Like Tree26Likes
Old 12-15-2011, 08:47 AM   #2806
jurquhart's Avatar
Trader Rating: 22 (100%+)
Default Avid bearing kit
Just wanted to let you all know I emailed avid about a bearing kit and they put one together. It is $25 and then 3 and change for shipping in US. here is the link
http://www.avidrc.com/flexkit/?kit=371&kitname=DEX210
Hope this helps
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 12-15-2011, 08:56 AM   #2807
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by teeforb View Post
What's the stock rear spring and spur gear size?
Light blue rear springs are stock and 87T on the spur gear.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-15-2011, 09:00 AM   #2808
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Hope this helps
and they include a thrust bearing... quite a deal I would say.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-15-2011, 09:05 AM   #2809
hopsing's Avatar
Originally Posted by sparkwraps View Post
I used what I had, Red fronts and White rears. It was a completely different car. I know the fronts say that they should be the same as the Durangos, but it added a ton of off power steering I could hardly believe it. Like the springs react different - maybe more progressive where the Durango springs felt very springy.
On the bench, dropping the car with the stock springs, the car would land and not come back up, just land with a thud, with the Losi springs, the car was rebounding and seems more conformable/responsive to the track.
The track I run on has some silt in it and is hard pack/smooth with medium grip. Running a boosted 13.5. The track is adding in some clay in the coming weeks so grip should start to come up. I will be racing on a higher grip track Saturday so we will see how the car does there.
I have a master build/setup sheet that I have been slowly filling in that includes the spring chart. If there is any interest, I can post that as well.
The red Losi fronts are alot softer than the kit 210 springs....the 210 uses the DK BLUE front spring which would be springier than the Losi's...thats part of the reason you experienced more off power steering. I cant account for the car springing back up better with the Losi springs as my car feels fine and I'm still using the stock kit springs and I'm on par lap time wise at my local track in Exp 2wd mod. But hey, if it works for you then cool!
Steve Butts
Old 12-15-2011, 09:09 AM   #2810
Super Moderator
I can't reiterate this enough... the box springs that come with the car are for a mid motor balanced car, not a rear motor car. You CAN'T have one set of springs that will be optimal for both mid motor AND rear motor.... The weight distribution is VASTLY different between the two. I have nailed down the proper spring balance for an average rear motor car, and will have my setup sheet ready to post after this Saturday's race... just need to fine tune a bit more.
- RCSpecialties -
Old 12-15-2011, 09:36 AM   #2811
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Agreed! I was thinking I could tune around it.
sparkwraps is offline   Reply With Quote
Old 12-15-2011, 10:06 AM   #2812
stavman's Avatar
So what are you guys doing for Spur Gears???
No TDR stock yet and need to be ready if I BURN one up
Reaming ASC B4 Spurs????
Thanks guys... Cant wait ta RUN this baby
Stav
FYAIDGASAM
stavman is offline   Reply With Quote
Old 12-15-2011, 10:09 AM   #2813
Hope this helps
how do they(Avid) compare to Boca bearings? i know of the price difference, but just wanna know if Boca bearings are worth the money?
Summit/FluxHp/R1/CR01/SCX10/XR10/Scte/Nexx10sc/808e/22/Fs2SP...
chiatw73 is offline   Reply With Quote
Old 12-15-2011, 10:09 AM   #2814
tomdav's Avatar
Trader Rating: 42 (100%+)
Stav
Yeah just grab a B4 and ream it out, there is just a very small amount of the thick inner ring left when its done. The durango spurs are hard and noisy so I would go with the RW's.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-15-2011, 10:12 AM   #2815
hopsing's Avatar
Stav
Schumacher is a direct fit, or get RW Spurs off of Ebay. In a pinch ream an AE spur but do it slowly and carefully so that its concentric otherwise it wont spin true and you'll have high and low spots where the mesh will change.
Steve Butts
Old 12-15-2011, 10:20 AM   #2816
tomdav's Avatar
Default Outdrives
Look what showed up today. Bad pic but you get the idea.
Tom
The Couve, WA
davesrctracks.net
Old 12-15-2011, 10:31 AM   #2817
stavman's Avatar
WHAT IS UP TOM!!!!!!! Long time no see buddy
Ya RW's come from UK, correct? May have ta check on an account with them soon
Thanks for the info
Stav
FYAIDGASAM
Old 12-15-2011, 10:35 AM   #2818
Xchange's Avatar
Trader Rating: 10 (92%+)
Hey Guys,
I'm reading all the stuff on the DEX210 but i'm a bit confuse..
I actually run my 210 in MM4 configuration, the car was so so at the very first race but went very wrong since... i have so much frustration with this car! that's crazy! i run in loose dirt in the morning and hard packed in the afternoon, medium groove.
I can't understand what's going on.. in can't control the car on power, even when i accelerate very very smooth... the rear tend to swipe out...
Any suggestion?
A lot of people tell me to convert the car in RR3... but i dont know...
i just want to ditch this car here and take an RB5!
Xchange is offline   Reply With Quote
Old 12-15-2011, 10:40 AM   #2819
hopsing's Avatar
Originally Posted by Xchange View Post
Hey Guys,
Any suggestion?
You need to go Rear Motor for a loose track...even a med grip track you should be in Rear motor mode. You can go with RM4 if the track stays mostly loose but RM3 will be good all around with the right set up. MM4 is for high grip like running on carpet or astro, not loose dirt.
Steve Butts
Old 12-15-2011, 10:45 AM   #2820
Xchange's Avatar
let's convert that sh**t tonite lol.... hope it fix my issue and give me the ability to drive fast again!
What is the best all around setup for this car in a RM3 configuration?
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
