking about getting an 8.5 sensored setup like the hobbywing xerun for it. And yeah the 1410 worked perfect for my 4x4 sc but now that I think about it, it will have way too much torque for the buggy. I think i'm going to order my 210 tomorrow!
Jato 2.5r
St Ives RC Club B4Bandit Australian Racing 16563 Yesterday 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
