Like Tree26Likes
Old 12-15-2011, 10:50 AM   #2821
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by sparkwraps View Post
Agreed! I was thinking I could tune around it.
i missed that memo!! so i am assuming the springs are too soft for RM right? whats a good losi spring to try? white?
MantisWorx is offline   Reply With Quote
Old 12-15-2011, 11:05 AM   #2822
TAMAK's Avatar
Trader Rating: 28 (100%+)
Losi red front / Yellow rear on a fairly loose track. I also had silver rear when the traction was not there. Its all about the balance of your car and the track conditions.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 12-15-2011, 11:08 AM   #2823
hopsing's Avatar
Trader Rating: 13 (93%+)
The stock fronts are too stiff and the rear is a little too soft........I personally have been doing very well with the stock springs ON MY PARTICULAR TRACK, FOR MY DRIVING STYLE. I feel I could maybe use a softer front spring but for now its working great and I've been able to tune the car to the springs and its competitive. Once I get the car to where I think it cant get any better, THATS when I start messing with different springs.......
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-15-2011, 11:12 AM   #2824
Trader Rating: 27 (100%+)
Originally Posted by murky123 View Post
I would try 1.2 four holes or 1.1 six holes
I thought the kit came witl light and dark blue springs, so how did you build it by the book with red and green?
red and green are option springs, not the stockers
The guy eho built it used those springs.. I will glue some holes in the pistons and see
C_Money is offline   Reply With Quote
Old 12-15-2011, 03:07 PM   #2825
tomdav's Avatar
Trader Rating: 42 (100%+)
Originally Posted by stavman View Post
WHAT IS UP TOM!!!!!!! Long time no see buddy
Ya RW's come from UK, correct? May have ta check on an account with them soon
Thanks for the info
Stav
Its been a nice December so far, lots of sun. Today its wet, grey and cold and I want to move south.
Your going to like the way the 210 handles, very forgiving.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-15-2011, 03:46 PM   #2826
NUZUM's Avatar
Trader Rating: 18 (100%+)
concerning springs .... most AE drivers run rear 1.90 or 2.10 spring sets and front 2.80 or 3.20 ....so some of you say the spring rates are off on the 210 are not really true... the back is really close at 1.85 (light blue) or go to the 2.05( light red)............ The front is a little stiff at 3.50 (dark blue) so a 2.85 (black) or the 2.65 ( light red ) will get you close to the spring rate of a B4.1
EA MOTORSPORTS /TRINITY/ EPIC/ REVTECH/B-FAST R/C PERFORMANCE/RADIOPOST
NUZUM is offline   Reply With Quote
Old 12-15-2011, 04:11 PM   #2827
rcman182006's Avatar
Send a message via Yahoo to rcman182006
what pinion should I run w/ an un-boosted Orion V2 13.5 and 75T spur? Running a Tekin RS speedo if it helps
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 12-15-2011, 04:14 PM   #2828
Trader Rating: 520 (100%+)
I blocked off the piston holes on my car at the beginning, and used a toothpick. I dipped it in CA, and then cut it off flush, then glued the end to seal it. I ended up using less glue, and sped up the process a little bit..
I am running 75/26 with a 13.5 and a little boost, using and Orion speedo, but it should be close, as I am running very low temps on mine, even after 15min. I would start at 75/24 and check temps a few minutes in.
flame56mx is offline   Reply With Quote
Old 12-15-2011, 04:25 PM   #2829
Originally Posted by jurquhart View Post
Just wanted to let you all know I emailed avid about a bearing kit and they put one together. It is $25 and then 3 and change for shipping in US. here is the link
http://www.avidrc.com/flexkit/?kit=371&kitname=DEX210
Hope this helps
Looks like they also sell this
Old 12-15-2011, 06:31 PM   #2830
Originally Posted by C_Money View Post
ok so its built by the book 1.3 pistons in front with red springs and 1.2 in the back with green springs.. I like the way it jumps but the back just slaps the ground when it hits.. Not sure of the oil he ran in it but what would you try from there?
I dont have the spring kit but I can glue some holes and change oil, any help to get that rear end from bottoming out would be awesome. without buying a bunch of springs
rear motor right now
Ok so the issue is bottoming out in the rear, the above info is what I had and the oils used were 35r and 30f.. What would you do to just minimize the bottom out? Maybe just plug 2 holes in the pistons? I like how it drives now and I just went to MM4 on the motor..
Also using a 87t spur what pinion should I be running with a boosted 17.5 on most tracks?
Old 12-15-2011, 06:31 PM   #2831
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Originally Posted by grapejuice View Post
Try mine, go to tresrey-usa.com and set-up sheets. If it's not changed yet, only different thing I have done is light red springs in the rear and the #3 hole on the rear hub.
4mm on the bumpsteer? Is that correct on your setup sheet?
fullsyzz is offline   Reply With Quote
Old 12-15-2011, 06:46 PM   #2832
lockmouth's Avatar
Trader Rating: 33 (100%+)
Ditch the stock spur and get the RW 69 or 75 spur.
MARIO KNOX
HOTBODIES RACING / FULL THROTTLE RACEWAY (OWNER / OPERATOR)
lockmouth is offline   Reply With Quote
Old 12-15-2011, 06:48 PM   #2833
4mm is std, or what the manual calls for, I am at 6mm on mine, as I noticed the car was a little sketchy when the shocks were compressed.
Old 12-15-2011, 06:55 PM   #2834
fullsyzz's Avatar
Cool, thanks.
Old 12-15-2011, 07:12 PM   #2835
+1 on this, I'm 32/75 with a mild boosted 13.5 atm
#NoChuck2015
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
