Like Tree17Likes
Old 12-14-2011, 08:00 AM   #2746
Moderator
Posvar's Avatar
Trader Rating: 461 (100%+)
Originally Posted by Cpt.America View Post
If you buy from Avid or Protek, they are $1 each and work great.
+1
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 12-14-2011, 08:19 AM   #2747
Jmuck69's Avatar
Good thought.. im not sure.. Could you imagine though what would of happened if the balls in the bearing had gone INTO the gearbox instead of OUT of the gearbox when it failed?
That particular bearing seems to be way too small for the job that is required. But other than that the car is solid and the gearbox/diff is butter smooth.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-14-2011, 08:22 AM   #2748
tomdav's Avatar
Trader Rating: 42 (100%+)
I found another error in the manual. The online manual lists the small topshaft bearing as a 5x8x2.5mm in the online assembly instructions. When you go to the part# description in the back of the manual it list that part 601022 as 5x8x3mm.
I was wondering why the inner diff bearings which are listed as the same size had different part #'s.
So can anyone confirm that the topshaft bearing is 3mm wide. I really dont want to rip the diff apart until I have my new outdrives.
Tom
The Couve, WA
davesrctracks.net
tomdav is offline   Reply With Quote
Old 12-14-2011, 08:32 AM   #2749
tomdav's Avatar
I just checked avid and protek and they do not sell 5x8x3mm bearings. Looks like I'll just need to add a shim or two.
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 08:47 AM   #2750
jurquhart's Avatar
Trader Rating: 22 (100%+)
I just checked the acer site and got sizes for bearings :
5x13mm - 2 pc
10x15mm - 4 pc
5x8mm - 3 pc
5x10mm - 8 pc
5x11mm - 2 pc
Only problem is they don't list the 3rd size...are they all 3mm? Trying to get bearings before I get my kit which it seems will take an act of Congress only been on back order for a month and looks like it will be after Christmas before I get it. Sorry for the digression from the topic of bearings
John Urquhart
Sponsors include Caster Racing USA, Radiopost, and Trick-parts.com
Caster F8T e-Truggy with Tekin RX8 & 2000 motor Radiopost radio & servos
jurquhart is offline   Reply With Quote
Old 12-14-2011, 08:47 AM   #2751
Jmuck69's Avatar
It's a 2.5 bearing.
B6D | B64D
Old 12-14-2011, 08:55 AM   #2752
tomdav's Avatar
Originally Posted by Jmuck69 View Post
It's a 2.5 bearing.
Check this out.
http://www.losipartshouse.com/servle...4pcs%29/Detail
Are they just trying to get you to buy a magical durango 5x8x3 bearing?
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 09:05 AM   #2753
Jmuck69's Avatar
Check this out.
I can measure my extra one tonight but pretty sure it's 2.5mm. I used a 2.5mm in that location and have no extra side to side movement and is not tight. A 3mm would definitely cause issues.
B6D | B64D
Old 12-14-2011, 09:15 AM   #2754
tomdav's Avatar
I just grabbed the power tools and removed the bearing its a 2.5mm. Your right the top shaft is very snug. Crisis averted!
I recieved an email that my new outdrives are on the way. The pic does not look as bad as it actually is. The pin is actually digging in deeper below the outer edge of the outdrive.
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 09:28 AM   #2755
Jmuck69's Avatar
You were able to remove the transmission in under 45 mins? your good!
B6D | B64D
Old 12-14-2011, 09:28 AM   #2756
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
That is what my outdrives look like... they have about had it. I was hoping to get a lifespan out of these more like the B4 or RB5.... I HATE buying outdrives. The ones on my cougar were soft as well, and eventually got me to sell the car. I was buying a $20 set of outdrives every 3 weeks, and it just seemed silly... these don't seem to be much stronger.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-14-2011, 09:37 AM   #2757
tomdav's Avatar
I actually did it in about 8 minutes with the electric screwdriver. I even left the rear shock tower attached to the shocks and rear bumper. Yanked it out from the battery side.
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 09:38 AM   #2758
tomdav's Avatar
Yeah I might have to park it for a bit until this gets sorted. Should not be hard for Durango to rectify.
Tom
The Couve, WA
davesrctracks.net
Old 12-14-2011, 09:48 AM   #2759
Super Moderator
I wouldn't count on it Tom... Say, are you going to be racing up here in that new PNW series? I don't think I realized you were up here in the PNW.
- RCSpecialties -
Old 12-14-2011, 09:59 AM   #2760
tomdav's Avatar
I'll be at TRCR and make as many as I can after that.
Tom
The Couve, WA
davesrctracks.net
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
