Like Tree33Likes
Old 12-14-2011, 01:01 PM   #2776
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by hopsing View Post
Ya, but I also run at West Coast which is hight bite track.
i see... with a 7.5.... on a high bite track... i would think your outdrives would wear faster than mine, as I run on a medium/high bite clay track with a 90% 9.5....
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-14-2011, 01:05 PM   #2777
hopsing's Avatar
Trader Rating: 13 (93%+)
Originally Posted by tomdav View Post
The online manual is confused as well. All three bearing that came in the kit are 8x5x2.5. No 3mm to be found.
Kyosho does use a 5x8x2.5 in their diff and in their steering bell crank....I remember measuring one of my bearings and I had one that was 3mm which I think was the one I blew out so maybe that was the problem.
Steve Butts
AKA, TrakPower, Serpent America/Desoto Racing, TrackStar, Futaba, EKD Paints
hopsing is offline   Reply With Quote
Old 12-14-2011, 01:17 PM   #2778
MantisWorx's Avatar
Trader Rating: 28 (97%+)
if ever there was a situation where RM4 is needed ,this is it!! this track was built last week and has not been raced on and only driven by a handful of cars so it is very loose and bumpy, i am running basically the same setup i was at the hardpacked track except i did the caster mod and went to 0 trailing, still running 20w f/r with 1.2/1.3 2 stg pistons, i can definately go to 17.5 in the rear as its not even close to packing up! i was pleasently surprised at how much traction is available, its actually easier to drive hard. im sure once the track hardens up and traction is increased i can clear the double-doubles, i did it with my SC right before the video! enjoy
http://www.youtube.com/watch?v=psReX8lRgKs
tires were losi 4 ribs and goosebumps.
MantisWorx is offline   Reply With Quote
Old 12-14-2011, 01:36 PM   #2779
hopsing's Avatar
Here are a couple of pics of my outdrives after about 35 runs with a 7.5 mod motor.
One thing I was thinking of was when I first built my CVD's one of them had bind in it. I had to clean up the cvd end of the dogbone slightly so that it would pivot freely throughout the range of movement in the axle. Its possible that if you have a "tight" cvd that during its rotation when it hits that tight spot it's causing an imbalance (which it will) that can prematurely damage/wear the outdrive.
Steve Butts
Old 12-14-2011, 01:56 PM   #2780
Super Moderator
Wow steve, you have almost no wear at all... I can only speculate that our outdrives are made out of different material... I have fewer runs than you (well maybe about the same), but mine are literally worn 5 or 6 times as much.
- RCSpecialties -
Old 12-14-2011, 02:10 PM   #2781
tomdav's Avatar
Trader Rating: 42 (100%+)
Looks good. My cvd's are free, no binding. The cvd can touch the axle and rotate freely on both sides although I have 4mm of limiters plus the droop screws to act as down stops so they never get to that angle. I just have a bad set of outdrives.
The 2.5mm might be a running change. If you run a 3mm it looks like the top shaft might be putting pressure on the race as opposed to just supporting it. I could get a 3mm in there but then the larger bearing would be pushed out from the diff case.
Drilled out some 55's to try on Saturday.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-14-2011, 02:25 PM   #2782
triplesix's Avatar
I'm running a 7.5 as well on a high grip carpet track and my car has app. 30 packs of runtime. There are almost no signs of wear on my cvd's and outdrives...
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 12-14-2011, 02:41 PM   #2783
tomdav's Avatar
Originally Posted by Jmuck69 View Post
Maybe a conical washer is needed to ride against the bearing instead of a flat washer?
Looking at the topshaft once I had the diff apart the washer touches it and not the bearing. Also the inner slipper plate can only go so far down on the topshaft. If you push the slipper away from the larger outer bearing(using a wider 8x5x3 bearing) all of the pressure would be transferred to the small bearing causing premature wear.
Looks like there is room for the 3mm in the pic. You can see the space to the left of the gear.
I do like the exposed slipper spring, so easy to make adjustments quickly and no adjustment cover to worry about.
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 04:05 PM   #2784
jnslprd's Avatar
Had the same issue with one cvd, my buddy also
jnslprd is offline   Reply With Quote
Old 12-14-2011, 08:38 PM   #2785
Trader Rating: 27 (100%+)
Originally Posted by grapejuice View Post
Try mine, go to tresrey-usa.com and set-up sheets. If it's not changed yet, only different thing I have done is light red springs in the rear and the #3 hole on the rear hub.
Also when I was driving it, it bottoms out a lot.. How do you get more pack out of the fat shocks? What should I do? I got it used so I dont know whats in the shocks but what would you all do?
Also lunsford shock standoffs are coming!!
C_Money is offline   Reply With Quote
Old 12-14-2011, 09:33 PM   #2786
Qwkrn U's Avatar
Trader Rating: 128 (100%+)
The shock pack is a issue on all the durango fat shocks. What most have done is close up a few holes in the pistions. Either use CA or melt them closed with a warm soldering iron.
Its hard to say exactly what you need but usually closing 2 holes makes a huge difference.
Wayne Robison
B5m , X-ray XB4 '15 ,xb8e, Scte 2.0
Tiny Boat Guy Paint Designs, Checkered Flag Hobbies, creativecustomtees.com
Qwkrn U is offline   Reply With Quote
Old 12-14-2011, 09:39 PM   #2787
Super Moderator
Are you running mid motor or rear motor? What springs, oil, and pistons are you running? Too many variables to give you an answer.
- RCSpecialties -
Old 12-14-2011, 09:40 PM   #2788
MantisWorx's Avatar
if you watch my vids , you will notice that my cars do not slap and there is plenty of pack. RCshox pistons eliminate that problem,both of those vids are 20w front and rear with 1.2/1.3mm 6 hole pistons. even on that drop off it barely kisses the chassis but not enough to slap. i am just saying, there is a cure.... why go through gluing holes shut and all of that? no point in running big bore shocks if you have to restrict the flow, may as well use std bore durango shocks with 4 holes, its the same difference!
on the latest vid there is a double that i jump and land flat bottom with no slap at all, while still being able to absorb the small stuff.
Old 12-14-2011, 09:45 PM   #2789
forty6's Avatar
What is the tallest pack that can fit this car?
forty6 is offline   Reply With Quote
Old 12-14-2011, 10:36 PM   #2790
murky123's Avatar
Originally Posted by MantisWorx View Post
why go through gluing holes shut and all of that? .
because it is way cheaper. and the kit comes with blank pistons, so if you dont want to close the 6 hole pistons, there is always the option of drilling your own custom pistons
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
