Like Tree26Likes
Old 12-28-2011, 01:12 PM   #3106
Konich's Avatar
Not yet as I'll have to get one first in order to put them on the scale.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 12-28-2011, 01:18 PM   #3107
Autocratic's Avatar
Trader Rating: 26 (100%+)
Cool deal. Definitely waiting on that + the aluminum rear toe mount & front bulkhead. Already have a nice list building up.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-28-2011, 01:21 PM   #3108
Konich's Avatar
Tresrey Japan has been working hard on parts for the 210. You can be sure Tresrey USA will have the items first and a massive stock as well
Old 12-28-2011, 01:22 PM   #3109
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I already have the towers, I ordered them straight from the man who makes them.
They are very nice!
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 12-28-2011, 02:05 PM   #3110
Trader Rating: 19 (100%+)
The 410 cf chassis was a few grams less than half the weight of the original- I would guess the 210 chassis will be similar to that.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 12-28-2011, 02:18 PM   #3111
Autocratic's Avatar
Anyone have a gearing for running a brushed P94 12x3? I'm on a backup ESC (Novak Atom) and this is the only motor I have to run with it. Was hoping to race this week but have no idea how to gear brushed motors on this car.
Old 12-28-2011, 02:20 PM   #3112
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
That is great news... this car needs a diet. if the carbon chassis is that much lighter, I will certainly be ordering one! They key will be protecting it...
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-28-2011, 02:22 PM   #3113
Super Moderator
Originally Posted by JOJOHAMBONE View Post
How will that affect the handling of the car?
The more wing you run, the more pressure you generate on the rear tires. The faster the car is going, the more pressure you generate, in an exponential curve.. So in general, more wing = less steering at medium and high speeds, more rear traction at medium and high speeds. It also affects pitch balance of the car in the air. All of my testing with this car so far, at least for me, pushes me to run less and less wing. YMMV
- RCSpecialties -
Old 12-28-2011, 03:03 PM   #3114
jimkoimanis's Avatar
Bugleboy makes under trays for the 210 and 410 go pm him he is on the aussie thread look for the st Ives thread
tamiya tao2 gt4,fav,bear hawk,team associated sc10, b4.1, sc18, tc5r,t4 j82. cougar sv pro dirt spec durango dex210 cat sx3 Schumacher k1 tekin gen2 d3.5 17.5 X-ray 808e xray xb9 13 spec os speed 21xz-b spec2
durango 410darc spec orion r10 pro orion vst
sponsored by habib's bodies
jimkoimanis is offline   Reply With Quote
Old 12-28-2011, 03:10 PM   #3115
tomdav's Avatar
Trader Rating: 42 (100%+)
Well after five full race days and countless packs I broke my first part. Busted the upper mount tab off the gear cover. Landed motor first off our massive triple. I also replaced the inner rear ballcups after they stretched out from many high speed tumbles.
For grins I put a Orion 6.5 in and was able to lay the power down, well almost. Wheelie king! Diff still smoooth.
I want to try a shorter rear tower. Maybe get a more progressive feel from the rear end. If you bottom out the chassis you still have a ton of up travel from the wheels in stock form. The rear spring is no where near being fully compressed. By no means do I think its required but as someone who usually just throws on a setup and just runs Its nice to try stuff a little outside the box.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-28-2011, 03:18 PM   #3116
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
He has his own site now:
http://bugleboyracing.com/
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 12-28-2011, 03:27 PM   #3117
1armed1's Avatar
With the stock spur start at a 21 and check your temps a couple minutes into the first run.
I usually ran 8 over with my B4 (81 spur) and a 12x2 on pretty decent sized tracks.
A 21 would be just under and a 22 just over the equivalent with a 81 spur.
Dayton
Old 12-28-2011, 04:01 PM   #3118
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
thanks so for a tight track or indoors less wing the better i will be running it for the first time saturday (weather permitting) so if it pushes i will cut the wing.
Blake Morris
-521 Designs-Tony's Hobby+Video-R&L R/C Products-Richards and Lees Cabinets-
**2014 XB4**Tekin RSX, REDLINE 5.5t, Protek Servo, Revtech Formula X Batteries
JOJOHAMBONE is offline   Reply With Quote
Old 12-28-2011, 04:17 PM   #3119
Default shocks
is it normal on this buggy to have to compress the rear shock to put the bottom screw in? the rear shocks seem very long and they cant compress all the way because of the pistion hitting the cap is that normal? i was just wanting to make sure.
thanks Blake
Blake Morris
Old 12-28-2011, 04:22 PM   #3120
Trader Rating: 520 (100%+)
thanks Blake
If the arms aren't at full droop, then you will have to compress the shocks to get the screw in. So,if you have your droop screws out at all, you will have to compress them a little.
flame56mx is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 Today 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
