Like Tree27Likes
Old 12-25-2011, 04:05 PM   #3061
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
i would start with a 25 with ur 8.5 motor
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 12-25-2011, 04:32 PM   #3062
Autocratic's Avatar
Trader Rating: 26 (100%+)
Originally Posted by ronsand View Post
- Check that the sub trim is close to zero (move servo arm if needed)
- set the controll links and servo arm at correct lengths and angles.
- set the endpoints on your radio.
Finished
I adjusted the endpoints on the radio and re-centered the steering trim. Looks better now.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 12-25-2011, 06:41 PM   #3063
Been following this thread for all 200 pages and like the looks of this car. Has anyone put it on scales and checked rear percentages yet?
Also how long are the rear cv shafts from inner pin to outer pin? Thanks
Nick
Cautrell05 is offline   Reply With Quote
Old 12-25-2011, 10:51 PM   #3064
Trader Rating: 16 (100%+)
I have a dex210 in the fs section for any one intrested.
krawlingxj is offline   Reply With Quote
Old 12-26-2011, 05:29 PM   #3065
JOJOHAMBONE's Avatar
Trader Rating: 31 (100%+)
Default DRIVESHAFT HITTING T NUT
Hi im building my 210 and im doing the turnbuckles and noticed on the left side the drive shaft end is huitting the t-nut it pushes the camber out positively so i cant have negitive camber. is this normal because i havent got done to break in my diff my diff is tight so should it be in farther. and dont know if when i break it in and i will probly have to tighten it more if it will go in more. i used team durangos diff build guide to build the diff.
thanks Blake
Blake Morris
-521 Designs-Tony's Hobby+Video-R&L R/C Products-Richards and Lees Cabinets-
**2014 XB4**Tekin RSX, REDLINE 5.5t, Protek Servo, Revtech Formula X Batteries
JOJOHAMBONE is offline   Reply With Quote
Old 12-26-2011, 05:34 PM   #3066
thanks Blake
pic hope that helps
Blake Morris
Old 12-26-2011, 05:47 PM   #3067
the tnut should be farther in.
cm.stites is offline   Reply With Quote
Old 12-26-2011, 05:59 PM   #3068
Trader Rating: 520 (100%+)
Yeah, should be further in, and on the other side of the car, otherwise it'll likely loosen itself. By the way, the slipper nut looks a little on the tight side as well..I wish my car was as clean as yours..
flame56mx is offline   Reply With Quote
Old 12-26-2011, 06:05 PM   #3069
symmetricon's Avatar
Trader Rating: 27 (100%+)
Hey guys, I finished my build, and it was amazing... besides some of the instructions and searching the parts tree. Anyways, I am trying to figure out what turn motor to run and what gearing to use. I can borrow a 8.5T from a friend fyi. I run on a large track with mid 30s laps.
Sorry I haven't searched, I'm at the inlaws in amarillo, and am using my phone, and it takes 5 min to load a page... if I am luck.
Thanks, jason
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-26-2011, 06:05 PM   #3070
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Attachment 853083
Really? I have been running mine on that side for a few months now. Looks like he is running RM3. Run it in then tighten it up, should be fine. I second the slipper nut.........
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 12-26-2011, 06:08 PM   #3071
Attachment 853083
are the instructions wrong because they show the t nut on the side of the slipper adjustment. should i tighten it down more or just wait untill i break it in. and i would break it in the same way as racer53 shows correct? what should i do?
Blake Morris
Old 12-26-2011, 06:09 PM   #3072
yes im running rear motor three gear
Blake Morris
Old 12-26-2011, 06:10 PM   #3073
i was always told to run the diffnut on the opposite side of the slipper otherwise they eventually loosen themselves.
Old 12-26-2011, 06:41 PM   #3074
Yeah, not too many cars have the slipper nut opposite the slipper plates, but if you think about it, hard acceleration may turn the nut (possibly) if it's on the left side. If the nut is on the right side, it wont be able to loosen. I didnt look at the manual though, just the rule I have always used. I will go and look at it though, but I dont think the rules of physics have changed, even with this car..lol
Old 12-26-2011, 07:11 PM   #3075
Trader Rating: 19 (100%+)
We have always run the diff nut on the left (driver's) side of the car, both in 3 and 4 gear configuration.
On another note, Cush had his first runs today with his new Racer's Edge shorty packs and what a difference. We've got some more tuning to do, but the car is night and day different. Running the battery full forward eliminated the push he has been fighting and freed up the rear end- with a full size stick pack the rear end was just too locked down. So far the shorty packs seem to be an improvement so we'll see how racing shakes out on Wednesday.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
