Like Tree28Likes
Old 12-15-2011, 07:20 PM   #2836
mjealey's Avatar
I run 26/75 with an rs pro, 13.5 Tekin and a little boost. The ESC and motor doesn't even get above 130 and it is surprisingly quick for a 13.5!!!!
Kyosho Inferno MP9 TKI 3 - OS Speed .19 & .21 - KO Propo
WinterBlast 2012 - Knoxville, TN - Chilhowee Park
10/27, 11/10, 12/8, 01/05, 02/02, 03/09*
mjealey is offline   Reply With Quote
Old 12-15-2011, 07:23 PM   #2837
I'm looking to get my first buggy! How would you guys comopare the dex210 to the tlr22 or Ae b4.1. Thoses were the ones i was considering. I'll be running it in the 13.5 class on indoor clay. Thanks
shark2288 is offline   Reply With Quote
Old 12-15-2011, 07:31 PM   #2838
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by NUZUM View Post
concerning springs .... most AE drivers run rear 1.90 or 2.10 spring sets and front 2.80 or 3.20 ....so some of you say the spring rates are off on the 210 are not really true... the back is really close at 1.85 (light blue) or go to the 2.05( light red)............ The front is a little stiff at 3.50 (dark blue) so a 2.85 (black) or the 2.65 ( light red ) will get you close to the spring rate of a B4.1
No offense, but this post is short sighted. The balance of the dex is nothing like the B4... the rear end of the dex is considerably heavier.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-15-2011, 07:32 PM   #2839
Trader Rating: 520 (100%+)
Having driven those three, (B4) not a .1, I like the 210 the best, but atm the moment it doesn't turn as well as a B4. I didnt get along with the 22, it had no rear traction on our med bite tracks. The 210 has more rear tractionthan any car I have driven, even after dialing some of it out..
flame56mx is offline   Reply With Quote
Old 12-15-2011, 07:35 PM   #2840
Super Moderator
B4.1 -
Twitchiest car
Feels fastest
Easiest to work on
Cheapest parts
Hardest to drive
22-
More stable than the B4
Easiest to drive
Not as nimble as others
Worst diff
Not too hard to work on
dex210-
As stable as the 22, but feels fast almost like the B4
Hardest to work on
Parts support is sketchy
Best diff on the planet (once you learn it)
Best shocks
- RCSpecialties -
Old 12-15-2011, 07:35 PM   #2841
Trader Rating: 27 (100%+)
Ok well as of now I dont have any of the other spurs, so with a boosted 17.5 what would you run for a pinion I am gonna go get some tomorrow.
C_Money is offline   Reply With Quote
Old 12-15-2011, 07:37 PM   #2842
i've been hearing that more and more about the 22. No rear grip. I don't like that. do you think you can get the dex210 to turn like the b4? Or is that a product of having so much rear grip?
Old 12-15-2011, 07:37 PM   #2843
Super Moderator
The largest you can fit with the factory 87 tooth spur, is a 25. You will still be way undergeared.
I have my dex turning almost as well as a B4... almost... More work this weekend.
- RCSpecialties -
Old 12-15-2011, 07:39 PM   #2844
So what is the best setup then? I will look around, What would you all use with a boosted 17.5? spur and pinion?
Old 12-15-2011, 07:41 PM   #2845
Originally Posted by Cpt.America View Post
B4.1 -
Twitchiest car
Feels fastest
Easiest to work on
Cheapest parts
Hardest to drive
22-
Easiest to drive
Worst diff
dex210-
Hardest to work on
Best shocks
Good summary. Sounds like its the better all around car out of the 3. parts support could make it scary though.
Old 12-15-2011, 08:10 PM   #2846
Super Moderator
Right now there is no "best" setup... just like their isn't a "Best" setup for any other car... it depends on your track, tire, surface, traction level, and drive style.
I think the 210 is the best car out of the three, with the B4 just barely behind it. But take into consideration that the B4 is almost a decade old! If the B4 didn't develop slop so easily, and had a decent set of big bores, it would be just as good as the 210. I personally don't like the 22 for a number of reasons, but I would rock the B4 just as easily as the 210.
For some people, as long as the car is good enough, part and setup support is the most important thing when picking a buggy, which would put most of those drivers behind the B4. I myself love being the guy figuring out the setup, and don't mind buying and stocking parts ahead of time, and don't mind a buggy that is harder to setup and work on... so for me, the 210 is better. For somebody brand new to the hobby, I would recommend the B4 before the 210 any day.
- RCSpecialties -
Old 12-15-2011, 08:11 PM   #2847
Ok I would just like to know about what gearing you people would do for a boosted 17.5.. I dont have a ton of gears so thats why I am asking.
Old 12-15-2011, 08:20 PM   #2848
Super Moderator
75 / 26 - 29
Depending on your boost settings.
- RCSpecialties -
Old 12-15-2011, 08:36 PM   #2849
OK well I run the r10 and crank everything about max, as far as spur gears go I have 83,87,75,69
Old 12-15-2011, 08:57 PM   #2850
Super Moderator
The question might be better asked on the R10 thread, as many here wont be familiar with what type or amount of dynamic timing that esc gives.
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
