Like Tree33Likes
Old 12-31-2011, 09:46 PM   #3166
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by cm.stites View Post
you shouldnt ever need to use droop screws to get ride height. i would check the shocks and make sure theres no binding.
That's not true. If the screws are incorrectly and SEVERLY limiting down travel, it can give you a drastic low ride height. He's not saying use your droops screws to tune , but to make sure they aren't in the way.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-31-2011, 09:57 PM   #3167
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Cpt.America View Post
If you are running on damp wet slick clay, you should probably be running full dremeled slicks, in which case you need no traction compound.
a first class clay track will have a bench mounted belt sander for customer use so you can buzz all of the tread off those brand new tires you just spent $40 on
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 12-31-2011, 09:58 PM   #3168
arn671's Avatar
Trader Rating: 14 (100%+)
Default Big bore shocks
Cpt.America, wondering if you have an idea of whether or not the Durango BB shocks would work on an RB5 SP2? I currently have the K-car but was very interested in trying the 210 to compare. If the shocks work on the K-car it would be a bonus!
I remember early on you were having diff isues? I was on vacation for a while and haven't been able to follow the progress, obviously the car is working well for you now, what was the issue?
What are your thoughts on the Rb5 compared to the 210? Usually racing at TRCR but am planning to head to BRCR hopefully soon.
Thanks.
Happy New Year
arn671 is offline   Reply With Quote
Old 12-31-2011, 10:45 PM   #3169
When hes telling him to wind them in to gain ride height then he is telling him to set ride height with the droop screws.Which is not how to set ride height.
he says to wind them down to get ride height if you wind them DOWN you are using them to raise the arms to set ride height which is a no no.
cm.stites is offline   Reply With Quote
Old 01-01-2012, 04:27 AM   #3170
Didnt know my question was complex.. lol.
Let me rephrase my 2 questions.
Which part of the chassis do you put the ride height gauge under?
Shock has No binding.. I can lift the rear end of the car without the tires lifting of the ground for a fair bit(above 30mm ride height gauge) in a smooth action.
Read somewhere on the thread had to wind down the shock collars all the way down to get 22mm ride height.
Sleepstream is offline   Reply With Quote
Old 01-01-2012, 06:09 AM   #3171
Trader Rating: 520 (100%+)
Thanks.
Happy New Year
I know this question wasn't aimed at me, but if you dont mind I can offer some insight..The shocks would work, but they will not be a direct bolt on, as the shafts are quite a bit longer and would have an extreme amount of internal limiting, the bodies are similar in length. You would also have to do some testing to get them to feel/work similar on the RB5 as well. The diff issues involved the thrust bearing internal cir-clip. The one that comes with the kit is stainless, and has very little spring, so once it has been compressed it doens't like to rebound. It is basically is a one time (carefully) use, and then replace. Most have replaced with a spring steel clip, and that seems to resolved the issue. We found the Fastenal or Xray clips work great. The Rb5 and dex210 to me are very similar, the Rb5 has more on power steering, and the 210 has more on power rear traction, owning both and driving them back to back, but the 210 seems more like a tuners car.
I check mine towards front chassis behind the front arms, and the rear of the car. It really depends on which gauge you have, and how/where works best for you. And getting the right ride height depends on which springs you run, as different oils, springs rates, battery packs, shock mount positions-etc will all play a part in ride height, so my shock collars will different than yours, theirs, etc. I would take what you read on here as a guideline, and add to the routine you may already have...Happy new year, and good racing...
flame56mx is offline   Reply With Quote
Old 01-01-2012, 03:50 PM   #3172
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Got a couple questions for you guys:
1. I'm already picking up some Losi Pink BB springs for the rear of my 210, what other rates (front and rear) would be good to have on hand ?
2. will Losi 22 pistons work in the 210 shocks
other than that I'm loving this car so far
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 01-01-2012, 04:59 PM   #3173
tomdav's Avatar
Trader Rating: 42 (100%+)
No, the Durango has a larger diameter piston.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 01-01-2012, 08:24 PM   #3174
rcfiend's Avatar
Trader Rating: 29 (100%+)
Has TD addressed the weak rear shock towers yet? If not what are you guys doing to overcome any issues with the rear shock towers. I'm just about ready to pull the trigger on one.
rcfiend is offline   Reply With Quote
Old 01-01-2012, 08:35 PM   #3175
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
http://www.diggitydesigns.com/D3_Off...rango_210.html
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 01-01-2012, 08:39 PM   #3176
rcfiend's Avatar
Originally Posted by Briguy View Post
Are you guys purchasing front and rear shock towers from dignity designs?
Old 01-01-2012, 08:41 PM   #3177
Jmuck69's Avatar
The stock rear shock towers are strong along with the rest of the car.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is online now   Reply With Quote
Old 01-01-2012, 08:41 PM   #3178
rcfiend's Avatar
Is there anyone here that races at West Coast? If so how is your buggy fairing against the 22's and B4.1's?
Old 01-01-2012, 08:43 PM   #3179
Briguy's Avatar
There are a lot of people having problems with the rear tower and is an issue .
Royal R/C & Hobby
Old 01-01-2012, 08:43 PM   #3180
Trader Rating: 19 (100%+)
I wouldn't call them weak- like any car there are certain parts that people break more often than others. My brother's car still has all of the original parts on it except for a steering bellcrank, and he has done quite a bit of "durability testing" as he got comfortable with the car. We are very satisfied with the car's durability overall.
Tresrey has CF rear towers out for the car, and also CF front towers, battery strap, and steering drag link as well as aluminum front bulkhead and FR hinge pin mount.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
