Like Tree23Likes
Old 12-30-2011, 04:06 PM   #3151
Autocratic's Avatar
Trader Rating: 26 (100%+)
Anyone have an issue with ball diff nuts? Mine broke on the first rebuild. Anyone know of an all-metal diff nut?
Not that it matters, though. Can't race anytime soon since this retard in an SCT demolished my front shock tower because he can't watch what's in front of him on track.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-30-2011, 07:09 PM   #3152
Damit's Avatar
Trader Rating: 22 (100%+)
Default Diff gears
Originally Posted by bbgjeeps View Post
It comes from ARRMA which is a sister company of Team Durango.
It drops right in with no shimming needed. I run it with 3000CST oil and it works great. You can get all the parts from Tower Hobbies for about $24.
http://www3.towerhobbies.com/cgi-bin...MA&S2=&S3=&S4=
You'll need the ARRMA Diff Gear Idler Gear Set, ARRMA Diff Gear Outdrives and the ARRMA Diff Gear Maintenance Set. It all goes together very easy, just add the diff oil of choice.
Just make sure you put the 210 Diff bearings on the idler gear before you install the outdrives as the bearings won't fit over them.
BTW, the ARRMA slipper clutch pads are the same as the 210's. I haven't tried their spur gears yet....
Thanks Mate,
Really appreciate it.
Chris
B6d 2wd / B64d 4wd - SJF01 Street Jam F1 - Tamiya Mini v2
Futaba-HW-LRP-Lunsford-Reedy/Associated
South Australian Member: AERCCC #16 and ARCR 9098
Damit is offline   Reply With Quote
Old 12-30-2011, 08:16 PM   #3153
Trader Rating: 520 (100%+)
Hmm, I had mine apart and re-greased my thrust bearings and didnt have any issues with the nut, but it's a possibility. I haven't seen anything as far as an aluminum one. I have a CF front tower on mine, but I do have a couple spare stock ones if you cant find another..
flame56mx is offline   Reply With Quote
Old 12-30-2011, 09:12 PM   #3154
Autocratic's Avatar
From what I've found online you can't get just the nut. There's a thrust kit, which is the nut, spring, and screw.
Losi has an aluminum nut for the 22. Going to hit up my local hobby shop and look around and see what I can find. I think the XXX-CR nuts would fit too.
This is the first EVER thrust diff nut I've broken, and all of the previous ones have been plastic as well.
Old 12-30-2011, 09:24 PM   #3155
If I remember correctly, the Losi thrust screw/nut is smallish in diameter, but keep us in the loop if it works. I like the way Kyosho diff's are setup, basically a replaceable plastic cage (comes with gear set) with a normal nylon lock nut, but I cant see it working in this case..
Old 12-30-2011, 09:49 PM   #3156
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Thanks Arno from petit RC for throwing this together for me in one easy to find page:
http://www.petitrc.com/setup/durango...217/index.html
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-30-2011, 10:55 PM   #3157
rcman182006's Avatar
Send a message via Yahoo to rcman182006
Well got a good first night of racing on my beast, broke the rear tower due to driver error (shiny side first into the wall) other than that and a few minor tweaks the car felt 1000x better than my old SP2
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 12-30-2011, 11:33 PM   #3158
spiro's Avatar
Default Essential 210 hop-ups?
I've seen several nice hop-ups thoughout the many pages of this thread. As I'm currently waiting for my full line of Durangos to arrive, I'd like to prepare. There are many nice-to-have items, but I'm looking for the gotta-haves. After some time of testing, what would you say are the essentialts of must-have upgrades that I can order even before the build?
Now, I'm off to the 410 thread to ask the exact same question there for the V3.
[ DEX210 ]|[ DEX410 ]||[ Futaba 4PK ]
spiro is offline   Reply With Quote
Old 12-31-2011, 07:16 AM   #3159
The normal spares, all the tuning parts (apart from springs) are included in the kit.
-Shock Towers, wishbones, hubs.
The car is very durable, you have to hit things very hard to break it! A local racer has owned a cougar, 201, X factory X6 (mid motor b4 conversion), B44 and a 22, and has commented that the DEX210 is the strongest and most reliable car he has owned and he races it everyweek.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 12-31-2011, 09:26 AM   #3160
Super Moderator
The two most important spare parts on this car IMO, are rear shock tower, and rear inner toe blocks.
- RCSpecialties -
Old 12-31-2011, 11:11 AM   #3161
junebugg's Avatar
Just wondering what shock springs you guys would recommend for a mid motor setup on indoor asphalt . I recall reading that some of you guys were running Losi springs. If you recommend Losi,could you tell me which ones and if not please tell me which Durango springs would work. THANKS
Kyosho MP9 TKI2
Pro Mod V-spec
junebugg is offline   Reply With Quote
Old 12-31-2011, 01:46 PM   #3162
Autocratic's Avatar
I hear the kit springs are pretty good for mid-motor on high traction surfaces.
Whenever I build a kit I always start with the kit setup and work from there.
Most people run Losi springs because that's what is available to them and they need something different than the kit springs.
I run Losi's because I don't like having all my springs the same color and only a small line of paint on the coil to tell which spring it is.
Old 12-31-2011, 06:55 PM   #3163
Default Ride Height
Where exactly do people measure their ride height from?
Struggling to get anything above 20 from kit springs in the rear. Spring preloads are almost maxed out. Anyone having the same issues?
Sleepstream is offline   Reply With Quote
Old 12-31-2011, 07:38 PM   #3164
Damit's Avatar
Default Ride height
Two words : droop screws
Wind then in to gain more ride height
Old 12-31-2011, 08:26 PM   #3165
you shouldnt ever need to use droop screws to get ride height. i would check the shocks and make sure theres no binding.
cm.stites is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
